| Finless Bob's Helifreak Tech Room Finless Bob's Helifreak Tech Room - Tips and how-To Videos |
#1121 |
Just did a rebuild on my EXI 450 pro carbon by watching these videos. My only question is what is the stock esc size that comes with the super combo trex. My heli is having to be rebuilt due to the esc going out mid flip. But anywho thanks Bob and keep up the awesome work.
#1122 | |
Sent from my DROID3 using Tapatalk 2
"It's not the crash so much as the sudden stop" Alees Rush 750, Compass 7HV, Compass 6HV, TRex450Pro, Blade MCPX, bunch of other junk in boxes |
#1123 |
+1
Thanks bob! I "built" a trex 450 dfc over the last 2 days. I use quotes because theres still a bit of electrical work and 3gx programming to still do. Nccraig has been helping me a huge amount but your videos were a HUGE help to me. You are a gifted teacher and have been quite selfless in the time you have dedicated to sending these prof lessons over the web ether. Your karmic currency, if there is such a thing, should be very high. Kudos to you sir! Sent from my iPad using Tapatalk HD
mCPX with brushless by NCCRAIG, Nano CPx with brushless by NCCRAIG, Blade 450x, TREX 450 PRO DFC with microbeast and CC icelite 50 ESC |
#1124 |
bob my question is I bought the new trex 450 pro v2 super combo and the instructions show the elevator servo mounts on the outside of the bearing block.This must be a change from the 450 pro,am I right
#1125 |
It depends on the servo you are using. Mount it so that the ball on the servo arm is lined up with the elevator ball link on the swash. Get this geometry correct no matter what you have to do - try the ball on both sides of the arm, servo in both locations, etc. Try what the manual shows first, but if it doesn't line up straight, try it the other way. Same with the front servos.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Jazzy's Flight Deck: To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#1126 |
I need help in balancing the tail blade of my pro. The heli is absolutely vibe free until I install the blades, at which time she vibrates at high throttle.
Appreciate your help. |
#1127 |
If you are positive that the blades are balanced with respect to each other, check the length from the holes to the tips and make sure that's the same also. Also check your blade grips and make sure they are on tight. Don't tighten the tail blades all the way down, they should be allowed to flop a bit.
#1128 |
Great Video Helped alot with my first build!!!
#1129 |
Hello all,
These videos are fantastic. I'm building a 450 pro V2 clone from a VCTRC kit that I purchased on ebay. The manual says that the main gear should be 14T. The main gear that I got in the kit is 11T. The splines on this gear are twisted. I have a turnigy 2627-3800 motor that I bought for this heli. It comes with a 15T straight spline gear. Can I use this gear? The 11T gear that came with the kit is much larger than the shaft of the 2627-3800 motor, so I obviously that combination is not going to work. Any help would be greatly appreciated. Thanks |
#1130 |
What do I need to do in order to watch these vids on an IMac?... Don't have a PC in the house
#1131 |
Click on the link to the video. Click stream video.
If you want to save the video to your computer, right click on Download File and select Download Linked File As. |
#1132 |
#1133 |
Which OS are you using? I'm on Lion.
#1134 |
#1135 |
Its a new Imac running on Lion 10.7.5 ??? says unsupported file format? what doesn't play a .wmv file these days? oh wait...my mac thats what.
I'll give it a try. Thanks muchly fellow freak. |
#1136 |
Yes, the flip4mac free player is what I'm using.
#1137 | |
Superb videos. wOw
#1138 |
followed your vid on setting up with stock gyro and servo, but I have a gp780 and ds520 servo, it has be centered perfectly ( 0 sub trim needed) the hh mode moves in the correct direction when I push the tail and back again when I reverse when there is no power. when I power up the heli it's always in the centre, limits set just right and endpoints on tx.
trouble is as soon as I apply power to lift off it spins counterclockwise, the servo is moving the right direction to compensate but it's not enough had it in a jig and it is moving to the limit ok, this one is puzzling me??? ![]() |
#1139 | |
#1140 |
Finished watching all videos and I must have missed where the motor was installed. I built in sequence with the videos and servos are in way unless the motor mount is removed, then I'm not sure the 1mm spacing from gear to pinion will be there. Any advise...
