Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > nano CP X Brushless Mods
nano CP X Brushless Mods Blade nano CP X Brushless Mods Information and Help
Old 11-22-2012, 04:54 PM   #1 (permalink)
Default No power
Finally got my mild motor installed but it has no power. Seems like headspeed is really low, barely flies, bogs easily and Miniaviation 190mah batteries only last 30 seconds to 3.7V. An suggestions on what to check?
itsmillertime0 is offline        Reply With Quote Quick reply to this message
Old 11-22-2012, 06:43 PM   #2 (permalink)
Default brushless
same issue here not impressed at all. my stock setup pulled harder than this setup. and i bought the wild kit
TEAM:
CYCLONE BLADES
matt blaisdell is offline        Reply With Quote Quick reply to this message
Old 11-22-2012, 07:26 PM   #3 (permalink)
Got the mild and love it so do others..
Did you ck the basics, binding, is the main gear lash ok ?
need some more info, settings, throttle curves...
Vbar Cont/Dx9 Align 600XN my first Nitro ! Original Goblin 500 stretched/Lynxed out Oxy2 now stretched and a few micros
Lynx Heli/Team pilot
thanasi is offline        Reply With Quote Quick reply to this message
Old 11-22-2012, 07:55 PM   #4 (permalink)
Did you change your throttle curves to flat across the board? You should have one value for each mode, I would start with 60% in normal mode and 70 to 75 in idle up. At 85% I could barely control it and had to lower the value to 78 in idle up 2. I'm running the mild kit and with stock batteries I'm getting 4 minutes with foward flight and moderate flipping.
Gaui X5-MiniVbar | Gaui X3-MiniVbar | Gaui X2 SK-540 | 250 Pro DFC |130X 3S GY280 | 300X-Ikon | DX8 | Real Flight 6.5
bmc76 is offline        Reply With Quote Quick reply to this message
Old 11-22-2012, 07:58 PM   #5 (permalink)
Ya im running stock batts and hyperion 160s they rock
im getting 3min with good amount of 3D.
Old 11-22-2012, 08:50 PM   #6 (permalink)
Default nano
well im running
normal-0-25-50-75-100
idle-1= 85-85-85-85-95
idle-2=100-100-100-100-100
this is not very powerful. i had to turn pitch down to 90/90 for motor to even pull it. the stock motor pulled 100/100
i can spin motor freely (back lash perfect)
Any ideas
TEAM:
CYCLONE BLADES
Old 11-22-2012, 09:04 PM   #7 (permalink)
Originally Posted by matt blaisdell View Post
well im running
Any ideas
Your normal mode won't work, it needs to be flat like iu1 and iu2. Your heli should be screaming like mad in modes 1 and 2. Try setting normal mode to flat 70 and go through the esc arming process. That may be the problem if you are initializing in normal mode with that curve. If that's not it, hopefully one of the experts will chime in.
Old 11-22-2012, 09:12 PM   #8 (permalink)
Default bl no power
ya i did the arming mode with a flat curve of 60 and still the same. this motor should pull 100 no problem but bogs at 94
TEAM:
CYCLONE BLADES
Old 11-22-2012, 09:17 PM   #9 (permalink)
check solder joints between the motor and esc first, all 6 wires in the 3 pairs must make good contact, most non blheli escs won't even start motors with one of the wires in a pair not making contact. the symptom is usually low power output if the motor will start at all.
Worst case is a broken motor wire near the motor from handling/install....
Post pics of your installs if possible.
Also what temp are your batteries at before you fly?
From tapatalk
Dylan ~ www.AstroidDesigns.com
Dylwad is offline        Reply With Quote Quick reply to this message
Old 11-22-2012, 09:23 PM   #10 (permalink)
Default brushless nano
solder points are good. i am using the stock batteries for the moment . the hyperion 160 are 25c as well so i dont see how they will help other than longer flight time
mine starts fine
TEAM:
CYCLONE BLADES
Old 11-22-2012, 09:50 PM   #11 (permalink)
mine starts fine
Wild kit needs hyperion 180, 240 or light mcpx batts, too much current draw for batteries that fit in the stock skids. Can you check your 0 pitch 100% throttle rpm?
