Go Back   HeliFreak > R/C Helicopter Support > Gas Powered Thoughts
Gas Powered Thoughts Advice for Gas Helicopter Success from Carey Shurley
Old 04-21-2015, 07:24 AM   #41 (permalink)
And that's why I use LiIon packs! No balance leads...
"I love the smell of Nitro/Gas in the morning!"
Citizen 654
rcnut is offline        Reply With Quote Quick reply to this message
Old 04-21-2015, 08:50 PM   #42 (permalink)
you cant charge a Lipo, balance it and draw current from it all at the same time. Raja would have to incorporate a microcontroller into his jewel to deal with all of that, and that would drive the cost up.
better to keep things simple.
gassed is offline        Reply With Quote Quick reply to this message
Old 04-22-2015, 07:56 AM   #43 (permalink)
Same principle as a car battery...
Citizen 654
Old 04-22-2015, 03:06 PM   #44 (permalink)
Don't quote me on this, but from my understanding if the current is low enough then a lipo does not need to be balanced.
Take a look at all the small hyperion lipos like those used on ultra micro planks, my 180 mah 3s and 240 mah 2s packs that I fly don't even come with balance leads from the battery manufacturer. Why? Even at a draw of 5 amps it's not enough to unbalance the cells. Ask hyperion about this yourself, and you will get the same response, the current is too low to unbalance the cells.
Because the generator supplies all the power the on board pack is there as a buffer. It only gets used until the generator is up and spinning. Therefore, the buffer pack sees a very low current.
If the output of the bec in the setup is ~8.4v there is no way to overcharge the pack, the potential coming out of the bec would have to be greater than 8.4v in order to over charge the pack.
XL Power 700v2 Nitro NME - OS 105HZR - Power Tune - Rail 716/106 - Brain2 HD
Sowa is offline        Reply With Quote Quick reply to this message
Old 04-23-2015, 10:16 AM   #45 (permalink)
Default +1 on the post above ^^^
And the generator is flexible, you can use it with all kinds of packs, from 4 cell NiCD/NiMH packs, to 5 cell of the same or 2 cell LiFE packs, to 2 cell Li-ion or Lipo packs. It won't overcharge any of them as you set the voltage to the peak charge level of the packs.
If you want to keep a lipo at a lower charge level so that over time it won't get damaged from staying closer to the top, you could lower the generator voltage down to 8v or 7.5v. The only drawback from this is that the battery is always have a lower charge level in it, which means that it will have less run time in the case where you need to use it.
-=>Raja.
MA 1005, Hanson 270, 4717 flts, Spectra-g, Hanson 270, 3672 flts
Whiplash-g V1-2, Hanson 300, 2235 flts, Whiplash-g V2, Hanson 300, 1552 flts
Whiplash Turbine, TS 45i WSE, 296 flts
Jewel on-board Generators, Miniature Aircraft Team Manager
rbort is online now        Reply With Quote Quick reply to this message
Old 04-23-2015, 08:29 PM   #46 (permalink)
I still am curious about using a Optipower Ultraguard for a buffer pack. It would allow one to run at 8.4v and not have to worry about putting the pack in storage mode if it sits for too long, as the Ultraguard has a discharge circuit built in.
Old 10-08-2015, 02:28 PM   #47 (permalink)
Couldn't you add a larger capacity LiPO to the Ultraguard?
~Jim~
Goblin700 Gasser TRM-300, BD Axon,
Align700E w/HC3SX, and a Goblin 380 w/BD3SX, using Futaba 14SGH
KSHeli is offline        Reply With Quote Quick reply to this message
Old 10-09-2015, 01:40 AM   #48 (permalink)
Yes you could do that as well. It was just a hair brain idea of mine to use an optipower Ultraguard for a buffer pack. One of many, and probably not a good idea.
The cc bec that Raja uses in his kit is adjustable but only to a few select voltages, at maximum it outputs 8.0v. Im ok with storing my packs at 8.0v, so I'm keeping it simple. Let the backup solution be a back up solution lol.
Old 10-09-2015, 06:16 PM   #49 (permalink)
Default Actually
Actually no you can program it to 8.5v if you want as well, and also 12.5v if you're using it with a 3 cell Lipo or Li-ion battery.
-=>Raja.
Old 10-11-2015, 02:34 AM   #50 (permalink)
Really? I swear all the other values were grey and unselectable. I'll have to check out the software again.
Old 01-26-2023, 01:11 PM   #51 (permalink)
Default gob gasser one-way bearing for jewel generator
gob gasser one-way bearing for jewel generator (2 min 48 sec)
cruzroy is offline        Reply With Quote Quick reply to this message
