| Belt CP E-Sky Belt CP |
#61 |
Yes and yes!
-Heli Yea! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Master of: the living room, stockTx, mechanical setup and, the obvious! Belt'ish CP MG90's,704A/S3114,CX head,HDX3550/Align 35G/HDX 500 SAH:-) HS-82MG's,G401B/BMS-631MG,HDX850/Align 60G,6s lipo /Hirobo Shuttle ZX .30 /Walkera 4#3B/Falcon40/Lama V3 DX6iThank you kind gents! :-) |
#62 |
BTW Kevlar Welcome to the forum!
That means there is no question that is stupid. The only stupid question is one that is never asked!
#63 |
Saweeeeet!!!!!!!!!!!!!!
by paddles are you talking about blades or.... So everything will work if i just switch the AR bracket around right?? |
#64 | |
flip the coptorx shaft upside down. Move the AR guide to the front and use sand paper or something to make the guide alittle wider and smooth. You will need main blades align paddles and for the tail some blades. Make sure to lock tite everything going into metal. Good luck and after you will see that it makes a huge difference...
EXI- New build.. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Belt CP- Rebuild Blade CX2- Blade MCX |
#65 |
Thanks for the warm welcome!
O and would it be worth it for me to do the dts mod? Considering I'm a noob at all this |
#66 |
Yep or use the swashplate you have. The paddles are the flybar paddles and YES I almost forgot(thanks for the reminder
#67 |
So correct me if I'm wrong but from what mtboy says i can use the CopterX main shaft or do i have to use the esky one
#68 |
You must either use a CopterX(that comes with it) or Align shaft upside down. The Belt's main shaft won't work. Conex got lucky and they sent him the wrong shafts.
#69 |
OH ok cool that will save me some money! So in you opinion should i do the DTS mod too?
#70 |
Thats up to you!
#71 |
I did the DTS while I was at it... Read DX6i topic.. It has alot of info I had to ask questions on while doing the head tail and DTS.. For my DTS I just bought some E325 servo trays and mounted those.. Didn't like the idea of cutting my frame..
#72 |
OK guys so I'm about to take the plunge and order my head and tail combo. So I'm getting the Head and Tail combo, align blades, align paddles and tail rotor blades. What else do i need or am i good to hit the pay button.
Esky Belt cp. Soon to be with CopterX Rotor Head & Metal Tail Rotor Set, Align Main rotor! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#73 |
I think your good to go... Thats what I got and now I'm hovering around.. Good luck and keep us updated..
#74 |
Push the button!
#75 |
YAAAAAAAAAAAAAAAAAAAAAAAAHHHHHHHOOOOOOOOO!!!!!!!!! !!! Will the flybar weights off the belt?
#76 |
Interesting question.... I didn't think to do that.. I dont have any weights on mine. Should I have them on?
#77 |
It dosen't really matter the weights provide more stability and less response. The Belt's weights will not fit. I use the CopterX carbon paddles which have weights built in but many here don't use weights at all which is fine and probably better!
#78 |
Sweet... thanks alot for being so fast..
#79 |
I f you are ordering Align flybars, make sure you get the 220mm ones, as they do manufacture shorter ones
These are fine: http://www.helidirect.com/product_in...oducts_id=1606 http://www.helidirect.com/product_in...oducts_id=4159 This is the shorter one at 200mm http://www.helidirect.com/product_in...oducts_id=2021 Mike
Happy Heli-days !!!!!!!! Skip To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. T-Rex 450Sport, T-Rex 600NSP, OS50, DS610s GY401/S9254, KO Propo PDS2364,KBDDs, Align 600Ds, MultiGov Pro DX7/AR7000, Phoenix +DX6i Blade mSR |
#80 |
Will these work??
http://www.ehirobo.com/shop/product_...e9b22228c11611