From tapatalk
Old 11-22-2012, 10:30 PM   #12 (permalink)
Default blade nano
ok 0 pitch at 100 flat curve
is 4106
TEAM:
CYCLONE BLADES
Old 11-22-2012, 11:46 PM   #13 (permalink)
I flew my wild with the stock Eflite 150 before the larger LiPo order came in. It flew great. So much power...the Heli once idled up, wants to leap into the air. Just unbridled power.
So definitely something is wrong.
Your Normal curve is fine. But you can't really fly with that throttle curve. The heli will seem to lag.
Use your Normal mode to arm the ESC. (See arming instruction below) Then go to mid stick on the throttle and switch to Idled Up 1.
How I like to Arm to ensure you're not running into the Blade RX board's soft startup spooling feature, which will mess up the arming if you're running Governor Arm mode on your ESC.
Plug in battery.
Turn off throttle hold.
Move throttle stick up midway. You will hear a tone.
Move throttle stick all the way down. You will hear another tone to indicate that the ESC is now armed.
Now you're ready to flip to idled up mode to fly the heli.
Daryoon is offline        Reply With Quote Quick reply to this message
Old 11-22-2012, 11:50 PM   #14 (permalink)
is 4106
That's 2000+ rpm short of where you should be with the wild... does the esc still have all of the default settings that it shipped with? Could you be in gov arm mode by accident?
From tapatalk
Old 11-23-2012, 12:42 AM   #15 (permalink)
Default bl no power
i have no idea. i ordered the kit from you and then i installed it. how do i fix it
TEAM:
CYCLONE BLADES
Old 11-23-2012, 10:27 AM   #16 (permalink)
Default bl no power
From tapatalk
anyone know how to fix this
TEAM:
CYCLONE BLADES
Old 11-23-2012, 11:02 AM   #17 (permalink)
Dylan said it should ship with normal gov mode. But if for some reason its in gov arm mode, this is how you would use it. Its what I use on my mcpx.
normal throt curve: 0 20 X X X
where X is whatever you want the final throttle percentage to be.
idle up throttle curve is usually a v curve that you play with to get your tail as responsive as possible, keeping all the values above 20%.
To fly, plug it battery with throttle all the way down, wait for initialization. Move to half stick and the esc beeps. This is 'arming' the gov, so it will try to hold whatever speed you have at half stick. Then go to zero stick and it will beep again. Then you're ready to fly. It will act normal at 20% or less, and above 20% is will hold whatever headspeed you've armed it with. So go to half stick and flip to idle up to take off and fly, then flip to normal mode and go to zero stick to stop.
If that ends up working, then either you can leave it there and use it like that, or change it by tx programming, but there's no point in trying to program without knowing if that's the problem or not, so try this out and see if anything different happens.
MattRendall is offline        Reply With Quote Quick reply to this message
Old 11-23-2012, 11:40 AM   #18 (permalink)
Default bl no power
ya that did not work. still same issue
TEAM:
CYCLONE BLADES
Old 11-23-2012, 11:49 AM   #19 (permalink)
Kay well that's something we can rule out.
Um, Did you say your gear mesh was correct and not too tight? How about double checking that the motor isn't rubbing on and part of the frame or the servos? I had a servo on my mcpx somehow rub on the motor. But I can't imagine that the motor would start spinning at all if it was rubbing..
Can you post pictures of everything? I'm no pro, but I've done a few conversions on mcpx's and will install my nano kit as soon as it comes, so I might be able to help a bit, and I have nothing better to do today lol.
Old 11-23-2012, 12:10 PM   #20 (permalink)
Default motor
nothing rubs and back lash is perfect. this setup is missing 2000 rpm according to dylan
i think kit is bad or the little esc was not programmed . i built this very carefully and did not pinch any wires. no servos touch and motor spins very freely. i took my time. I will not buy another kit to fix it. i will go back to stock before i dump any more crazy money in to it. Like i said the stock motor pulls 100/100 pitch with little bog. this motor bogs 94/94 bad motor lags when i give full pitch and then tail blows out. Not happy at all
TEAM:
CYCLONE BLADES
