Go Back   HeliFreak > R/C Helicopter Support > Hirobo Nitro Helicopters > Hirobo Electric Helicopters
Hirobo Electric Helicopters Hirobo Lepton EX, Quark and other Electric Helicopters
Old 06-27-2006, 12:46 PM   #21
sparkz
Thanks Bob
Excellent videos. You've given me the push to go out and order my Lepton. Can I send you my bill too
Mark
sparkz is offline        Reply With Quote
Old 06-27-2006, 02:31 PM   #22
FrittsLogic
Bob, I've been building fast enough to catch up to your videos. I got all the way to step 33 before you posted your warnings. Having said that, I had little trouble installing my Hyperion 10 turn BECAUSE of three tips in your video. Even though my boom, belt, main gear, etc. were already installed, the tip about using the kitty corner mounting holes and the widest two holes on the Hyperion allowed fairly straightforward access to each with a simple Duratrax ball tip allen driver. I did remove the right side tail belt tensioning pulley as you suggested, very straightforward. You can then drop the pinion down after loosely tightening the two motor bolts. I came through the left side frame, at a 10 degree angle or so from the front with the 1.5mm allen for one grub screw on the pinion, then used a small flat blade screwdriver from the back (remember my tail servo is installed at this point) to hold the pinion up so that it's top is flush with the main gear, then tighten the pinion grub. Then locktight the second grub, install, then locktight the first. Then it was straightforward to set gear mesh and tighten, locktiting in sequence the two motor mount bolts. Then put tail pulley tensioner back. All done without disassembly (other than tail belt tensioner) in about 3 minutes. So if anyone got Bob's last warning too late, never fear, it can still be done.
Menehune Rotorworks, Inc.
FrittsLogic is offline        Reply With Quote
Old 06-27-2006, 05:11 PM   #23
Finless
Team Taco VP
Thanks FrittsLogic!
Good to hear it still can be done with the Hyperion motor.....
I will shoot more tonight and next up is servo install, then head and linkages.
Bob
Old 06-27-2006, 06:02 PM   #24
Finless
Team Taco VP
Just posted step 24. There is a tip about the screws holding the outer balls onto the swash plate that I think is important! They stick out the back side and can possibly pop a link.
Bob
Old 06-27-2006, 08:33 PM   #25
Finless
Team Taco VP
A few more steps posted.
Step 25 head linkages
Step 12 Cyclic servo installation
ENJOY!
Bob
Old 06-28-2006, 01:17 PM   #26
Gscott
Hey Bob,
Will you be doing a Lepton video on the CCPM setup and getting rid of interaction?
Gscott is offline        Reply With Quote
Old 06-28-2006, 04:48 PM   #27
Finless
Team Taco VP
Yep I sure will! I am going to try and get that out tonight.
Bob
Old 06-28-2006, 04:50 PM   #28
Finless
Team Taco VP
FYI, last night I posted steps 26,27, and 28 servo linkage setup.
Bob
Old 06-30-2006, 04:04 PM   #29
Gus
Finless,
Look at this link posted by Stuka in thehttp://www.helifreak.com/viewtopic.php?t=15123 (Lepton Thread).
http://www.runryder.com/helicopter/g...tor_access.jpg
May have to paste to a new page to see.
Sometimes we can't see the forest for the trees.
Gus...
Gus...
Aircraft: Heli: Synergy E5s (VX1n), Beam E4 se FBL (VX1e), T-Rex 250 Pro DFC (VX1e), Quads: Armattan CF-226 & CF-258, F1-F5, F1-F6, MX400s, QR LB (DSM2) (2), SK SlowHawk 2, Park Hawk 4, Carbon Falcon Wing. Xmitr: FrSky X9D Plus.
Gus is offline        Reply With Quote
Old 06-30-2006, 04:18 PM   #30
Finless
Team Taco VP
Yep I saw all that.... Great idea by Stuka!
But it still wont help much setting the pinion backlash unles you swing it down and do trial and error adjustment. But for sure it helps getting the motor screws started and snugged up then swing the plate up and adjust the backlash.
Bob
Old 06-30-2006, 05:42 PM   #31
Finless
Team Taco VP
OK, I just posted the last step of the Letpton video series.
I may do a canopuy trimming vid / tips and for sure will do a test flight vid.
I hope you all enjoy the series!
Bob
Old 07-06-2007, 10:46 AM   #32
John Heli
Thanks, Bob, for these amazing videos. I could use them pretty much for my 3dx500.
John Heli is offline        Reply With Quote
Old 10-17-2007, 11:24 PM   #33
Brian Tugela
Default videos
Please could somebody tell me were to find the lepton build videos as I am new to this
Brian Tugela is offline        Reply With Quote
Old 10-18-2007, 01:17 AM   #34
Finless
Team Taco VP
Right here
http://www.helifreak.com/showthread.php?t=13452
Bob
Old 12-02-2007, 08:41 AM   #35
lotus7
Hi admin
I am registered and logged on , but since yesterday I cannot download videos . Did anything change in the setup rules?
Lotus7
Compass 6HV FBL
Compass 600E FBL 12S
lotus7 is offline        Reply With Quote
Old 01-25-2008, 09:31 PM   #36
JohnLund
Great videos :thumbsup:
JohnLund is offline        Reply With Quote
Old 10-16-2008, 07:52 AM   #37
marluzkat
Hey Bob I just buried my Lepton and I am trying to repair it, but for some reason I get the fethering shaft off the blade grips? I can seem to locate your build vids for the Lepton? HELP!!!
marluzkat is offline        Reply With Quote
Old 10-21-2008, 11:53 AM   #38
cybinary
Default Bob's Build Videos
They are posted at the beginning of this thread, you can get there by following this link...
Currently Flying!
Logo 400 V-Bar: Hacker A40-12S, Jive80, 9650s, BSL241, 6s1p 3300 Lipo
Lepton EX Installed in Airwolf: Hacker A30-12XL, CC80, 3102s, 401/9257, 6s1p 3300 A123
Retired Helis - Blade CX, Blade CPP, TRex450SE,
cybinary is offline        Reply With Quote
