Old 11-22-2010, 06:51 AM   #21 (permalink)
Blade Forum Support
Talking vid
Great video. May try this on my outrage 550 and Trex 500. God is Good
tntburnett is offline        Reply With Quote Quick reply to this message
Old 11-27-2010, 06:53 PM   #22 (permalink)
Your welcome.
Mod helps Alot of things. Try it and let us know what ya think.
jondabear is offline        Reply With Quote Quick reply to this message
Old 12-02-2010, 01:20 AM   #23 (permalink)
This is the first time I have seen this in video... but I am new to all of this.
I generally avoid activities related to electronic devices. But as it happens, my wife has a tube of E6000 sitting in her craft room. She uses it to glue beads. Tomorrow I plan to borrow a bit and mod my 450.
Thanks, Bear!
Gotta love that Arizona Weather
Vibe-50;450Pro 3G; 700 F3C; Aurora 90; mSR, CX2 & Phoenix SIM
TheDHndrsn is offline        Reply With Quote Quick reply to this message
Old 12-09-2010, 01:17 PM   #24 (permalink)
Post
I want to try this 3g mod, but I am scared I will mess something up. It looks very simple.
My gain is at 45 and the heli is solid. Is it worth it so that I can turn my gain up a little?
jameson1234 is offline        Reply With Quote Quick reply to this message
Old 12-09-2010, 02:31 PM   #25 (permalink)
Looks like ya found it.
Old 12-09-2010, 11:14 PM   #26 (permalink)
Hey Jondabear,
I did the mod on my 550e and my 700n today. I could not find the 3M 4010 but I did find some 3M 411 heavy duty indoor / outdoor mounting tape. It looked like the thickness was close to the 4010. Have you herd of this and will it be allright to use?
Also you say not to strap the sensor with the 3M. Can you explain why.
Cant wait to test. Will air both birds on Saturday!!
Thank you for taking the time to make the video.
randy45c is online now        Reply With Quote Quick reply to this message
Old 12-10-2010, 11:21 AM   #27 (permalink)
My pleasure on the VID.
Now on to the short explanation.
Standard 411 WILL NOT do the same job as the 4010.
I would try to find the exact 4010 OR the LOCTITE brand equivelant.
4010 is a GEL and 4011 is a FOAM. 2 TOTALLY different dampening characteristics.
Thats why I also use the E6000, instead of regular silicon. Different densities,mass,vibe diferentials etc.
No strap needed because we have now "TIGHTENED" up the sensors from WITHIN.
Strap will only induce and transfer Vibes. If ya MUST, do it very loosely so as to keep it only as a safety precaution for the sensor. The way we use a strap to tie down a gyro, more or less. Very loose, but just enough to keep it from falling off the heli.
Hope this helps. PEACE!
Old 12-10-2010, 07:31 PM   #28 (permalink)
Jondabear,
I dont know what happened but I went to test the 550 today and it was unflyable.Flew great before the mod but with lower gains. I used the E6000 and installed it as per your vid. Mounted the sensor with the 410 with no strap. Gains on the unit at 12. Upon spool up the bird was VERY unstable, Went down with the gains and it seen to get worst, Went up to 1 o clock then 2 ect all the way till 3 or so. It got a tad better but still unflyable.
I then tried remounting the sensor with three other foams,tapes ect with the same results. The changes of pads did not make the unstable hover better or worst. I went as far as changes the cable to the sensor. No difference,
last thiing I did was to take apart the sensor and safely remove all ofthe E6000,inspect the board and reinstall. Same effect. I installed the Align metal antirotation brack that the sensor fits on.Can this be a issue.It was installed prior to the mod with no issues,
The only thing I have not done is made changes thru the 3G software yet. It is set on defult for 500 - 700. Any sugestions???
Any other guys that had an issue with a 550? I am a bit afraid to fly the 700 tomorrow.
Thank you
Old 12-11-2010, 01:32 AM   #29 (permalink)
LOCATION.
Sensor is happiest within the frames on the BOTTOM plate just below the motor.
Where it is rt now is absolutely the WORST place to put it.
Also try to use the Loctite brand tape or a ALIGN foam.
The spartan FOAM also works very well.
Old 12-12-2010, 01:52 PM   #30 (permalink)
Is it best to use a closed cell or open cell foam ?
Polyolefin or polyethylene ?
Function is offline        Reply With Quote Quick reply to this message
Old 12-13-2010, 12:10 PM   #31 (permalink)
Didnt know there was actually names for those. HAHA, Take a look at spartan stuff and let me know what that is. Id say the denser of the 2 which would be closed cell probably . Is that a corerct assumption?
Old 12-14-2010, 04:33 AM   #32 (permalink)
how long of a cureing time do you give it?i gave it 12 hours,when i installed the gyro now my swash leans forward at rest.when i opened up the case,all the stuff settled down on the board
Trex 700E DFC V-Bar , Trex 600N , Logo 600 SE FBL V-bar, Logo 600/550 FBL V-bar,Logo 400 FBL V-Bar ,Goblin 500 V-Bar, Blade 130X , Blade MCPx , Blade 500X
celm is offline        Reply With Quote Quick reply to this message
Old 12-14-2010, 12:04 PM   #33 (permalink)
Ive given it as long as weeks, as i do the mod for all my sutomers 3g systems before I send em out. (If requested).
And Ive given it as little as an hr or so on some of my personal helis.
Old 12-14-2010, 01:29 PM   #34 (permalink)
Well i am going away ina few days and be back after new years.that should be ALOT of time to cure.if i am having issues then i just messed up the gyro
Old 12-14-2010, 05:35 PM   #35 (permalink)
Hey Guys,
My hats off to Jondabear. He is a world of knowledge plus and just a good guy for the hobby. I had what I thought was a destroyed sensor and he took his time to help me get my 550 back in the air. He owns a hobby shop and at no time did he try to push a new sensor on me.
Give this guy a chance if you need some Heli parts or just some solid advice.
Randy
Old 12-16-2010, 07:32 PM   #36 (permalink)
Thanx for the kind words!
Old 12-19-2010, 12:37 PM   #37 (permalink)
I had a weird intermittent side to side wobble in my 500 which no amount of futzing with the gain adjustment would eliminate. I did the e6000 mod three days ago and flew it for the first time this morning. No wobble at all ... perfectly stable. Thank you Jondabear.
T-Rex 450 Pro V2 3GX
T-Rex 450 SE V2; GY 401; 9257; Jazz
T-Rex 500 ESP; Mini-Vbar; KDE Neu 1708H
JR X9303 ... and a world class collection of bent shafts
supercpa is offline        Reply With Quote Quick reply to this message
Old 12-19-2010, 03:00 PM   #38 (permalink)
Thats what Im here for! Your welcome .
Old 12-30-2010, 01:02 PM   #39 (permalink)
TTT as per request.
Old 01-14-2011, 10:51 PM   #40 (permalink)
AGAIN!....ttt
