Old 12-13-2008, 11:54 AM   #1
Finless
Team Taco VP
Default Show off your Protos - post your pics here
I thought I would start this like the other forums have for a sticky.
I didn't notice a lot of people sharing pics of their protos and setups in this forum?
So here goes!
Post your Protos pictures here!
I will post my pics soon.
Bob
"Don't Taco My Pack Dude!"
Old 12-13-2008, 06:01 PM   #2
trailblazer
Here´s my Protos, the original canopy was smashed in a very hard crash due to a rc failure
So i ordered a blank one and painted it in a very "basic" style. For better visibility i put on some white paint on the tailfin and landing gear.
trailblazer is offline        Reply With Quote
Old 12-13-2008, 08:48 PM   #3
JMoore12
Just got my kit yesterday so pretty basic at this point. I am going to do something on a blank with the Iwata after the holidays.
So finless you a fan of the Protos?
-J
JMoore12 is offline        Reply With Quote
Old 12-13-2008, 09:19 PM   #4
JustPlaneChris
Default Here's mine
I added some dayglo yellow to the canopy, but after flying it a few times I'm not sure I like how it presents itself in flight. I think I may try dayglo green instead of yellow (same pattern).
Trailblazer, I really like your white landing gear struts and fin!
-Chris
JustPlaneChris is offline        Reply With Quote
Old 12-13-2008, 09:48 PM   #5
DriveWRX
Here's mine. Sadly this canopy no longer exists...
MSH Prōtos ...A Better Way to Fly
MSH Prōtos Mini
Mikado Logo 600
Vergnügenstabi
DriveWRX is offline        Reply With Quote
Old 12-13-2008, 10:15 PM   #6
Big E
Trying to figure out how to attach a photo. If it works, here she is. Had a friend paint a blank fiberglass canopy. Working on chrome for the windshield but may end up going to a metallic silver.
TREX 450 scaled to Hughes 500D, GY 401
Mini Titan 325 scaled to Cobra, GY 401
TREX 600N, 8717's cyclic, OS .50H, GY 401
PROTOS 500, Scorpion 880kv, CC 80amp
Big E is offline        Reply With Quote
Old 12-14-2008, 03:48 PM   #7
wespen
In the works... will take a few snaps when im done.
Wesp
wespen is offline        Reply With Quote
Old 12-14-2008, 06:17 PM   #8
weasel53
Smile
Here is my PROTOS! Added a fiberglass canopy with home brew paint job. Visibility is great!
weasel53 is offline        Reply With Quote
Old 12-14-2008, 09:20 PM   #9
toddeichel
Full-sized photos attached. Pics are from an outing towards the end of the summer.
ID:	72488   Click image for larger version
ID:	72489   Click image for larger version
ID:	72490   Click image for larger version
toddeichel is offline        Reply With Quote
Old 12-15-2008, 07:18 AM   #10
ping
Flybarless baby!
ping is offline        Reply With Quote
Old 12-15-2008, 11:24 AM   #11
akshaw
Here is mine with my lousy paint job (no one will disagree ). Great visibility though.
ID:	72564   Click image for larger version
BEAM: jazz 40, scorpion-8, 3xHS65mg, gy401+9257
FBL Compass Atom: Stock motor, YGE80, 3x9650, 9254
akshaw is offline        Reply With Quote
Old 12-15-2008, 09:47 PM   #12
jetnc
A common theme seems to be "visibility". I have a hard time seeing my Protos also, but I've seen some good ideas here......
jetnc is offline        Reply With Quote
Old 12-15-2008, 10:36 PM   #13
JMoore12
Ping, I know I dont have to say this but that is a sweet setup. What Digital flybar are you running? Wish I had the patience to run my wires as clean as that. Someday maybe..
I might get a GAUI flybarless system for christmas and think about using it on the protos depending on how the maiden goes.
Old 12-16-2008, 04:00 AM   #14
Jetleaf
+1 That does look sweet. And I hate white landing struts. I guess I'm used to seeing the Align version with the light blue skid stops, which look like ass with white struts imo.
I put the "__" in lazy
Jetleaf is offline        Reply With Quote
Old 12-16-2008, 05:28 PM   #15
ping
It's a V-bar. It flies awesome super quite with the belt drive and no flybar.
Old 12-16-2008, 08:11 PM   #16
JMoore12
Make your own washout lock? Looks like a simple route. I was thinking of getting the Gaui flybarless system shortly depending on how the official maiden goes.
Old 12-16-2008, 08:36 PM   #17
ping
I did make my own washout block by simply adding a grub screw to the stock washout. I found it did not provide enough clearance for the extreme collective/cyclic required for 3D. For FF and sport flying it should be fine.
Their two 8mm swash drivers on the market that will provide more clearance the Gaui driver and the Mikado driver. Each are compatible but require the ball links on the swash plate to be swapped with the respective brand.
I'm also considering metal grips to eliminate any torsional flex in the grips at the ball link.
Old 12-16-2008, 09:38 PM   #18
JMoore12
Are you using the 10mm blade grips? Mind sharing a link? A bit off topic but ..
-J
Old 12-17-2008, 02:06 AM   #19
OICU812
Here are a few pics of mine that I owned. I was an early adopter and had some issues which caused its' death. I will revisit this heli in spring when the cf combo kit is available and give it another shot now that it seems the issues have been addressed. Good news is the canopy and fins actually survived, but not much else, lol.
ID:	72776   Click image for larger version
OICU812 is offline        Reply With Quote
Old 12-18-2008, 09:41 AM   #20
bapgood
Since the canopy is stock I'll just show my OCD wiring job.
bapgood is offline        Reply With Quote
