Old 02-06-2011, 10:26 AM   #1 (permalink)
Default crash durability
well i have to say this thing is really strong... it was sunny for the first time in a while yesterday so i went flying, only having 3 flights on it i wasnt use to it yet... was doing some pitch pumping on it trying to figure out the problem with my pitch, got a little close to the ground and bam... hit extremely hard. i was quick on the th as i ran up to it all that broke was the fbl ball link broke the plastic main grip, and one long rod broke off, and my new cosmetic flawed radix fbl were cracked... didnt strip any servo gears or do any other damage that ive noticed so far... i did a run up and all the shafts look straight...
my main question is do the fb and fbl use the same long rod? i can only find one online and im pretty sure they do just want to double check before i place an order online
michael88997 is offline        Reply With Quote Quick reply to this message
Old 02-06-2011, 09:40 PM   #2 (permalink)
Bummer!
Looks like both versions use the MSH40051 long rod.
Chris Boultinghouse
JustPlaneChris is offline        Reply With Quote Quick reply to this message
Old 02-06-2011, 10:38 PM   #3 (permalink)
Ya I'm guessing that since there isn't other arms and their close in measurement...
After looking it over closer I took the grips off and the spindle is bearly bent so I'm going to replace that, also what is puzzling me Is the main shaft collar was pretty far off the bearing like the entire head was pushed down, and the bolt inside the main gear was bent, but it all went back to position except for the collar, so I guess somehow it popped back in... I don't want to pay 5 bucks for the main gear just for that screw so I'm gonna look at a home depot or something for it
Old 02-07-2011, 11:24 AM   #4 (permalink)
I think they should start selling little packs of screws or something because I believe with the design the screws are going to give before parts, just like my screw inside the gear,
How do you measure the screw? It's 2mm wide I believe and from tip of head to tip of threads it's 20mm long so I'm assuming it's a m2x20mm
I'm going to try and find it at home depot and buy a few
Old 02-07-2011, 11:49 AM   #5 (permalink)
I'm breaking one main gear screw per crash. I'm using the one of my TRex as replacement.
Other parts I've broken (on FBL):
- Main grip
- Main shaft
- Main shaft collar screw (during repair) *
- Spindle
- Head link
- Tail fin (vert, planning to mount two together next time)
- Tail lever
- Tail guide
+1 on the hardware bag.
PS * Collar is listed on MSHeli web site as MSH41005 Main shaft locking ring.
ziper_it is offline        Reply With Quote Quick reply to this message
Old 02-07-2011, 12:27 PM   #6 (permalink)
Mines about the same, didn't break anything on the tail and my lock collar made it, do they sell that screw separately?
Have u tried the solid main shaft? Rh is out of the hollow so I was going to try it, I also broke the links that are the swash trailers on fbl,
But all my bearings looked to have survived
Old 02-07-2011, 05:09 PM   #7 (permalink)
i broke pretty much the same as you guys but also the servo mounts cracked and the washout hub.
JASON671 is offline        Reply With Quote Quick reply to this message
Old 02-07-2011, 05:15 PM   #8 (permalink)
Ops, forgot to tell I scratched my beautiful canopy.
Time for a re-kit? Looks almost worth for blades and canopy alone.
Old 02-07-2011, 11:15 PM   #9 (permalink)
what are these repairs adding up to?
eightythree is offline        Reply With Quote Quick reply to this message
Old 02-08-2011, 02:13 AM   #10 (permalink)
Not too much.
Main shaft (hollow) is 6.25EUR each, spindle 2.70. Main grip is 2.50 and a set of links 3.00.
Old 02-08-2011, 02:17 AM   #11 (permalink)
Originally Posted by ziper_it View Post
Not too much.
Edit:
Regatding the rekit, I was considering that the canopy is 31EUR and SAB blades 38. This sums up to 70, which made me think that it could be worth to buy a naked kit (220) and have a full set of spares instead of buying these items alone.
Old 02-08-2011, 07:43 AM   #12 (permalink)
Ya mine was around 20 bucks without blades and now I have a few spares... Not bad for how hard I hit
Old 02-08-2011, 09:00 AM   #13 (permalink)
ahh.. never looked at parts prices yet.. Ive got extra blades, so crashing this heli won't be a big deal
Anyone know if Radix fly well on this heli?
Old 02-08-2011, 09:05 AM   #14 (permalink)
I crashed some cf radix 325 fbl ones and I have a second pair waiting to go... Honestly I can't tell much of a difference but I haven't got to push them hard, but I will most likely stick to the cheap align or stealth blades
Old 02-08-2011, 04:19 PM   #15 (permalink)
Anybody know a good place to get a m2x20 screw? Lowes, home depot, radio shack, best buy don't carry them
Old 02-08-2011, 05:53 PM   #16 (permalink)
Try Denton Tool & Fastener -
www.fwbt.net - 700 North Locust Street, Denton - (940) 383-2183
That should be similar to some fastener stores we have here in Austin.
Chris Boultinghouse
Old 02-09-2011, 03:06 PM   #17 (permalink)
just tried them they dont, neither does northern or harbor freight... my lhs is closed today but im going to try them tomorrow, my friend might have one laying around to get my by this weekend... i found a set of 12 on ebay but they will probably take a while to get here...
Old 02-09-2011, 03:33 PM   #18 (permalink)
Try these guys...
http://baindustrial.com/fasteners.html
ri0grand is offline        Reply With Quote Quick reply to this message
Old 02-10-2011, 12:36 AM   #19 (permalink)
To get a good selection of metric screws locally, you need to go to the smaller neighborhood hardware stores. They usually have a huge selection, where as the larger chains (home depot, lowe's) don't have much. Around here any True Value hardware will have a full selection.
-David
Trex500 sk360 | Logo400 vbar | Logo500 vbar | logo 600se vbar | Synergy N9 sk360 | E-Aurora vbar | Mini Protos beastX | mcpX
whaleboy is offline        Reply With Quote Quick reply to this message
Old 02-10-2011, 11:50 AM   #20 (permalink)
Got spares, back on the air tomorrow!
