Old 01-04-2009, 09:35 PM   #1
RMJ22
Default What does CCPM stand for?
And what exactly does it mean? Thanks.
Gobby 500 Sport USA Ed. #55, Q 4120, BK5001HV cyclic, BK7005HV tail, HWing 100A ESC, 20T pinion, AR7200BX
Gobby 500, Quantum, BLS153 cyclic, MKS HBL980 tail, AR7200BX, Jive 80+HV, 21T pinion, DX8
IRC Vortex, Fatshark Attitude V2's
RMJ22 is offline        Reply With Quote
Old 01-04-2009, 09:39 PM   #2
The Steve-O
Cyclic Collective Pitch Mixing. It's what all the 450's I've heard of use. It takes 3 servos spaced usually 120 degrees apart to tilt the swash plate, left, right, back, forward and raise and lower it. I'm sure someone else has a more technical answer, but this is the jist of it.
Blade Cp, T-Rex 450 Se V2.75 (mikado head, beam swash and tail, 7200BX), Airwolf 450sa, Blade mCx, mCPx, mSR, Cx2, Swift, Havoc Heli
The Steve-O is offline        Reply With Quote
Old 01-04-2009, 09:42 PM   #3
gravydrive
http://en.wikipedia.org/wiki/Ccpm
The T-Rex 450X and 450XL HDE used mechanical mixing like the Raptor series helis; there is one elevator servo, one aileron servo and one pitch servo that all work independently. All the modern Rex kits are direct servo-to-swash CCPM.
gravydrive is online now        Reply With Quote
Old 01-04-2009, 09:56 PM   #4
RMJ22
This is helpful. Thanks!
Old 01-05-2009, 07:27 AM   #5
TomRex
= mechanical ccpm
=electronic ccpm
Anything using a swash plate is ccpm except in fixed pitch
How much past 200 mph do I need to go you ask?
TomRex is offline        Reply With Quote
Old 01-05-2009, 12:01 PM   #6
Pinecone
So technically we have mCCPM and eCCPM.
But common usage is CCPM = eCCPM.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote
Old 01-05-2009, 01:31 PM   #7
BarracudaHockey
Not quite. Anything that moves the swashplate up and down to increase or decrease collective pitch is a form of CCPM.
Not all models do that.
Andy
AMA 77227
Jacksonville FL
http://www.jaxrc.com
BarracudaHockey is offline        Reply With Quote
Old 01-05-2009, 10:31 PM   #8
goldslinger
The fact that the servos all work in unison to give us insane cyclic is the 'e' in ccpm.
T-REX 450SE V2
JAZZ 40-6-18, AR7000, NEU 1107H/2Y, 14 tooth Steel Pinion. Hi-Tech 65MG on Cyclic. DS3500G on Tail; SPARTAN 760 Gyro. BEAM E-4 Tail & Swash.
"The Beatings Will Continue Until Morale Improves."
goldslinger is offline        Reply With Quote
Old 01-06-2009, 03:58 AM   #9
markleyland
Crashing Costs Packets Monthly
"Sort your head out and fly with your heart"
Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc,
Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251
markleyland is offline        Reply With Quote
Old 01-07-2009, 07:14 AM   #10
TomRex
Andy:
How does the swash effect a fixed pitch heli? Does a fixed pitch have cyclic and collective?
Edit: This question is designed to make one think!
Old 01-07-2009, 10:17 AM   #11
goldslinger
Andy: .
The swash in a fixed pitch just tilts to angle the blades for forward, backward, side to side movement for the heli.
Rotor speed is the only thing making it go up and down in a fixed pitch; so it's less effecient.
CCPM has collective and the swash stays level and slides up and down level for up and down motion, adding pitch to both blades equally. Then all 3 work in unison for cyclic with one or more servo going down, and one going up, etc.
T-REX 450SE V2
