Old 02-11-2012, 10:19 PM   #181
Thalios
Your links are all messed up..
Lynx Heli Team Pilot
Prôtos CF, 130X and many others.
CarbonCore H6 650mm Wookong-M
All on DX18!
Thalios is online now        Reply With Quote
Old 02-12-2012, 04:38 PM   #182
rikef16
Fixed
SAB GOBLIN 630 - Scorpion HKIII 4035-560, 22t pulley, SAVOX 1258TG, MKS DS760, HW 120, VBARSILVERLINE 5.3
MSH Prôtos CF FBL Stretch
rikef16 is offline        Reply With Quote
Old 02-13-2012, 08:39 PM   #183
Thalios
Originally Posted by rikef16 View Post
Fixed
Wow, you have skills.....
All on DX18!
Old 02-15-2012, 06:21 PM   #184
rikef16
Thanks!
Old 02-20-2012, 05:37 PM   #185
rikef16
One more
Old 03-09-2012, 05:11 AM   #186
scoio
Default Winter times
Here is a vid shot few days ago, after the re build of my protos.
Watch it in full screen.
Chris
Logo 600 3D MiniV 5.3 Pro
SAB Goblin 500 MiniV 5.3 Pro
Rigid 480 6S Beast X
MCPX BLS
scoio is offline        Reply With Quote
Old 03-14-2012, 11:55 AM   #187
jsmith285
Default New to Heli's Got a Protos 500
Flies really good. Nick Maxwell help set it up.
jsmith285 is offline        Reply With Quote
Old 03-16-2012, 08:17 AM   #188
wbefield
Nice flying Joe!! Impressive
William
Alees Rush 700-Kosmik 160A + KDE 700XF-495
Synergy N5C & E5-600
Protos 500
wbefield is online now        Reply With Quote
Old 04-01-2012, 09:19 PM   #189
Dutch349311
Default hs?
My new Protos stretch!
Great machine!
nice flight , what headspeed are you gettin in idle up with stretch kit in this vid?
Dutch349311 is offline        Reply With Quote
Old 04-02-2012, 04:46 AM   #190
rikef16
Thanks! I'm getting 2700rpm with 14t pinion and 880kv scorpion motor.
Old 04-02-2012, 04:18 PM   #191
mic-21
just wonder if you use Governor ??
mic-21 is offline        Reply With Quote
Old 04-02-2012, 04:41 PM   #192
rikef16
Yes I do. Now im using Castle creations and I'm very happy with it!
Old 04-03-2012, 12:31 AM   #193
mic-21
did you get the warning from the ESC ...my set at 2600RPM and already had the minimum over head ( 2% )
Old 04-03-2012, 12:25 PM   #194
rikef16
I did, but just put 25volts in the voltage instead of choosing 6 cells.
Old 04-03-2012, 06:46 PM   #195
desertstalker
So basically, you have no governor at all, since the pack will not be at 25V ever under load, even if there is a little overhead left, it will all be gone pretty soon into the flight as the pack voltage drops into the ~3.8V loaded range. You might as well be in fixed endpoints at 100%.
-DX8
Old 04-03-2012, 07:21 PM   #196
rikef16
Your not wrong, but i'm not either. Castle's governer is a bit conservative, so their values are not "real" values. Don't forget the stretch version is rated at 2700rpm, if you run 100% throttle and you make a dive or a move that makes your headspeed rise too high you could have a blade ejection, so the governer helps you with that. And also I tried just using 100% throttle and makes alot of difference. I do this from experience, since I also did it with my 450 and had great results so I gave it a shot again, and just works for me. This is just my point of view, regarding my flying and me being confortable with it.
Old 04-03-2012, 07:23 PM   #197
mic-21
did you check the Data ? is the HS stay around 2700RPM all the way ??
I just finish setup the BeastX ...( upgrade to Low Head FBL + Stretch ) Parameter left at Default .I plan to test flight tomorrow ..very impress of your flying ..can you post your Parameter setting ..
thanks.
John.
Old 04-03-2012, 07:36 PM   #198
rikef16
Yeah I always check my data and record every flight. The HS will stay around 2700 throught the flight, but also that depends on your lipo's. I use Voltz 35C and they are great, so if you have a C rating above, will decay less towards the end. On my CC I have governer gain at 25, initial spool up at 8, speed change at 20, timing 5, PWM 12Khz. BeastX, first and third pot are stock and second is one point up, because I like it more responsive, but that is really your preference.
Old 04-04-2012, 03:32 AM   #199
mic-21
I"ll try your setting ,,but since this is the first time step into FBL world ..and I am trying to tune the Heli , I'll stay at 2600Rpm , My batt..are Voltz 35C too but only 2650Mah ( from my stock FB because upgrade ) .
about the BeastX Parameter ..can you post the rest ( are every steps at Default except Second Pot ??) ,,I tried a quick flight today and found out that I didn't feel connect to the heli .. I'll crank up Pot 2 next time ..
thanks
John
Old 04-04-2012, 12:24 PM   #200
rikef16
thanks
John
2600 is fine, but you can tam it down a lil bit just to have a feel for it, i personally run 2300 on normal mode when i want to fly smoother. I also have one voltz 2650, just make sure you mount it as foward as you can to have proper Cg, since flybarless is very sensitive to that. On my beastx i have control beavior set to transmitter, pitching up and tail to medium, stick deadband set to 1, tail precomp off, cyclic response high and pitch boost off. On my transmitter i have both aileron and elevator set to 5% expo and tail to 15%. Travel adjust is 115 to ail and elev and 100 to tail.
