Old 03-14-2011, 11:10 PM   #21 (permalink)
NTM
Mine's been fine.
NTM is offline        Reply With Quote Quick reply to this message
Old 03-14-2011, 11:47 PM   #22 (permalink)
TT
How big are the capacitors (in microfarads) for the HobbyWing 120A HV Pro? How many do I need? I might mod mine before using it just to be on the ultra-safe side. Cheap insurance.
TT is offline        Reply With Quote Quick reply to this message
Old 03-15-2011, 06:15 AM   #23 (permalink)
The 3 caps needed for direct replacement are 470uf, 63v,105 c,12.5 mm dia, 31 mm long.
TDRx2
Mikado 600SE
Sandy is offline        Reply With Quote Quick reply to this message
Old 03-27-2011, 05:30 PM   #24 (permalink)
Got my hobbywing 120 Pro esc installed and flying, LOVE it! It is very user friendly and easy to set up. The soft start is just as good as castles if not better. I am very pleased with it, and for the price I really dont think you can beat it. so far I have 20 flights on it. It was between a new CC 120 or the HW and am really impressed with it. A friend of mine had his CC 120 catch on fire and burn up his 700E frames yesterday....very disappointing. He is replacing it with a HW 120.
In Thrust We Trust.
jetblue2135 is offline        Reply With Quote Quick reply to this message
Old 03-27-2011, 05:56 PM   #25 (permalink)
Glad to hear you like. I love mine on my 450 Pro. HW Platinums are great.
Blade 130X
Blade mCP X (Bl)
Blade Nano CP X
Prôtos 700
Xtreme-Production
SYMAWD is offline        Reply With Quote Quick reply to this message
Old 03-27-2011, 09:01 PM   #26 (permalink)
do you have a link to ordered them??
thank you....!!
these are ok... they are 25 and not 31 is this a problem??
http://cgi.ebay.com/10-pcs-470uF-63V...item27b64c10b3
Or these??
http://cgi.ebay.com/Axial-Electrolyt...item3a63c91e1d
AP Logo600SX:Pyro 700-52 -Vbar-3x610 -bls251-Vbar GOv-Hw PL120HV-Thundepower
Logo6003dXera 560 - VbarGov - 3x8717 - Bls251 - Hobbywing PL 120Hv-Thunderpower
Cinestar 8 Cs gimbal - HoverFlypro - Tiger motors 710-Radians-Turnigy Plush 40A
MaSt0RaS is offline        Reply With Quote Quick reply to this message
Old 03-27-2011, 09:47 PM   #27 (permalink)
any way you can get some video posted of your heli with its new esc ? some hard flying tic tocs and all?
sniper_iron_man is offline        Reply With Quote Quick reply to this message
Old 03-28-2011, 12:01 AM   #28 (permalink)
Anyone using the internal gov of the esc?
Whats the difference between the 120hv and the 120hv pro?
T Rex 600 ESP BeastX
MangeAirborne is offline        Reply With Quote Quick reply to this message
Old 03-28-2011, 07:21 AM   #29 (permalink)
Hi guys; Where did you buy you HobbyWing in USA? My CC120 came down in a ball of fire yesterday and I'm needing a fast replacement.
Peace
Minicopter Diabolo 800+ - Minicopter Triabolo - Srimok FAIFA
Jeti DS-16
tribe3 is offline        Reply With Quote Quick reply to this message
Old 03-28-2011, 08:30 AM   #30 (permalink)
The diameter is important to fit the solder pads and need to be radials. 25 mm long are just fine.. I got mine from Mouser at $1 a piece and 2 day shipping.
TDRx2
Mikado 600SE
Old 03-28-2011, 08:42 AM   #31 (permalink)
I don't understand why CC doesn't use 63v caps, since even high quality caps are very very cheap. Especially when we pay that much and they don't even give us higher rate caps? That is confusing, because I am thinking higher rate caps like 63v would fry other electronics on the board?
BruceHuang is offline        Reply With Quote Quick reply to this message
Old 03-28-2011, 09:46 AM   #32 (permalink)
Long battery leads to the ESC, multiple connectors, widely spaced battery leads all cause higher inductance, greater induced voltages (ripple) with the rapid on/off conditions of these PWM motors shorten the life of these capacitors..
We could help a lot by shortening the overall battery lead lengths, reducing the # of connectors, adding more parallel caps close to the ESC for every 4" in excess of the ESC leads..Would this reduce the "flame" rates???
TDRx2
Mikado 600SE
Old 03-28-2011, 11:29 AM   #33 (permalink)
Why are people concerned about the caps being 50v when the max voltage on a 12s pack is 50.4?
Also to the original poster, the CCHV85 is one of the best controllers Castle has ever made. I have rarely if ever heard of any issues regarding them. It is also ready for all the firmware updates the ICE version of ESCs has. The only thing your missing is the data logging.
ping is offline        Reply With Quote Quick reply to this message
Old 03-28-2011, 02:04 PM   #34 (permalink)
Electrolytics don't like over voltage.. A high ripple values can cause the induced voltages exceeding the battery voltages.. With 12s batteries, the margin is close.. That is the reason for the concerns.. look here
TDRx2
Mikado 600SE
Old 03-28-2011, 03:06 PM   #35 (permalink)
I don't see how the ripple voltage could be above the input voltage, it should always be a drop. Either way lipos don't hold 4.2 volts per cell under load. Even very expensive lipos will drop below 4 volts per cell.
Old 03-28-2011, 04:19 PM   #36 (permalink)
Time will tell.. HW and CC both use 50v.. The engineers must think it is okay..
TDRx2
Mikado 600SE
Old 03-29-2011, 10:46 AM   #37 (permalink)
So were is the best place to get the 120 HV Pro ESC? I am takeing off the CC120HV and selling it.
Angelo
Angelo
esmoglo is offline        Reply With Quote Quick reply to this message
Old 03-29-2011, 11:45 AM   #38 (permalink)
I'm thinking about doing this too but I just did a search on the net and it appears that there are just as many Hobbywing fires out there. What to do...what to do...
Tommy
Trex 700E FBL - PowerJive 120HV, 700MX, Fullsize Vbar, Telemetry, WR Super BEC, various KDE Upgrades
Outrage 550 FBL w/mini Vbar, NEU 1907H1Y, CC 125A ESC, WR Super Mini BEC
Outrage 550 - same as above but with flybar
tptompkins is offline        Reply With Quote Quick reply to this message
Old 03-29-2011, 12:13 PM   #39 (permalink)
Originally Posted by tptompkins View Post
... it appears that there are just as many Hobbywing fires out there. What to do...what to do...
Tommy
yep... one here just posted on the vbar forum https://www.helifreak.com/showthread.php?t=291250
Jeti DS-16
Old 03-29-2011, 12:45 PM   #40 (permalink)
there is something wrong.. with the 500 motor was flying great and he had the problem on the frist flight with the 530 motor..!
