Old 04-11-2009, 02:32 PM   #21
teshreve
I'd like to try other's setup files. My setup is mostly default.
T-rex 600 ESP
8S 4200mah, Scorpion 4025, ~2200 HS
Spartan DS760 w/ 9256
Align 620s on cyclic
Using hacked up stock Align parts for flybarless setup. See this thread
No governor
It flies very nice, but has a bit of wiggle on hard collective changes.
Not sure what the heck to change.
Anyone have a dialed-in config for something similar to my setup?
teshreve is online now        Reply With Quote
Old 05-31-2009, 12:20 AM   #22
GenReaper
Trex700E
12S5000
Scorpion 4035-540
CC110 ESC 100 Flat throttle with 14 tooth pinion
Radix 690 blades
3DX Flybarless head
Spartan 760 Gyro with BLS251 on tail
InoLab 760MG servos on collective at .09 speed
2230 head speed
Actual build thread is located here http://www.helifreak.com/showthread.php?t=113403&page=7 and settings and graphs are on last page.
Flys realy good.
Trex 700E 12S Scorpion 4035-500 3DX SK360 Spartan 760 CC110
Trex 600E 10S Scorpion 4025-740 FBL SK360 Spartan 760 CC85
GenReaper is offline        Reply With Quote
Old 06-19-2009, 05:07 AM   #23
Somnambulus
I'm currently running my SK360 in my HDX500 with the head lowered about 12mm and HDX alloy grips. Just extended the pitch arms back near to center.
Scorpion hk1026 1000.
22T pinion.
140T main.
13T tail gear.
Head speed about 2400 in idleup.
Turnigy Plush 60A esc with switchmode bec.
Zippy Flightmax 4S 2650 lipos.
HS82s with 13mm arms.
Futaba 9257 + GY240.
Futaba 6ex 2.4 gig.
Trex500 skids.
+/- 10 deg pitch cyclic and collective.
30 Bell on pitch and roll.
50 Hiller on pitch, 44 and roll.
240 deg/sec pitch and roll.
Hiller decay 80
Pretty lively on 4S due to light weight but not really a 3d wizard's power setup. Good for up tempo sports and learning 3d. Compared to the stock clockwork head it's now super fast in pitch and roll.
Somnambulus is offline        Reply With Quote
Old 06-25-2009, 03:12 PM   #24
bpd964
Team Taco Member
Protos Carbon 500
Flybarless SK360
Scorpion 880
HDX500 CF Main Blades
KBDD Tail Blades
15T pinion.
Head speed about 2800 / 2900
Align 75a esc
FP EVO25 2500
Futaba 9650 with MKS metal gears
AR7000
Spartan Ds760 / 9257
CC BEC
=FUN
bpd964 is offline        Reply With Quote
Old 08-26-2009, 01:38 PM   #25
adamw88
Talking rave 450
rave 450
3S 2200
radix 325
3000 head rpm
Elevator__ Aileron__________ Use Base Gains Directly
_190 ______200
_40________50
_46________48____________ Hiller Decay 150%
_12________13
_-6_________0
adamw88 is offline        Reply With Quote
Old 03-05-2010, 06:44 PM   #26
Carman9876
ttt
Carman9876 is offline        Reply With Quote
Old 03-05-2010, 07:39 PM   #27
hurricane.br
Originally Posted by Carman9876 View Post
ttt
Why do you need to post ttt on a stick?
hurricane.br is offline        Reply With Quote
Old 03-07-2010, 11:47 PM   #28
wasabro
ttt
I have seen few "ttt" on this threads.What are the ttt those mean.I noob here.
wasabro is offline        Reply With Quote
Old 03-08-2010, 03:25 AM   #29
Skint Eastwood
I believe it stands for 'To The Top' meaning the poster wants the thread to go to the top of the list so more people see it
http://www.acronymfinder.com/TTT.html
Skint Eastwood is offline        Reply With Quote
Old 03-08-2010, 06:09 AM   #30
hurricane.br
And many consider that forum spam.
Old 04-18-2010, 04:53 AM   #31
hoffa
Trex 600E
Lightning Heli Penta bladed rotor head
550mm CF blades
Stock Align 75A ESC
6S 5000mah , Zippy and Turnigy
Z30 1110KV
11T pinion
~1400 headspeed
Futaba FASST
File Type: zip pentaTweak.zip (257 Bytes, 160 views)
hoffa is offline        Reply With Quote
