Old 11-23-2012, 09:20 AM   #41 (permalink)
Glad you got it sorted. I was beginning to get worried .
Moto
MX48 is offline        Reply With Quote Quick reply to this message
Old 11-23-2012, 05:20 PM   #42 (permalink)
Great community and support here!
Gravity Fighter
NewR is offline        Reply With Quote Quick reply to this message
Old 11-25-2012, 03:41 PM   #43 (permalink)
So any Thr curve I make over 50% gives me the same exact HS. I rebinded the vbar mini. Still does it. Over all I'm getting more HS. But if I do a 60% curve and a 85% curve no difference. But if I do a 40% and 85% big difference.
maarset is offline        Reply With Quote Quick reply to this message
Old 11-25-2012, 05:32 PM   #44 (permalink)
Something is wrong or faulty in your setup.
With yge gov store, the th % is very linear, I normally just use a calc to get a start % then tach to check, it's normally within 100 rpm to what I wanted.
Max calculated hs with full charge = 3500, so if I want 3000:
3000 / 3500 = .857... So I would start with 86%
[B]TT E820 - Kosmik 200, Scorp 5035 TT G4.1(x2) - OS 91 3D Speed, Hatori
MSH Brains + JETI DS-16
rossk is offline        Reply With Quote Quick reply to this message
Old 11-25-2012, 05:59 PM   #45 (permalink)
Maybe I'm not being clear.
If I go from idle1 65% flat curve to idle2 80% flat curve HS doesn't change. If I have a idle 1 40% flat curve to a idle 2 80% flat curve HS changes.
Old 11-25-2012, 08:32 PM   #46 (permalink)
The crazy thing is I plug in a 4S 2150 rhino pack and I get a definite change in HS.
Old 11-25-2012, 10:15 PM   #47 (permalink)
Sounds like your other batteries can't provide power for higher HS.
MiniProtos Carbon with Low FBL, MSH 2580kV, YGE 60A, Mini V-BAR
Kyosho Concept 46VR with ASP46, GP750
Walkeras: Genius CP Brushless, V100D03, V120D02
Futaba T8FGS
pilot4fn is offline        Reply With Quote Quick reply to this message
Old 11-25-2012, 10:18 PM   #48 (permalink)
Yah. That is what I'm thinking. Will run those 4S packs at 65 or 70 % till I get some 6S packs for my 6S motor.
Old 11-26-2012, 05:21 PM   #49 (permalink)
Well I had 4 SUCCESSFUL flights with the mini p today. Using the Rhino 2150 4S packs and a 62% flat throttle curve. 2580KV motor. 16T.
Had really nice pop. Flipped and rolled rather quickly.
Sometimes in flips, and all the time doing tick tocks I get fluttering from the blades (Align 3G 325mm).
Maybe I need to replace the dampners? They look a little tired.
Or is this maybe a notchy thrust bearing in the Head?
Too high cyclic gain?
If I have the main grips disconnected from the swash and turn the grips they feel a little notchy. But if I pull on them a little they are smooth.
Also I think I might have some high vibrations. It doesn't sit nice in a hover. (mini vbar pro black). Black thick soft pad / metal plate / white pad / vbar unit above boom.
Is the lower part of the frame under main gear a better place for the FBL unit? Less vibs?
With the main blades off and the tail blades on, hooked up to the vbar spektrum analyzer I'm getting 600 reading and it is coming from the tail.
Tail output shaft seems nice and straight. Tail is smooth. Using the stock black tail blades.
But other than that, I was very happy with it today.
Now I just need to find some 6S packs
Mike
Old 11-26-2012, 05:59 PM   #50 (permalink)
600 is way too many!
You should be aiming for < 200 @ 3000 rpm hs.
Get a base line with no mains or tails, this should be < 150.
Dynamically balance the tail blades with the spektrum analyser on the bench, adding tape to a tail blade and testing to see if better or worse.
Balance the main blades on a balancer, u can also do them dynamically if u have Bluetooth for your vbar.
I found crappy blades just don't work well, I think rail 326's are the best!
It's still a band aid solution, you should be able to get good hs with 3S packs, I suspect when u go 6s with new 1300kv motor, you won't have this problem...
Old 11-26-2012, 06:07 PM   #51 (permalink)
Yah should get good HS with 3S. I think those 3S packs were tired.
Thanks for the info on what to shoot for on the Spektrum Analyzer.
Going to mess with it tonight.
