| Walkera Helicopters Walkera Helicopter Support |
My walkera prodicts seem to be ok but there is a main setback that i need help with. The gyro works through all ranges of adjustment, but when i turn the cyclic gain above 50% in the rudder adjustment, the gyro light turns on and then moves all the way to the extent of the servo control. It still functions, but it does not sit in center or react to the "range" setting. Please help... the gyro has "limit" and "gain" knobs, and two switches "invert" and "ds or nor". I know what these do, except for the difference between "ds" (digital servo) and "nor" (analog servo), and i dont know if it is the radio or the gyro taking over. I think after the radio gain is set above 50%, the gyro reaches its "coupling state, but i still dont understand why it would go to the extent to center its control. my gyro is set to analog servo..
:danceLast edited by ZAOAOAOZ; 02-24-2009 at 08:37 AM.. |
Heading hold normally can creep to one side (and its normal)... it will also not return itself to center while in heading hold mode....
That being said.. eish.. another walkera.... good luck chuck :-)
-Fade-Dude- Compass Atom 500E | Compass Knight 600E | Compass Odin 90 w Electric Brushless Fan *On its way* vanTo Technologies | Making IT Possible [link=hyperlink url]www.vanto.co.za[/link] |
Creep is normal in Heading Hold. How does it fly?
Velocity 50 FBL w/Beastx, T-rex 500ESP, 450 size scale UH-1N, T-Rex 450, mCPX BL, mCPX, Traxxas QR-1 micro quad, JR X9303, Realflight G3.5, AMA# 923167, Vice Prez Farragut Flyers |
Well i made a stand to setup all my helicopter needs, (posted here) and when i throttle it up the gain is just a little weak, I need about 65% on a typical scale, but after I hit 50% the helicopter goes wild and spins as fast as it can out of control. I dont know why this is set this way, youd think the gain should just be a 1- 100% typical gain adjustment, but no, somebody had to add just a little more technology and boom Im screwed. Gotta buy all the right stuff in pairs or it wont work. You know, there are two things I havent tried, 1. setting my gyro to digital servo, and removing the gyro altogether and see if it is the gyro taking over, or the controllers design to "couple to the gyro" after 50% gain. Im going to write walkera.
Team Taco VP
I moved this to the Walkera forum as I figured you would get a LOT more responses and help to your question in here rather than the main forum.
Bob
"Don't Taco My Pack Dude!" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#6 |
What heli and TX is it you have ZAOAOAOZ?
Blade 400, mSR, mCPX - Sonix SX450SE - Walkera 1#A, 4#3, 4#3A, 4#3B, 4G3 |
#7 |
I own a walkera wk-0701 radio, and all walkera electronics with an exi 450. Great helicopter... cheesy remote???
#8 |
I'm not familiar with either your TX, heli, or electronics, perhaps someone who is can advise.
I would guess that below 50% gain your gyro is in rate mode, and over 50% it is in HH mode. How does the tail behave when in rate mode? Ideally you want to start off by adjusting the position of the tail slider so that the tail holds as well as possible in rate mode with no rudder trim.
#9 |
Well, after understanding and downloading the instruction manual, I found that the gyro adjustment locks into "lock" mode where the gyro takes full control over the heli. I dont like that and understand not why they do that, but I guess even though they should have done this through a whole new setting or switch, they cheapened their product and said anything over 50% do something else. Im not a big fan of my radio, and I am upgrading to a more sophisticated heli radio. Thx for all replies.
EXI 450-- Walkera WK-0701 6CH PCM 72mhz w/ Gyro Blade MCX |
#10 | |
No matter what the gyro always has full control of the tail. Thats the way it is. ALWAYS. No matter what gyro. The "greater then 50% = lock mode" is normal for most gyros. This allows you to configure a spare channel on the tx/rx as a remote gain control so you can switch between 'Rate' and 'Heading Hold'. This is a feature that allows you to adjust the gyro while in flight. Think of it this way 0%=100% gain in rate mode. 25%=50% gain in rate mode 75%=50% gain in HH mode 100%=100% gain in HH mode And you can adjust this with a spare chan on your tx. |
