Old 01-04-2009, 11:51 AM   #1
Finless
Team Taco VP
Default Trex500 ESP Manual
By request here is the Trex500 ESP manual for download from Helifreak.
Special thanks to JaggedEdge for providing it!
Align Trex500 ESP manual zipped JPG format (4 Megs)
Bob
"Don't Taco My Pack Dude!"
Old 01-04-2009, 11:56 AM   #2
maxman55
Wow thanks good job.
Trex 600 NSP blue, align 610, Spartan Quark + 8900.
Logo 600se Jive 80hv, xera 4035/3y-400 ciclic savox-tail futaba bls251
maxman55 is offline        Reply With Quote
Old 01-04-2009, 03:15 PM   #3
bugdozer
Yeaa!!! Now I have some light reading.
bugdozer is offline        Reply With Quote
Old 01-04-2009, 07:16 PM   #4
Ecklund1
What timing. I just didged the "Buy Now" button on this version today. Then, noticed this thread. Thanks JaggedEdge/Bob!
Jeff
I do not have to be politically correct. I am not a politician.
K-50 / 500ESP /450SEv2 /H200SD / mCX / RF4.5 / 10C 2.4GHz
Ecklund1 is offline        Reply With Quote
Old 01-14-2009, 12:34 AM   #5
DesertClimber
Cool, I like having the digital version of these as well... Now I don't have to carry my manual with the heli when I go travellin...
Thanks, as always!
DesertClimber is offline        Reply With Quote
Old 01-17-2009, 08:06 AM   #6
RC-Bearings
Is this just the ARF version of the standard 500? Are there different bearings? I am trying to put together a bearing kit.
Paul McIntosh
Stainless, Ceramic and steel bearings
5% discount for the Freaks. Code: helifreak
RC-Bearings is offline        Reply With Quote
Old 01-17-2009, 08:31 AM   #7
bugdozer
Nothing is assembled on this one. Main bearings may be the same but with the torque-tube tail, it's quite different.
Old 01-17-2009, 09:39 AM   #8
RC-Bearings
Thanks for the quick reply. I was wondering because the manual shows a bunch of the head bearings as being installed at the factory.
Paul McIntosh
Old 01-17-2009, 08:04 PM   #9
bugdozer
Most of the bearings are in place but the screws are loose and nothing has Loctite. You have to pull most of it apart and reassemble.
Old 01-18-2009, 03:48 AM   #10
RC-Bearings
Thanks!
Paul McIntosh
Old 01-23-2009, 04:32 AM   #11
tourerjim
Nice one
DSX9, Phoenix Sims, Blade Nano, mCP X, 130x
Trex 250pro DCF, Mini Titan 325se 3G.
Trex 450v2pro 3GX, Trex 500EFL 3GX.
Trex 600NSP 3G FBL, Trex 700n 3GX.
tourerjim is offline        Reply With Quote
Old 01-24-2009, 10:52 PM   #12
Shervin
thank you for posting the manual....my heli says "EP" I assume it is the same...left my manual at work, but I'll get busy building ! thanx again.
Shervin is offline        Reply With Quote
Old 01-24-2009, 11:04 PM   #13
Shervin
darn !...my 500 Trex "CF" is belt driven (vs. shaft).....I 'll have to see if i can surf for another manual
Old 01-27-2009, 11:14 AM   #14
JaggedEdge
Trextuning.com has it here: http://www.trextuning.com/blog/?p=182
-TREX600NSP - TREX500ESP -
917540 -
1003 -
JaggedEdge is offline        Reply With Quote
Old 06-23-2009, 08:42 PM   #15
helijack
Correct me if I'm wrong, but, when I downloaded that manual, it said EP.....not ESP. I was under the impression that the ESP was the torque tube model, which is 10mm shorter than the other 500 models. So there must be a difference, in my opinion.
Just an observation.
T-Rex 450 SE V1, HS65MG, 9650, 325 CF, AR6100, 2200 FlightMax, 430XL/BL35X, GY401 ...SOLD
T-Rex 500ESP...SOLD
DX7...Still for sale
M.A.A.C. 78596
Ex President - Calgary RC Heli Club
helijack is offline        Reply With Quote
Old 06-23-2009, 09:58 PM   #16
JaggedEdge
The zipped pdf available in this thread is the ESP manual.
TT and belt model share the same boom.
917540 -
1003 -
Old 07-22-2009, 11:47 PM   #17
Jasmine2501
Location: In deep space, abandoned. Any crew? Negative.
Sweet
I'm upgrading my 500GF and wasn't sure the orientation of the metal bearing blocks. Thanks to this I don't have to post a thread! Yay
Jazzy's Flight Deck:
Jasmine2501 is offline        Reply With Quote
Old 01-08-2010, 06:16 PM   #18
jombo
this is the one i use , it has the belt version
http://www.trextuning.com/t500-manual.pdf
jombo is offline        Reply With Quote
Old 02-20-2010, 12:15 PM   #19
Steve Evans
Anybody know of the whereabouts of a KX017011 manual (new frames + 780 gyro + 520 tail servo)?
Cheers,
Steve
Steve Evans is offline        Reply With Quote
Old 03-03-2010, 07:02 AM   #20
Brutis
Brutis is offline        Reply With Quote
