Old 02-23-2009, 10:13 AM   #1
10karer
Default SK360 Setup Files
Heli name (Trex 500)
Number of Blades and type (2 Radix 430 carbons)
Head Setup (Direct or Indirect)
Motor/Pinion
ESC
Setup Type (Scale, light Aero, 3D, Stick Banger)
What are your thoughts?
Dave
Lift off is optional landing is mandatory
10karer is offline        Reply With Quote
Old 02-23-2009, 10:15 AM   #2
Heli-RND
I fly indirect, mild 3D
- we ship worldwide free; SK 720, SK 360, DS 760, GyroBot .....mostly FBL only, the good products only
Heli-RND is offline        Reply With Quote
Old 02-25-2009, 02:13 AM   #3
jvthert
misunderstood the first post
Grtz, Jeroen < my name
jvthert is offline        Reply With Quote
Old 02-25-2009, 07:29 AM   #4
oldschool269
sk setup screen shots in link ..
http://www.helifreak.com/attachment....2&d=1227560531
trex 500 rtf 1.9 kgs
+- 15 deg collective pitch , +- 13 deg cyclic .
s9650 futaba servos with MKS 9660 MG's inside , servo speed .12ms at 5.1 volts
indirect head set-up , factory align parts pinned reversed washout .
scorpion Hk 3026 1000kv
ESC CC hV 45 Mk2 Set rpm GOV 2400 2500 2600
Batts 12s 1300ma outrage
12t pinion .
align 3k cf mainblades.
comments : mad as 3d , Main-Gear Shreading Power..
oldschool269 is offline        Reply With Quote
Old 02-25-2009, 08:07 AM   #5
jvthert
Old 02-25-2009, 08:20 AM   #6
WillJames
If somebody can send me a link to what to sticky, I will be happy to do it.
Thank you.
William James
If you fly you are going to crash.
WillJames is offline        Reply With Quote
Old 02-25-2009, 09:47 AM   #7
Heli-RND
Will, send me your email address and I will send my profile for you to handle, I am flying 9650 on cyclic, DS 760 and 9257 on tail and perfect piro
Old 02-25-2009, 01:43 PM   #8
jvthert
Torsion 430 blades @2750 Rpm
Neu 1706 1.5Y Motor 16T
S9650 Metal gears
Indirect linkages
Spartan +JR8900
When I've got my CG problems fixed it will be a 3d ship.
Old 03-01-2009, 01:49 AM   #9
Skint Eastwood
Trex 700E
Radix 710 blades
Kontroniks 30/12 Motor
Kontroniks Jive hv80
Helichris frame conversion
12s Flightpower eon 28 3750
Mikado style direct link
15 tooth pinion
Stock sk360 3d profile at the mo , open to suggestions
Early days for thoughts, but it sure has some power and this one is very light 4.36 Kilos all in with lipo.
trying different headspeeds but 1850 seems nice
Skint Eastwood is offline        Reply With Quote
Old 03-01-2009, 04:36 PM   #10
Heli-RND
Trex 450
Hitec 5065 mg
Hyperion HP-DS11-GCB
DS 760
Rotortech 325 carbon fiber blades
12 tooth pinion
Esky 006 motor (11 USD)
cheap Chinese pack
My profile
Old 03-01-2009, 05:49 PM   #11
oldschool269
how the heck you do that ?? the ones we have built were more like 5.5 kg's wow thats light !!
Jase
Old 03-03-2009, 08:41 AM   #12
10karer
Trex 500
Radix 430 carbons
Direct using Mikado Kit
Stock 500L/ 13 tooth
Stock 60A ESC
I use the stock setings for now and it is on rails, I only fly Lazy 8's right now . I love this thing
Old 03-06-2009, 09:38 AM   #13
Skint Eastwood
Jase
I dont know think i better check my scales, lol think they are ok! lipo is 12s 3750 weighs 1.1 kso quite light
Old 03-06-2009, 09:45 AM   #14
Skint Eastwood
rechecked against bags of flour, defo between 4.3 and 4.5 kilos
Old 03-08-2009, 04:09 PM   #15
raptorwoody
Trex 450 with JRDS287's on cyclic
Using Thunder Power 325's
13 degrees collective pitch and 8 degrees on cyclic pitch
Indirect head setup
Scorpion HK2221-8 with a 14t pinion
FlightPower 2500 3s
Was using 401 now with Spartan DS760
Align RCE-BL35X
Mild 3d
A little aggressive, locked in feel and tracks well. I know it wants to be thrown around vigorously.
raptorwoody is offline        Reply With Quote
Old 03-12-2009, 01:41 PM   #16
ViperX35
Question Blade 400
Hi,
Does any one have a setup.. for the Blade 400....
Every thing looks gr8 til i plugin the sevos.
They do not woork the way they chould.
Pls help!!!
An Apple a day... Keeps Bill Gates away!
T-Rex 600E - SK-360, 3G FBL head, DX7 T-Rex 450 Sport Super Combo - SK-720, 3G FBL head, DX7, T-Rex 250 Super Combo - DX7
Blade 400 - (RIP), Lama v. 4 - (RIP), Blade CX2 - (RIP), HoneyBee CP2 - (RIP), HoneyBee FP - (RIP), Kyosho Consept 46 - (RIP), Big Lama - (RIP)
ViperX35 is offline        Reply With Quote
Old 03-12-2009, 02:40 PM   #17
10karer
Viper
you set the servo movement and swash mix in the SK. Make sure you are in single servo collective in the TX, then set the servo direction in the SK software, next set the swash mix.
Old 03-14-2009, 05:44 AM   #18
oldschool269
Indirect head setup
AirThunder 2200 3s
Align RCE-BL35X
Mild 3d
whats your actual gains in flight ??
Old 03-14-2009, 05:48 AM   #19
oldschool269
OK trex 500 setup
update
trex 500 rtf 1.9 kgs NEUTRAL CG BALANCE
s9650 futaba servos with MKS 9660 MG's inside , servo speed .12ms at 5.8 volts
ESC CC hV 45 Mk2 fixed endpoint 100 75 100
12t pinion .
comments : high head speed req (3000+) , will do a pyro pitch pumps , gentle breeze
260 280
40 45
42 44
18 18
-6 0
base gains checked
hill scales dampening unchecked.
hillier decay 90
let me know what it flys like for you guys, for lower HS , up hillier gains a few clicks (both channels one click at a time ..)
i have played around these no alot , but keep coming back to them as being the most consistent to fly 3d with .
i flew it in a gale and its really twitchy , so will need some work on hillier gains ...on gale force days .
Old 03-15-2009, 11:29 PM   #20
raptorwoody
I have very good equal rolls between the elevator and aileron. Making good power and tracks really well in FF. I still have a little work to do on the pirouetting portion, but no complaints here!
I had my dampening gains down to 16 (elevator) and 13 (aileron) and Hiller Decay was at 100. Raising them up calmed the heli down so I could take down the expo in the radio.
Name:	Brian's SK360.jpg
