| Finless Bob's Helifreak Tech Room Finless Bob's Helifreak Tech Room - Tips and how-To Videos |
#1021 | |||
What radio are you using ?
What batteries are you flying ? Most radios allow you to ignore some points in the curve by inhibiting them (usually shows as "INH" on the Tx). This simply tells the Tx to linearly interpolate between the other points. If you just want a straight line then no need to enter the intermediate values. So 0-inh-50-inh-100 is the same as 0-25-50-75-100. Quote:
Kenneth * MSH Protos Stock motor/15t/Align75/Align DS510/GL730+DS520/7s A123 2300 * TRex450CF/430L/12t/CC45/HS65mg/L2100T/KP 3s 2200 25C or 4S LiFe Previous rides: HX242, W5-4, TRex450(HDE), TRex450(SE), QJ-EP8v2, BCX2 ,Logo10, Hurricane550 SIM: Phoenix (previously also Reflex/XTR, ClearView, RF, FMS) |
#1022 | |
450XL, Align 420 motor, Align 25A ESC, GY240, HS55 servos all around, Flight Power Evolite 2500Mah. 450SE, Align 430XL motor, Align 35A ESC, GY 401, HS65 servos, 9650 tail servo, Flight Power Evolite 2500Mah. Both with Futaba 6EXHP remote. |
#1023 |
Since I can't seem to start a new thread, I'll ask my question here........if ya don't mind.
Bob.......is there any chance of you making a setup video using the DX6 and a T-Rex 450SA? Or any T-Rex 450 for that matter, as I don't see how they differ all that much. It's more the radio setup I'm interested in. Thanx for your time and dedication again, Bob. Your videos have been invaluable to me! Jack in Calgary |
#1024 |
Jack - You can start threads in many of the forums here on Helifreak, just not this one.
I think you might find this DX6/TRex450 setup guide very useful: http://www.digimemphoto.com/guides/backguide.htm
#1025 |
If those batteries are being properly maintained and cared for they should provide lots of power and not lead to bogging, especially with mild flying. Try the new curves and see if they help. You could also check the "throttle response" setting on your ESC, it should be medium or you could try fast.
#1026 | |
When you say "batteries properly maintained and cared for", what exactly do you mean? I do not run them lower than 10V, I let them cool down, I then charge them with Eflite Celectra charger at 2A combined with a Blinky on the balance plug of the battery. What else could I do?
#1027 | ||
I don't know anything about that charger or how good a job it does, the balance charger that came with my EFlite BCX2 is pretty lousy.If you can afford it, I would suggest you get an FMA CellPro4S and then you can be certain the battery is being properly charged and balanced.
#1028 | |
I did take off my training gear today and there is a huge difference, it now climbs up like a banshee! Was just affraid, but I haven't really crashed, so I guess i didn't really need the training wheels... My Celectra is OK and I was told that the Blinky was pretty adequate. EVERYBODY keeps recommending that FMA Cellpro! I will have to get me one or two of them soon! I will try not to get my batteries lower than 11V after any given flight. I had gotten them as low as 10.5V on quite a few occasions, will this have permanently damaged my bateries? ![]()
#1029 |
Hi is the older videos of 450 se build that shows the head ,flybar assembly still avalible to view , I am in the middle of building a se and on looking up finless bobs build videos noticed the se one has changed and don,t cover some of the previous sections i found useful to watch . thanks Iain.
#1030 |
Hi there, if I am building up a 450S CF can I still use the 450SE videos, is there much difference other than some parts being alloy?
Thanks! |
#1031 |
Team Taco VP
Yes, pretty much the same! Plastic instead of metal but all the parts dimensions are the same.
Bob
"Don't Taco My Pack Dude!" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#1032 |
Thanks so much Bob, your videos are a great help!
#1033 |
Iain - I don't recall the SE videos including the head construction phase since the head is preassembled. However the HDE build videos do show how to assemble the head from scratch. It is a plastic head but the process is much the same.
BF - Yes you can.
#1034 |
Bob!
Invaluable information for newbies as myself! I am using most all of your information setting up modifying and flying my esky honey bee king 2 heli on my optic 6 radio.My Trex project is collecting a little dust while I go thru the motions on a cheaper bird.I am having a ball with the bk2 learning the heli curve and am hooked on helis for life. I would gladly leave you a tip if I could find your tip jar. Sincerely |
#1035 |
Thank you so much Bob, your videos are a great help!
Now I am going back to make some changing on my "bird". Kind Regards |
#1036 |
Hi Bob,
Just a quick question, I have stripped down my bird and rebuilt it using your videos as I thought I might get a better flying bird by doing so, so far all is good and your videos are great! However I am having a problem with the heli not being balanced when I spool her up, I have taken the blades off and removed the tail and I still get a lot of movement with just the paddles on, I have measured and they are the exact same distance apart from eachother and I have removed the weights and I still get this, are there any areas I should give special attention to? Also I have got a really tight flybar, i can balance a pen on the end of one of the paddles and it isn't enough to weigh down the paddle, are there any spots I should check for that as well? Thanks so much for your help |
#1037 | ||
My HF Map location Join Date: Jul 2007
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Nankin Hobby Field Rep, Compass Support Team Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX Experience is something you obtain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
#1038 |
Hi, thanks for your response, well I took the main shaft out and it is slightly warped, if I roll it on the table I can see a slight bend in it, I assume its just a matter of replacing the old one?
I will take apart the head and check all of the things you suggested, thanks again |
#1039 |
Yes. Even a tiny bend in the main shaft will amplified by the high RPM of the shaft, causing vibration.
#1040 |
Well I was able to straighten up the slight bend in the main shaft, it is running a lot smoother now, I will order a new main shaft which should be here monday. Do resize the links is a ball resizer my only option?
