Old 10-02-2015, 06:15 PM   #1 (permalink)
Default Throttle Servo Adjustment
This is the part I don't get when setting up gov for electric heli. Using CC120HV ESC, do you guys have to mess with the default values on the Throttle Servo Adjustments? Do you guys have to calibrate your ESC?
I'm using NEO Express no vlink and CC120HV.
Thanks in advance.
Protos 380 NEO x2
Oxy 2
Goblin Fireball
norstaroption is online now        Reply With Quote Quick reply to this message
Old 10-02-2015, 06:59 PM   #2 (permalink)
Yes you will need to adjust the end points for the ESC on Castle Esc's. There is a castle set up video on the Vstabi web site under electric gov. They set up a castle 120.
Synergy Field Rep
Rail Blades Field Rep
Kevin Dalrymple is offline        Reply With Quote Quick reply to this message
Old 10-02-2015, 11:14 PM   #3 (permalink)
Oddly enough I didn't do anything on the Neo for my 700 with an Ice2 120HV. I left it at the default -100/+100 and it works fine.
On my 6HV with Hobbywing 70HV I just input the same values I used on the Blue Vbar (-104/+100) and it works fine.
#nodroneshere - 104
Old 10-03-2015, 12:00 AM   #4 (permalink)
What about your sensor configuration? Did you enter half of the motor pole?
I'm not getting the head speed I wanted. It worked fine with my silver line.
Protos 380 NEO x2
Oxy 2
Goblin Fireball
Old 10-03-2015, 06:26 AM   #5 (permalink)
Yes 1/2 the pole count. Using Hobbywing phase sensor on both.
#nodroneshere - 104
Old 10-03-2015, 06:26 AM   #6 (permalink)
Did you hit the reset button on the first gov tab when you chose Electric?
#nodroneshere - 104
Old 10-03-2015, 09:10 AM   #7 (permalink)
I'm using the built in rpm sensor from the CC Edge.
Protos 380 NEO x2
Oxy 2
Goblin Fireball
Old 10-27-2015, 07:34 AM   #8 (permalink)
I'm using nitro Gov on NEO, but i cannot turning min throtle adjust. Who heve help me !
Thank you
VŨ NGUYỄN
Gaui NX7 OS-105 HZ-R - HATORIES PIPE - MKS950HV - MKS980HV - MIKADO V 5.3 PRO
Gaui X7F K160 - SCORPION HK-4530-540KV - MKS950HV - MKS980HV - MIKADO V 5.3 PRO
LOGO 690SX JIVE PRO 120HV - MKS665HV - MKS669HV - MIKADO V 5.3 PRO
Love_Heli is offline        Reply With Quote Quick reply to this message
Old 10-27-2015, 07:41 AM   #9 (permalink)
Default I also am having this issue with the nitro governor
I am also not able to adjust the minimum throttle adjustment. The maximum level works with the fine tune adjustments in the software, but the minimum doesnt move no matter which way we adjust the lever in the software.
Also, what about idle vs throttle cut. Can we set the heli to idle (and adjust the idle as needed) when the throttle stick is ALL the way down?
Andy
akular1 is online now        Reply With Quote Quick reply to this message
Old 11-01-2015, 03:53 AM   #10 (permalink)
Hello Andy,
I'm just finish on NX7 . If you want to adjust, please download new PC or Mac software and turn off TX to work fine
VŨ NGUYỄN
Old 11-01-2015, 06:17 PM   #11 (permalink)
Default follow up
Hi there
Thanks for your message! Is there new software that we should download to enable this? Was this a new release. Also, when you indicate turn off transmitter, how can I adjust the trim with the transmitter off. I appreciate your help
Thanks again!
Andy
