Old 05-16-2006, 03:15 PM   #21
gkoutsis
It's amazing how many people are looking for the videos on RR.
Everyday I stumble across two or three posts in all areas regarding these. We need to let them know where to find them.
gkoutsis is offline        Reply With Quote
Old 05-16-2006, 03:27 PM   #22
Finless
Team Taco VP
I know but every time somone posts where they are Mark deletes it!
All I can suggest is PM'ing the person that asks as he doesnt delete PMs.
That is what I have been doing when I jump over there to have a look see but that is like once a day and I miss the deleted posts.
Bob
Old 05-16-2006, 03:33 PM   #23
gkoutsis
hehehe so my post will be deleted then.... nice. I'll check in a few hours to see if its still there. Maybe he missed it.
Old 05-16-2006, 05:35 PM   #24
djparvin
Many thanks for these, have yet to embark on my SE build but I'm sure they'll be invaluable. :mrgreen:
Darren
T-Rex 450 SEv2, Sceadu 50 Evo, Raptor 50 Titan
www.camfc.co.uk
www.southernmodelairshow.com
djparvin is offline        Reply With Quote
Old 05-16-2006, 06:37 PM   #25
WillJames
Registered User
Tell them to search google for "Finless Bob" (without the quotes) and they will find this place. It is the number one search result.
If they search Yahoo it is result #5
William James
WillJames is offline        Reply With Quote
Old 05-19-2006, 12:05 PM   #26
rchover
"Gotta Fly Every Day"
Jeremy
www.HobbyQuarters.com
www.rchover.com
www.FpvExpert.com
rchover is offline        Reply With Quote
Old 05-19-2006, 04:55 PM   #27
rdlohr
p llim: willy under cover!!!!!!!!
Helifreak, the place to be!
Rush 750 w/VBAR,Logo 400SE, 600SE w/NEOs, TREX 450SE, 500, 600, Blade mCPX,130X, 180CFX, Nano QX, MiniProtos w/BD3SX
rdlohr is offline        Reply With Quote
Old 05-19-2006, 08:03 PM   #28
GimbalFan
Hey Bob
I'm sitting here on the edge of my recliner, watchin' baseball out of one eye and Finless Bob's SE build videos out of the other, sippin' a frosty beverage and building this SE.
Got a question:
I'm a big fan of grommets, eyelets and mounting plates on my Raptor. However, it looks like the Rex don't need no stinkin' grommets nor eyelets for these Airtronics 94091's. Correct?
PS -- It's a lot easier to install these servos with the upper frameset split. Since I was greasing bearings and re-loctiting screws anyway I'm putting the servos in before reassembly.
What say you about the grommets and eyelets, O' Ye of the Premium Build?
PPS -- Would it be better for HF members if questions like this were posted in the TRex forum?
op-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwo
GimbalFan is offline        Reply With Quote
Old 05-19-2006, 08:20 PM   #29
Finless
Team Taco VP
Originally Posted by GimbalFan
Hey Bob
Got a question:
Yep we dont use no stinking grommets.... BUT if you can use them and keep the servos from being able to move I would say go for it!
Bob
Old 05-19-2006, 08:24 PM   #30
Finless
Team Taco VP
I just looked a pic of one of those on the AT web site.... I think your going to have to use the stinking grommets as the holes in the tabs are large! I suppose using a washer or a large headed screw would work...... Bottom line whatever you do you dont want them to be able to wiggle or move....
Bob
Old 05-19-2006, 08:29 PM   #31
GimbalFan
I put the plastic 'nuts' on upside down, on the servo side of the mount, and the round raised portion of the plastic nut centers on the larger servo hole nicely and still permits a little movement before tightening for a bias up and forward.
Would you prefer questions like this to be posted in the TRex Forum?
Old 05-20-2006, 02:10 PM   #32
MrFixit
Default Securing pinion to motor shaft.
Hi Finless
I have almost finished building my 450xl and have found your videos extremely helpful in confirming some things I already had a good idea on and some things I didn't have a clue with.
I have a qestion, what is the best way to secure the pinion onto the motor shaft. I originaly screwed on a 13T pinion, which seemed fine but then read that 11T would probably be better, so I removed the 13T and put on the 11T and because there is less metal, as the pinion is a smaller diameter, I stripped the thread out. I have now stripped out 2 pinions and trying to be really careful when I do this.
Do you have any recommendations on this. I have thought about getting a steel pinion or glueing it to the shaft. Should I grind a flat on the shaft?
Your opinion would be much appreciated.
Keep up the good work.
MrFixit (Mick)
MrFixit is offline        Reply With Quote
Old 05-20-2006, 05:14 PM   #33
molegrips
Hi Bob
Also Hi to everyone else on this forum, I have just joined although I have visit the site many times and used Bob's videos for reference, Thanks for producing those, they have been invaluable as everyone else on here seems to back that up. your a star sir and I would have been in dire trouble without your help.
Regards
Mole
molegrips is offline        Reply With Quote
Old 05-21-2006, 04:00 AM   #34
BarnOwl
Default Re: Securing pinion to motor shaft.
I had exactly the same problem with the provided motorpinion in the HDX kit. Somehow the locking screw doesn't fit properly or the material of the pinion is weak and doesn't hold the force of the 450T motor. I had it coming off in flight! luckily I was hovering only 2 feet off the ground.
I ordered the 2.3mm Align pinion set ( nr. HZ020T) because i never had this problem with Align pinions. Also I think 11 T is better.
Jeroen -
Just fly it!
BarnOwl is offline        Reply With Quote
Old 05-21-2006, 04:48 AM   #35
MrFixit
Hi BarnOwl
Thanks for the info.
I have the new 430L motor with the silver ends, which has a 3.17mm shaft and because of the larger hole there is less meat for the thread. Do you know if anyone does a 11T steel pinion.
I even thought about soldering the pinion to the shaft but the heat may damage the bearing or windings in the motor, so I passed on that idea.
I haven't finished building it yet but feel that this could be a problem, as you said, you have had yours come loose in flight.
MrFixit (Mick)
Old 05-21-2006, 06:34 AM   #36
WayneBrown
I used a little red locktite to hold the pinion to the shaft, and blue locktite for the screw. You do not have to crank the grub screw down hard, just snug it and wait a few hours.
Removal will require a little heat, in the frames use a soldering iron, out of the frames you can use a torch.
WayneBrown is offline        Reply With Quote
Old 05-21-2006, 06:59 AM   #37
MrFixit
I have another set of Align pinions on their way and I will get some red loctite from my local car spares store.
Hopefully I will be third time lucky. Gone through 2 pinions and it's not been in the air yet. :?
Thanks for tip Wayne
MrFixit (Mick)
Old 05-21-2006, 10:59 AM   #38
Finless
Team Taco VP
MrFixit, what pinions are you using? Align pinions? I have never had a problem with those stripping or coming loose. Maybe you just got a bad batch?
Anyway do as Wayne says on th next go around.
Bob
Old 05-21-2006, 12:11 PM   #39
MrFixit
I'm using Align pinions, it's probably me being a bit too heavy handed but I will certainly try what Wayne has suggested when my new one arrives.
MrFixit (Mick)
Old 05-21-2006, 12:32 PM   #40
BarnOwl
Ok, I thought you were talking about the HDX outrunner motor, sorry, didn't read your post properly......
I use the Align 430 on my other heli and use it with the Align 11T pinion. I never had a problem with Align pinions (yet) and you can just order that pinion anywhere they sell Align parts. It should hold allright, because the Align pinions (the smaller ones) have a bigger bottom end were the grub screw sits.
Jeroen -
Just fly it!
