Old 03-10-2010, 03:38 PM   #21
Tool38
Originally Posted by Steve Evans View Post
Anybody know of the whereabouts of a KX017011 manual (new frames + 780 gyro + 520 tail servo)?
Cheers,
Steve
Just found it for myself and remembered this thread.
http://video.align.com.tw/mpeg/manua...er%20Combo.pdf
DX7 - 500 ESP - 450 Sport - MCPX - 7HV
Tool38 is offline        Reply With Quote
Old 03-10-2010, 04:35 PM   #22
Steve Evans
The KX017011 I ordered came in a KX017008TA box which had me muttering unkind things about chinese purveyors of Align helicopters until I opened said box to find the gyro and tail servo inside. The box was sealed with Align tape so I have to conclude that's how it left the factory. The manual is that of the KX017008TA.
Steve
Trex 450SEv2/HS65-MGs cyclic/Spartan Quark/DS520 tail
Trex 450ProV2 DFC/CGY750 FBL/DS410s cyclic/DS520 tail
Trex 500ESP DFC/CGY750 FBL/YGE-120LV ESC/DS510s cyclic/DS650 tail
Futaba 8FG 2.4GHz
Steve Evans is offline        Reply With Quote
Old 05-05-2010, 08:02 AM   #23
wonko the sane
Hi there
Is there a different manual for the belt driven tail versions of the 500
wonko the sane is offline        Reply With Quote
Old 05-20-2010, 11:50 AM   #24
carlocivicsi
can anyone tell me the basics of parallel and series.
im new at this and i would love to save money not buying new batteries if i can mix them together. for example i bough a new trex 500 esp and i have 6 3s 11.1v 2200 mah and the trex requires 6s 22.2v and at least 2200mha. so what can i do with this batteries?? thanks.
carlocivicsi is offline        Reply With Quote
Old 05-20-2010, 01:03 PM   #25
lindell26
Here is a very good site that explains the differences between parallel and series. The site mostly focuses on charging, but obviously it works the same for discharging.
http://sites.google.com/site/tjinguy...erial-charging
http://sites.google.com/site/tjinguy...allel-charging
The short story:
Two 3S 2200mah batteries wired in parallel = one 3S 4400mah pack
Two 3S 2200mah batteries wired in series = one 6S 2200mah pack
-Lindell
T-Rex 500ESP - VBar
T-Rex 700E - VBar
lindell26 is offline        Reply With Quote
Old 09-18-2010, 12:32 PM   #26
inkfreak74x9
Ahh, I didnt Know Bob had a halarious side to him.
inkfreak74x9 is offline        Reply With Quote
Old 10-26-2010, 07:42 PM   #27
celm
when u guys first buy your new kits ,i guess you have to put a large part of it together.when you are doing your servo to swash rod links,are you making them to lenght that it says in the manual to start with.Or are you setting it to your preferance or to what ever it takes to make the swash level?
Trex 250 SE FBL SK720,CX450 Black Angel Airwolf FBL 3G, Trex 700E FBL V-Bar ,Logo 600 SE FBL V-bar, Logo 600/550 FBL V-bar,Logo 400 FBL V-Bar ,Goblin 500 V-Bar, Blade 130X , Blade MCPx
celm is offline        Reply With Quote
Old 10-29-2010, 12:27 AM   #28
Jasmine2501
Location: In deep space, abandoned. Any crew? Negative.
Start with the suggested length, then adjust them so that your swash is level, the mixing arms are all level, and there is zero pitch on the blades, with the servo arms centered. Make them however long they need to be to reach the servos. Usually the measurements for the upper links will be correct - try to match those exactly. This should cause all the mixing arms to be level with zero pitch on the blades, and it will determine the proper 'zero pitch swash height' ... follow me? Then you just make the servo links long enough to reach the centered servo arm.
Jazzy's Flight Deck:
Jasmine2501 is offline        Reply With Quote
Old 10-29-2010, 12:36 AM   #29
celm
thats what i did ,i went with the manual as a start. then tweeked everthing so it was all level,etc...
Old 11-01-2010, 08:15 PM   #30
JaggedEdge
I needed this manual yesterday.. Came on helifreak did a search and what do you know... Completely forgot I provided it. lol.
-TREX600NSP - TREX500ESP -
917540 -
1003 -
JaggedEdge is offline        Reply With Quote
Old 11-02-2010, 11:31 AM   #31
AndyBK
Thumbs up
Greetings from Russia, Bob!
And thanks for manual!
AndyBK is offline        Reply With Quote
Old 05-25-2011, 11:00 PM   #32
mitchellliu
GOOD JOB. THANK YOU VERY MUCH.
mitchellliu is offline        Reply With Quote
Old 10-09-2011, 08:26 PM   #33
blueindain1
THANKYOU!!
blueindain1 is offline        Reply With Quote
Old 04-27-2012, 04:42 PM   #34
nivaldin
Great!!
But my heli is the 3G torque tube version.
Anyone has this manual?
nivaldin is offline        Reply With Quote
Old 06-07-2012, 04:58 PM   #35
mlp3028
I have the Trex 500 ESP 3G with TT manual if that will help.
T-Rex 500 ESP 3G: AR7200BX / DX8 / Phoenix Sim / mCPx
mlp3028 is offline        Reply With Quote
Old 06-18-2012, 03:32 PM   #36
mhills51
I have the 500 efl pro manual if anyone needs it.
mhills51 is offline        Reply With Quote
