Warp 360 Compass Warp 360 Model Helicopter Discussion |
06-19-2014, 06:05 PM | #1 (permalink) |
White gear rubs against frame.
The white gear barely rubs against my frame. I have loosened my tail belt and tried messing with the gear to see if it was something mechanical I messed up on. Has anyone heard of this and a solution for it?
Just one more honey... I don't have one like this. |
06-19-2014, 07:13 PM | #2 (permalink) |
Re: White gear rubs against frame.
Look at my post "new Warp some issues" a view topics below this post. Double check you have the spacer between the maingear and bearing.
-TT E700 V2-vbar-mks950-980-Kosmik 160HV-Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+Spirit Pro |
06-19-2014, 09:38 PM | #3 (permalink) |
Member
I used a dremel to remove some of the frame area where it would rub slightly.
06-19-2014, 09:40 PM | #4 (permalink) | |
Here is my thread on it. https://www.helifreak.com/showthread.php?t=609081 |
06-19-2014, 10:58 PM | #6 (permalink) |
Okay sweet I will give that a try, thanks. Is the photo you posted of your warp after dremeling? How did you get it to look so clean if it is?
06-20-2014, 02:04 PM | #7 (permalink) | |
Sent from my SGH-I337M using Tapatalk |
06-20-2014, 02:13 PM | #8 (permalink) |
I believe if you sand the maingear and build it correctly this shouldn't be nessesary.
06-20-2014, 02:53 PM | #9 (permalink) |
Member
I built mine correctly but decided to take a bit off the frame rather than mess with the white ring around the main gear.
06-20-2014, 03:06 PM | #10 (permalink) | |
Compass should really slightly tweak the design so the main gear and tensioner pulley line up properly or include different size shims so the builder can shim it imo. Sent from my SGH-I337M using Tapatalk |
06-20-2014, 07:47 PM | #11 (permalink) |
I am running the fusuno frames. They seem to provide a bit more space.
The last time I had an issue with my main gear rubbing the frame my top bearing block was a bit bent. Sent from my SCH-I535 using Tapatalk
NX4|Tri-Chronos|Chronos|7NT|Specter700 Saje Marvin - Citizen 125 |
06-20-2014, 11:00 PM | #12 (permalink) |
I don't run it at all! Just the gear.
It doesn't need it.
Rapid Helis Australia |
06-22-2014, 12:40 PM | #13 (permalink) |
You don't run the white pieces???
06-22-2014, 01:36 PM | #14 (permalink) |
Sand them, don't over tighten the bolts, build precisely, no problems
06-25-2014, 08:01 AM | #15 (permalink) |
Hi, no not all the belt is in a happy place, I guess the pulley guide keeps it where it should.
06-26-2014, 09:36 AM | #16 (permalink) |
Yep, did this on mine, works perfect, and even look better, more industrial mean black kinda sexy looking machine, yeaahh
XL Power 520(soon to become a 480), Warp 360 , Tarot 360Sport, Logo480 LowRpm , Logo 500 T500 AP |
07-14-2014, 06:54 PM | #17 (permalink) |
Can you post a pic of your warp without the white guides?
