Old 11-11-2010, 03:41 AM   #241
gorn
with the tail pushrod not connected to the servo, how stiff is the rods movement by hand?
Should move very freely.
Have you lubed the tail shaft?
Failing all this, use a full size tail servo.
I was never happy with the smaller servo on mine.
Was night and day difference with a full size servo
If you bling it, they will come!!
gorn is offline        Reply With Quote
Old 11-11-2010, 03:31 PM   #242
pmikeyg
Gorn, I am gonna go to a 9254 on the tail. It's a little better, but not rock solid. I checked the tail and everything moves freely.
pmikeyg is offline        Reply With Quote
Old 12-30-2010, 02:47 AM   #243
aliosha323
^^^^ havong this EXACT same problem...
Current tail set-up;
Fut S9254
Align GP 750
KBDD Blades
servo hole at 12mm
Previous Tail set-up;
Fut S9257
Inertia 860 Gyro
No binding, everything moves smoothly, just cant get it to where the tail is holding well at all, it feels extremely "weak" (i.e. a gust of wind comes and it blows the tail out in a hover)
Im just completely lost here...
aliosha323 is offline        Reply With Quote
Old 12-30-2010, 12:13 PM   #244
EricW
Cut the guide-eye for the carbon rod off, you don't need it, and it can cause friction.
make sure the tail slider works very smooth.
use MSH tailblades (the stiff type if you like), the blades are designed for this heli..
I still use MSH tailblades and they are perfectly fine, you can even get them in different colors nowadays.
And optimize the settings and the damping on the GP750 (sensitive gyro).
Make sure your servo uses maximum resolution between the limits (finetune servocenter distance)
Btw..I fly it (3D) with a mini servo (JR3500) for more than two years now, rebuild it a couple of times, and it has always been rocksolid.
One day I got stung, and now I love rotor sounds...Team RIGIDHELI.COM
T-Rex 700N Pro, Compass 7HV ult., MSH PRTOS
EricW is offline        Reply With Quote
Old 03-21-2011, 09:42 AM   #245
chriscummings83
Default Pictures
Any pictures how what you did to get the JR 3500G to fit on the tail servo holder
chriscummings83 is offline        Reply With Quote
Old 10-23-2011, 01:32 AM   #246
spykez
Originally Posted by gmhelo View Post
Easy method is
http://www.youtube.com/watch?v=k_2RJ9YS7dA
I know the guy who makes these, I have one and it is very good.
Gary
Gary, that tool really looks very convenient. Have you any ideas if it's still available to purchase? Over a year since your post. Thanks
Still in exile. FML.
spykez is online now        Reply With Quote
Old 06-10-2012, 06:36 PM   #247
dinopilot
dinopilot is offline        Reply With Quote
Old 10-16-2012, 02:40 PM   #248
karl k
This thread has been a good read. I've scooped a used one and am looking forward to flying it.
Thanks for the videos, Finless. It gives me some good things to look out for in the maintaining and repair of the heli.
karl k is offline        Reply With Quote
Old 11-30-2012, 05:29 PM   #249
Cincinnatus
Default guide pulley spacer
In step 2 in Bob's video--and my manual is identical--during the assembly of the guide pulley, there are supposed to be 2 Guide Pulley Spacer 3x5x0.6 MSH 50018. Mine appear to be missing (and yes, I have looked at ALL the washers in that bag.) Funny thing is, these are not listed on the contents printed on that bag, Bag B, either... I read the contents of the other bags, and I don't think they are here at all.
Anyone else experienced this? Got a solution other than ordering the exact one, like maybe something I can get OTC somewhere?
Or maybe, since they are not even listed on the bag, have they been eliminated from the design, but the manual is not updated?
Cincinnatus is offline        Reply With Quote
Old 11-30-2012, 06:27 PM   #250
Dr. M
Looks like those spacers have been discontinued. I don't have them on my pulleys.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
PRTOS 500 FBL "Sky Whip" | Robird G31
Audacity P6 FBL "Phoenix" | MSH Brain | 12s
Goblin Speed | iKon
Dr. M is offline        Reply With Quote
Old 11-30-2012, 09:54 PM   #251
Cincinnatus
hmmm...
Edit: The (newer, I guess) manual for the carbon version does not have the spacers, so I think you are right.
Old 12-24-2012, 01:34 PM   #252
matthewcornell
Thanks so much for the vids, Bob. I started my CF FBL build a few days ago and have been following along. Question: I may have missed the answer elsewhere, but I'm to the point where you've decided to mount the tail servo on the left side of the boom. Does that mean I should move the elevator servo from the left side of the frame to the right?
matthewcornell is offline        Reply With Quote
Old 12-25-2012, 07:04 PM   #253
j bomb
You can do it either way. I also changed the position of the elevator servo on mine for the same reasons as moving the rudder servo, less likely to be struck by a blade in a crash, and helps to balance the heli L to R since the rudder servo was moved as well.
John Barta
Michigan Whirlybirds Heli Club
http://www.michiganwhirlybirds.com
j bomb is offline        Reply With Quote
