Old 04-21-2009, 04:03 PM   #1
lazsyss350
Default Biggest lipo in trex 500.
Can anyone tell me what is the biggest lipo i can put in the trex 500 without modifying anything, i have 3300 6s zippys comeing for mine but someone told me that battery is to big, can someone help me out.
lazsyss350 is online now        Reply With Quote
Old 04-21-2009, 04:45 PM   #2
Slyster
No it isn't too big at all... I love the 3300's... getting 8.5 minutes at 92% idle up
You DO need to do one of two options.
1- 5 minutes tray drop down.. involves drilling 4 holes. Very ez
2- Drill new canopy grommet holes 1/2" further back and a tad up... just as easy.. but not as good... as mod #1
It's not just a hobby... it's a lifestyle!
Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo
Pete Team Outrage.
Slyster is online now        Reply With Quote
Old 04-21-2009, 06:26 PM   #3
lazsyss350
How far down do i have to drop it, can you show me with a pic, i would really apreciate it, if you dont have a pic dont worry about it. i will figure it out.
Old 04-21-2009, 06:30 PM   #4
WillJames
Here is a pic of one that has the mod done to it.
HTH,
William James
If you fly you are going to crash.
WillJames is offline        Reply With Quote
Old 04-21-2009, 06:32 PM   #5
Slyster
I just did it all by hand.. didn't even measure. Probably about 1cm.. just below that strap gap I was using.. now I use the slow below it.
Pete Team Outrage.
Old 04-21-2009, 06:33 PM   #6
Slyster
I didn't do ANY cutting... just drilled 4 holes 1cm lower... but here are some threads with some pix.. but I think they did it a little differently... some other ideas for you.
Lipo mod
http://www.helifreak.com/showthread.php?t=115087
Another tray mod
http://www.helifreak.com/showthread.php?t=108787
Pete Team Outrage.
Old 04-21-2009, 07:21 PM   #7
erniefritz
you don't even need to drill 4 holes , just 2? see the original tray drop mod here:
drill the front 2 tray holes 10mm lower , the rear go in the large slot perfect fit. the 3300Zippy's fit perfectly in between the frames against the tray. even if your esc is under the tray , this mod can be done...
seems like every month , this subject comes up , this mod should just be put under a sticky for future refrence...
erniefritz is offline        Reply With Quote
Old 04-22-2009, 01:32 AM   #8
10inja
yes, the mod was very easy.. I did it and I'm a total noob.. I'm getting more than 10 minutes with the zippy-h 3300.. all thanks to Slyster's recommendation for this battery.. half the price of my TP Eon28 2550 mah and twice the flying time
10inja is offline        Reply With Quote
Old 04-22-2009, 08:28 AM   #9
0636
I have
Zippy Filghtmax 6s 3000 mAh 20C 462g and
Zippy Flightmax 6s 2650 mAh 30C 454g.
Both do balance/fit stock 500ESP perfectly without canopy/tray mode with ESC installed on a side of frame.
With average current of 24 Amps (mild 3D) they give about 6 and 5.30 minutes of fun respectively.
0636 is offline        Reply With Quote
Old 04-22-2009, 08:32 AM   #10
lazsyss350
What about CG, does it affect anything, what about when i use a smaller battery will that affect CG.
Old 04-22-2009, 11:27 AM   #11
Shef
Which balance adapter do I need for the Zippy Filghtmax 6s 3000 mAh if I'm hooking it up to a BC-6? Thanks
Former owner of T-Rex: 250, 450 V2, 500ESP V-Bar, 600ESP V-Bar, 700E 3G
T-Rex: 550 DFC
Shef is offline        Reply With Quote
Old 04-22-2009, 02:18 PM   #12
RyuuChi
The balance plug is the same one that is compatible with the astro-blinky without a thunder power adapter. It plugs right into my turnigy acucel 6 balance port. i know thats not a direct answer, but i hope it helps.
Thank god i have snowboarding to keep me occupied when its too cold to fly!
RyuuChi is offline        Reply With Quote
Old 04-22-2009, 03:30 PM   #13
10inja
Don't know what it's called either, I use the TP 610C balancer charger and I plug it into the "Chinese connector" as in the attached picture.
Old 04-22-2009, 03:31 PM   #14
Shef
Cool, I have that one. Thanks.
T-Rex: 550 DFC
Old 04-22-2009, 09:56 PM   #15
lazsyss350
HTH,
Looks like you shaved down to were the strap use to run through, hows CG and will the CG remain the same with smaller mAH lipos.
Old 04-23-2009, 09:32 PM   #16
hfenn
Default zippy 30C6S2650
Just finished mine and ran it for a minute under the porch light. Zippy 30C6S2650 no mods, fits without any room left, balances just a skosh towards the nose with HiTec 5245MG, GY401/Futaba9650, Spektrum AR6200, rtf weight 1880g.
hfenn is offline        Reply With Quote
Old 04-27-2009, 11:13 AM   #17
nitro-pro
Great work with the mod...will be doing that to my esp this eve., but no one ever said what the largest lipo is...the zippy's seem to take forever to get, is there anything else?
my build: stock TREX 500 ESP, GY 401, DX7
nitro-pro is offline        Reply With Quote
Old 04-27-2009, 11:40 AM   #18
cation3
6s 3300mAh Zippys on my 500 work fine:
I had previously modified the frames to fit Flight Power batteries. This is not necessary with this battery as it will fit between the frames (you can see the aft upper corner of the battery is between the frames). You will need to drop the tray down, though. Four drilled holes and you're done.
Two hover flights so far for battery break-in and problem solving - as the 500 has not flown in four months, but they balance fine so far. Canopy is a very tight fit, but its on there.
Damn these are huge batteries:
-Drew
cation3 is offline        Reply With Quote
Old 04-27-2009, 01:04 PM   #19
nitro-pro
cool, is hobby city still the only source for those? Not to keen about ordering from over seas..shipping must be nuts
Old 04-27-2009, 06:52 PM   #20
cation3
Yeah, Hobby City. Shipping was 30 bucks (EMS style = 3-5 days, but took about a week and a half). Yes, that is a lot, but I got these two batteries for $220-ish. That's $110 each, shipped. Compare that to some 6S 3000 / 3300 Outrage packs at $179 each and I couldn't care less about the cost of shipping.
I must say: "Z2" still has me concerned. "Z1" initial-balance-charged in 40 minutes. Z2 took almost 2 hours. Using an E-Station BC6, so they will take a while to charge as I'm limited to 2.5A. I guess time will tell if these are quality packs or not....
-Drew
