Old 01-24-2012, 02:33 PM   #181 (permalink)
just would like to share my settings and measurement as I read most have some trouble with theres , I'm using the original compass 500 FBL head , the original FB mainshaft and swash plate ( tried the compass swashplate but didn't work for me ) on the links I'm about half on the thread so thats ok for me
Iate the pic show my measurements
servo - MKS 9660a+ and at 14mm blue light on the BeastX @ 6 degrees
hope this helps somebody
| Kraken 700 : Neo | Atom 6HV : Evo | Raw 580 : Neo | vbct |
ragge1 is offline        Reply With Quote Quick reply to this message
Old 01-24-2012, 06:39 PM   #182 (permalink)
Originally Posted by skered53 View Post
So with the Atom links I should be able to lower the head by about 7.5 mm ( ie drill another hole in the mast / main shaft ? )
Who has them in stock ?
Any Compass dealer will have them available.
Jeff_Barrett is offline        Reply With Quote Quick reply to this message
Old 01-24-2012, 07:28 PM   #183 (permalink)
looked at Nankin, they didn't have them in the 4 pages of parts
T-rex 500FBL BeastX, I2 MRH & Swash, I2 boom support,( Bob's the Mahn ! ) DX7s. T-rex 550 I2 FBL head & boom support,KDE motor mount. CH-53E's 83-87. MCAS New River. FAA certified Airframe & Powerplant license holder since 1992
skered53 is offline        Reply With Quote Quick reply to this message
Old 01-24-2012, 09:02 PM   #184 (permalink)
Call Mike at Nankin directly-he will help you!
Old 01-24-2012, 10:42 PM   #185 (permalink)
Will do,
Old 01-24-2012, 11:06 PM   #186 (permalink)
Ragge1-
Good info, I am in the process of setting mine up. A little different Tracx, DS510, Stock main shaft FB and Swash with 3GX. I can't wait.
Kraken 580
Jose5x5 is offline        Reply With Quote Quick reply to this message
Old 01-25-2012, 12:23 AM   #187 (permalink)
The part # is 08-0139S (FBL Drive Tube)
Old 02-05-2012, 01:25 PM   #188 (permalink)
Hey guys just finished setting up my tracx head with the 3gx. I just want to give a special thanks to Rick at http://rdlohr.com/. The FBL pitch gauge leveling tool is awsome and the receiver/gyro mounting plate works great. Now i just have to get out to maiden and do some final tweeking on the 3gx. hopefully I can keep it out of the dirt.
ID:	286670   Click image for larger version
ID:	286671   Click image for larger version
Kraken 580
Old 02-05-2012, 01:51 PM   #189 (permalink)
Originally Posted by Jose5x5 View Post
Hey guys just finished setting up my tracx head with the 3gx. I just want to give a special thanks to Rick at http://rdlohr.com/. The FBL pitch gauge leveling tool is awsome and the receiver/gyro mounting plate works great. Know i just have to get out to maiden and do some final tweeking on the 3gx. hopefully I can keep it out of the dirt.
Thanks much Jose! It was my pleasure.
Rick
Helifreak, the place to be!
rdlohr is online now        Reply With Quote Quick reply to this message
Old 02-08-2012, 07:14 PM   #190 (permalink)
Default PTFE Shims
If anyone wants some 15mm shims, send me a PM,
I have a nice sheet of .015" stock and a sweet 15mm punch, makes a nice disk that fits under the 500 trax grip perfectly, I'll look into a hole punch for the 3mm hole, but for now you will need to cut your own hole as close to the middle as you can.
two of these discs are .030" and per my measurement, the gap was .027"
Cheers.
Old 02-26-2012, 10:43 PM   #191 (permalink)
Cheers.
Just received some shims from Skered53, The ones I received had the 3mm hole punched already. These work and fit like a glove. They are a way better fit than the ones i bought at heli direct. Not to mention the workmanship quality looks very professional. Thanks again Derek, now I dont have shims that stick out of the blade grips.
Kraken 580
Old 02-27-2012, 12:02 AM   #192 (permalink)
You are welcome my Brau !, the 15 mm diameter is just right, can't even tell they are there.
Old 05-22-2012, 03:30 PM   #193 (permalink)
Default Tracx Head Question
I just installed one of these heads and noticed that if the bolts between the yoke and arm grips are even slightly snugged up, there is noticeable binding between the yoke and the grips. Even tightening too much by hand creates a noticeable difference. It also seems like not very much thread is engaged in the arms either. Is this normal for these heads? I want to fly the heli but am leary of relying on loctite this much to keep the bolts in place. Also, this is without the 4 small brass washers installed on the inner and outer yoke arms. I'm assuming those washers are supposed to be installed there but couldn't find anything definitive regarding their use or installation.
GRR45 is offline        Reply With Quote Quick reply to this message
Old 05-22-2012, 05:57 PM   #194 (permalink)
The small thin-pattern washers go between the bearing in the yoke, and the blade grip arm. Usually, only one is required. This is to keep the blade grip arm from touching the bearing shield and causing binding (as you describe).
The yokes should move freely in their bearings with the bolts tightened properly.
Old 05-22-2012, 07:47 PM   #195 (permalink)
Thanks for the info- I installed one small washer on each arm and everything is smooth
Old 05-22-2012, 09:56 PM   #196 (permalink)
You are most welcome!
Old 06-27-2012, 04:41 PM   #197 (permalink)
Ordered the shorter links yesterday, no i need to drill a new hole in my FBL shaft that 7.5 mm away, should give my that much more shaft into the center spindle, I'll post pics once I get it completed.
Tags
tracx, trex 500 fbl head
