Old 08-05-2012, 02:44 AM   #21 (permalink)
When my original fails I will be going to a Hitec 5084MG.
similis vobis fugere eam furatus
"The beatings will continue until morale improves."
-- William Bligh
petedee is offline        Reply With Quote Quick reply to this message
Old 08-05-2012, 08:28 AM   #22 (permalink)
I am about to order the Hyperion DS11-GCB
Blade 180CFX | 300X
MSH Mini-Protos 3S, Spirit FBL
Parkmaster 3D, Funjet, Sbach 3D, FrSky Taranis, FPV260 Quad, Pheonix Sim
stevebaker is offline        Reply With Quote Quick reply to this message
Old 08-05-2012, 09:12 AM   #23 (permalink)
Installed 3 days ago but no chance to try it out
QAV250
Futaba T8J
Blade 230S
godwisper is offline        Reply With Quote Quick reply to this message
Old 08-05-2012, 10:54 AM   #24 (permalink)
Would love to know how it performs before I pull the trigger
On paper it's the best of the bunch - best balance of weight vs speed vs torque vs price
Blade 180CFX | 300X
Old 08-05-2012, 11:21 AM   #25 (permalink)
I've been using the DS11-GCB in my LA Heli Ricco (same basic size heli) for well over two years, first with a Spartan Quark then with a Microbeast. Nice servo. It's what I'll put on my 300X if the stock servo gives me any issues.
Chris Boultinghouse
JustPlaneChris is offline        Reply With Quote Quick reply to this message
Old 08-06-2012, 08:12 AM   #26 (permalink)
Thanks Chris. Ordered the Hyperion for the tail. I'll test it later in the week and report back.
Blade 180CFX | 300X
Old 08-06-2012, 05:01 PM   #27 (permalink)
Cool
tail
cyclic
Hubschrauberpilot is offline        Reply With Quote Quick reply to this message
Old 08-06-2012, 05:10 PM   #28 (permalink)
Hub, your 300x looks hOoked up!
I want that motor too! Are you still running the stock esc? And the built in BEC for that setup?
X5-12s/Yep120/KDE600-530/FullSizeVbar/belt/550mm
180cfx-ServoSaverMod/TorqueTubeClutch/CarbonBlades, DX7se
My son Enzo - X5, 180cfx, DX7se
ccnada is offline        Reply With Quote Quick reply to this message
Old 08-06-2012, 05:27 PM   #29 (permalink)
Wouldn´t want to try those servos with the weak BEC of the stock ESC.
I use a Roxxy BL-Control 940-6 with 5.5 V/ 3A (peak 5 A)
Old 08-06-2012, 05:28 PM   #30 (permalink)
Wow... that is one bad-ass looking heli!
What are those red servos?
Also, is that a voltage meter on the side? If so, where does one acquire such a thing
mixfisto is offline        Reply With Quote Quick reply to this message
Old 08-06-2012, 05:46 PM   #31 (permalink)
Thx
Those are from Multiplex (firm own by HiTEC) & identically to HiTEC HS-5065MG
Yes it is & really handy.
Old 08-06-2012, 05:56 PM   #32 (permalink)
Originally Posted by Hubschrauberpilot View Post
Thx
I have one of these meters but never realized that there is a button you can press. By pressing that button what does it do?
JookSing is offline        Reply With Quote Quick reply to this message
Old 08-06-2012, 06:02 PM   #33 (permalink)
You can set the alarm: OFF, 2,7 - 3,7V
Old 08-06-2012, 06:11 PM   #34 (permalink)
...for low voltage, correct? Mine ranges from 2.7 - 3.8v
Old 08-06-2012, 07:14 PM   #35 (permalink)
You may want to look at the JR DS287MG servos for cyclic control and the JR DS290G servo for the tail. Having a good esc with BEC is critical or use a separate BEC on the speed control. I like to use programable BEC's and set the voltage for 6.0v and usually have had good luck with the Castle Creations esc's. Just be careful to follow the directions for using the independent BEC. Usually it is the red wire from the esc that is disconnected....I use a short 3" servo lead and disconnect the red wire on it rather than on the esc itself, that way I still have full ability to program the esc and the parameters I like to set up for flight with my helicopters....using governor modes and finding the best settings for the motor/esc/battery combinations. I use the Castle Link software on my computer for the programming of the BEC and also the ESC.
Bob
rcmorrow is offline        Reply With Quote Quick reply to this message
Old 08-06-2012, 08:02 PM   #36 (permalink)
What voltage do you set yours at?
I just might have to get one of these!
Old 08-06-2012, 10:11 PM   #37 (permalink)
Align ds415 on cyclic for me
next simu only...
ducatimoto is offline        Reply With Quote Quick reply to this message
Old 08-07-2012, 02:03 AM   #38 (permalink)
Before everybody goes rushing off buying BECs, my telemetry shows that the voltage never drops below 4.7V with stock servos, so it's working really well (for stock servos).
Also, it's obviously better to have your TX beeping to warn for low bat - if you have telemetry that is.
Blade 180CFX | 300X
Old 08-07-2012, 12:34 PM   #39 (permalink)
Well I received and fitted the Hyperion DS11-GCB on the tail:
I'm glad to report it works flawlessly. I threw everything at it, fast backwards, tail down funnels, aileron loops.
It holds solid in pitch pumps, no drift, no wag and nice hard stops with no bounce.
Running at 270Hz even though it can go to 333Hz, with an 8mm ball distance.
Lets hope it lasts a little longer than the stock did
Blade 180CFX | 300X
Old 08-07-2012, 01:00 PM   #40 (permalink)
That's excellent news, Steve!
I think you will have better luck with that servo. I sure like mine!
Chris Boultinghouse
