Old 07-17-2014, 12:17 PM   #261 (permalink)
Originally Posted by Dsss View Post
Wow that's something I would never expect to happen. Been using 3m 4011 or 4010 for a while now.
The issue is that the SK-720 is mounted on a plate and has a vibration pad under that plate so that the auto-level works reliably, so it is a bit more complicated to mount.
The SK-720 BE can be hard mounted if you don't mind not always having the auto-level feature available. Personally I barely use that much anymore, but I still love the vibration analysis.
Mark
Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc....
mkovalcson is online now        Reply With Quote Quick reply to this message
Old 09-28-2014, 04:08 PM   #262 (permalink)
Question Logo 550SX build
Greetings ... I am a proud new owner of a used, but in great condition 550 SX - other than stress fractures on the canopy, {first time owning a Mikado} and have just been reading your post on your build. NICE JOB !! I was wondering where you got your static kit from? And ~ I had a couple of other questions ... is there a tray that the main battery sits in? It looks awfully open underneath. Page 10 in the manual, figure 5 makes it appear that there is something there but I can not find a reference to it. Also OUTSTANDING IDEA on the canopy magnets I am definitely going to implement that!!
Datalyss is offline        Reply With Quote Quick reply to this message
Old 09-28-2014, 09:23 PM   #263 (permalink)
Anti Static: https://shop.mikadousa.com/04358-Wir...tic_p_410.html
Put male velcro on the bottom elements, fuzzy on the packs, place them carefully (use a silver marker or something to insure center of gravity) and strap them (it) down with a pair of battery straps.
Definitely do the magnet thing. I'm now using epoxy, and some plastic to separate the blobs while thery dry,
HAVE FUN.
PRÔTOS 500 Plastic, Logo 550SX/600SX, PRÔTOS Max2 up and flying!
Team MSH USA, Team Cyclone, Team Xnova
trickybit is offline        Reply With Quote Quick reply to this message
Old 09-29-2014, 12:32 PM   #264 (permalink)
I've found this amount of Velcro is working really well.
Just cover the bottom slats and 2/3 of the battery and it will hold well and come out easily.
Mark
Old 09-30-2014, 07:56 AM   #265 (permalink)
I guess I've had most of a season with it and I'm finding the Logo 550SX to be extremely reliable.
It has become my goto heli, like I was hoping.
At least the way I've been crashing ( 3 times so far this year ) I've found it repairs very quickly. I've yet to break a frame.
Mark
Old 01-31-2015, 03:10 PM   #266 (permalink)
Great thread!
I just got my first Logo and it's a 550SX. Really appreciate all the good 550 info fleshed out here.
Thanks to Mark, Ryan and everyone else contributing
Mark,
Did you ever shorten your ESC to motor wires?
Jay - Diligentia, Vis, Celeritas
Lynx / OXY Team Pilot, Zeal Team Pilot
jmackey is offline        Reply With Quote Quick reply to this message
Old 08-05-2015, 08:02 PM   #267 (permalink)
Default Bump!
Originally Posted by mkovalcson View Post
I don't know why but the scale of these little snap ring plyers makes them seem cute.
I got these on Amazon. 4 of them total, two pull and two push, two are straight and two are angled like below.
Including the lock ring these are shorter than my index finger
Suggestion: For scale, next time put a quarter (or penny, or ruler, or...) in the photo!
Just started researching my Logo 550sxV2 build and currently I'm on page 1 - (thus explains this thread's resurrection...)
This will be my first big heli. So far, so good (still in the study/research phase). Thanks for sharing your build secrets and tips!
ridge-runner is online now        Reply With Quote Quick reply to this message
Old 10-21-2015, 01:25 PM   #268 (permalink)
HEL
Hi!
Where to buy a rug (FBL Rotors Unlimited)? as in the photo
HEL is offline        Reply With Quote Quick reply to this message
Old 10-21-2015, 03:12 PM   #269 (permalink)
RJ
Originally Posted by HEL View Post
Hi!
http://www.fblrotors.com/FBL-ROTORS-...ION_p_578.html
RJ is offline        Reply With Quote Quick reply to this message
Old 10-21-2015, 03:44 PM   #270 (permalink)
HEL
Thank you
Old 12-29-2016, 01:03 PM   #271 (permalink)
Hi All
Just received my 550SE today, this will be my first Logo, I have only built Trex before.
First question is, should I use the rubber grommets on the servos as I have never done so before, also are the self tapping screws secure enough I thought they would be bolted.
SteveW is offline        Reply With Quote Quick reply to this message
Old 12-29-2016, 01:35 PM   #272 (permalink)
CHC Benefactor
Grommets are a matter of preference on an electric; however, I skipped them on my Logo 550. You have no choice on the screws but they do hold
Actually I had one screw not grip fully, just be careful to align well when screwing in and don't over torque.
Old 01-01-2017, 11:54 AM   #273 (permalink)
The new 550SE build is going nicely, everything fits together so well its a real pleasure to build.
Do I need to lubricate the belt ? it is not mentioned in the manual.
I have some "Servisol Silicone grease 70" spray, would this be suitable ?
I would of thought the lubrication is likely to make the belt slip a tooth.
Thanks again for your help.
Old 01-01-2017, 12:59 PM   #274 (permalink)
CHC Benefactor
Don't think it will slip if tension is right. A lot of people use the lube technique and I havent heard of any causing belts to slip. But, I've no experience on lubricating belts as it's pretty humid here and I use grounding of boom and tail to motor.
Old 01-01-2017, 02:15 PM   #275 (permalink)
FWIW, I've never lubed a belt.
I have sprayed static guard on a few in the past but I don't think it was necessary.
I have the tail grounded on all.
Lubing the belt probably can't hurt. I just always felt it would sling off the belt and make even more dirt/dust get all over the heli.
Not to mention attracting more dirt to the belt itself.
Just my 2 cents.
Old 01-01-2017, 11:04 PM   #276 (permalink)
CHC Benefactor
Oops, my bad. No lube necessary. I interpreted the static spray as a lube which is commonly used to prevent static build up. The static can zap your FBL which will leave you without control. This will appear as a glitch, lasting a short period of time, or your electronics may not recover resulting in a crash.
Old 01-09-2017, 07:31 AM   #277 (permalink)
The 550SE is nearly done now.
The manual says position the battery to achieve the correct CG, I guess the CG should be at the center of the blades, if so should the bottom of the skids be level or the boom ?
Old 01-09-2017, 08:14 AM   #278 (permalink)
CHC Benefactor
I personally look at the boom assuming it's ninety degrees to the mast which should be perfectly vertical.
Old 03-18-2017, 04:23 PM   #279 (permalink)
Excellent thread.
Does anybody have a handful of those McMaster Nylon bolts to spare? I'm willing to pay for it as well as shipping to Finland. Thanks.
This will be for my new 550sx build.
stark is offline        Reply With Quote Quick reply to this message
