| Finless Bob's Helifreak Tech Room Finless Bob's Helifreak Tech Room - Tips and how-To Videos |
#41 |
Bob-- I built my rex from your vids about four weeks ago. A freind of mine bought one and I told him about how much help you were. When I tried to show him I thought I had lost them forever. Thank you so much for putting them back up.
Now my question- Do you think you could do one on how to properly tension the belt. I've read so many conflicting details on what is proper, and since "you da man" I was hoping you could help. Seeing is believing as the saying goes. One more question (now that I think about it) What do you recommend for the tightness of the main and tail blades. |
#42 |
I just realized the vids for the frame assembly and motor pinion aren't up yet (I hope "yet" is correct and not "gone")
The vid on how to properly seat the tail drive was invaluable for me. Thanks Bob ![]() |
#43 |
Team Taco VP
I think I can handle a quicky belt tension vid! Let me see what I can cook up
I will also see if I can find the pinion video as I do see it is missing. As for blade tightness. I like them pretty tight! But as a easy starting point have them tight enought so when you put the heli on its side they DO NOT fall on thier own. Bob
"Don't Taco My Pack Dude!" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#44 |
There,s a new pinion thread on rr(help cant get my pinion on), it may be of some help till the vid comes out.
#45 | |
Team Taco VP
Bob
#46 |
Hi, i want to download videos to save but takes to long.......... help
#47 |
Team Taco VP
Hmmm the download speed from Helifreak is pretty darn fast! just as fast as RR was in my opinion. Are you on a dial up connection? If so there is not much I can do to help it go any faster......
Bob
#48 |
yes im on dial up............. which video should i download first cause im startin build now on trex
#49 |
Team Taco VP
Get the frames put together per the instructions then do them in this order:
Installing Servos in a Trex SE (38 Megs) CCPM Setup Part 1 (58 Megs) CCPM Setup Part 2 (58 Megs) Pitch and Throttle Curves 101 (58 Megs) Trex Electronics placement and overview (28 Megs) If you need to learn to solder and need the ESC and battery available so you can power the servos for the ABOVE videos then do these before the above videos. Soldering Deans Connectors 101 (30 Megs) Soldering Bullet (Motor) Connectors 101 (50 Megs) Align ESC setup (30 Megs) Bob
#50 |
And order an SE Reverse Gyro Mount from me now so that you will have it when you are ready for it.
http://www.wavelandps.com/clearly/
Helifreak, the place to be! Rush 750,Logo 400SE 600SE, TREX 450SE, 500, 600, Blade mCPX,130X My products, flown by top pilots around the world, like you! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#51 | |
Team Taco VP
The gyro plate is worth it trust me! You will agree the first time you crash and take out s $120 401 gyro! Bob
#52 |
Got my Gyro plates today!!! Finally checked the PO BOX!! AWESOME, thank you Rick.
I would highly recommend these to anyone, and after loosing a 401 gyro this past weekend to bad placement, I can assure you they ARE worth the $$ many times over. Thanks again Rick!!
William James To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. If you fly you are going to crash. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#53 | |
#54 |
Team Taco VP
OK you guys asked for it... its up!
Blade Tracking 101........ Let me know what ya think Bob
#55 |
"It was suggested by a excellent contributor GimbalFan that I order my videos in a order that should be follow by a new person (n00b) with a new Trex. I liked the suggestion and now the videos are in order as they should be viewed." -- Finless Bob
Thanks, Bob. That comment wasn't necessary but it's appreciated. I'm new to this forum, one of MANY happier refugees who've recently come over from 'the dark side.' Best move I've ever made in RC. And what timing! Just as I'm building my first electric, a Rex SE, I find your help videos. This build went far better and easier than it would have without them. Like many have said here before, first drink's on me whenever we cross paths. Second, third and fourth, too. I'm guessing that you'll have a hard time paying for frosty cold beverages anywhere Rex's fly.
op-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwo |
#56 | |
Team Taco VP
Thanks I one day hope to take you up on the frosty bev! Bob
#57 |
Any luck locating the vid how to snap the HDE (and I guess the 450X) frame together? I have a friend putting his together this weekend and the part about the taill drive bearing fit really helped me. I won't be in town this weekend to help him and the videos are fantastic help. Hard to rewind a conversation
Sure wish I'd saved these the first time instead of just watching them. Hindsight always gets to you. Thanks again Bob. Don't do alcoholic stuff, but any time you need a Coke tell Eddienewyork to put it on my tab |
#58 |
FINLESS BOB'S...... thanks a million.
I have a Trex heli and I built it after flying on my reflex for a few months. I am progressing very well on the sim so I figured I would finally take the trex out. It was all I could do to keep this thing in a 20x20 area. It was all over the place. I went over the throttle and pitch curves, balancing, tracking, leveling and anything else I could think of. Everything seemed to be as the instructions stated. Sooooo. I took it to my LHS and had the heli guy go over it and fly it. He could fly it, so I figured it was just me. I went bcak home and tried it until I got so fustrated I was about to give it up. THEN along came FINLESS BOB and his videos. I watched them all and as I was watching them I was telling my self I done this, I done that, I checked that, Hey I never knew i had to do that, and this, and make sure this was like that. In other words I was way off from what the instructions told me to do. SOOO. I started over and rebuilt it PER BOB'S videos. Then I took it outside and hovered it. HOLY $HIT. It stayed in a area about 2 feet by 2 feet. I even got to hover it hands off for about 10 seconds after a few flights. BOB YOUR VIDEOS ARE AWESOME. THANKS A MILLION. |
#59 |
My support all the way. I joind runryder cuz of your vids, and you can bet I will not miss that site one bit and will keep up with you here.
Team Outrage OPM - Fly it like it aint yours! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. JR X9303 2.4 Baby. I have felt the difference and I like it! Don"t make me list 'm all ! |
#60 |
Team Taco VP
zooland1, yes..... I should have it up tomorrow!
bob
