| Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum |
This post will be used to list programming tips, suggestions, procedures and other useful information relating to programming the 14MZ (and FX-40).
Posts NOT adhering to the above description, will be DELETED. The TITLE of each post must summarize what it's about, e.g. "Programming the GV1". If you have questions, you see problems in a post that require correction or otherwise want to comment on a post in this thread, please either PM the original poster directly or open a SEPARATE topic and reference the post in question from there. DO NOT ADD REPLIES TO THIS THREAD! Tip away ... :mrgreen: |
Official 14MZ FAQ
Always consult the official 14MZ FAQ section from Futaba before asking for help. Many questions are already answered in their info. http://www.14mz.com/faq/faq-14mz.html |
eCCPM setup guide :: Working with the Swash Detail screen
Here's a very nice write-up by Ben Minor on setting up eCCPM on the 14MZ: http://www.helifreak.com/viewtopic.php?t=11836 Note: the above post used to be sticky, but cleared it to minimize the amount of sticky posts on this section of the forums. |
Programming in the Futaba GV-1 governor
Here's a nice page on setting up the GV1 by Eric Larson: http://www.ericlarsonrc.com/Heli/Equ.../FutabaGV1.htm And some additional posts here in HF about the subject: http://www.helifreak.com/viewtopic.php?t=6924 http://www.helifreak.com/viewtopic.php?t=9421 |
Team Taco Member
Programming with CSM Gyro's
If using the 14MZ with the R5014DPS G3 Reciever and a CSM Gyro that has the ability to switch from Normal to Head Lock(ICG400 in this case) it will not work or enter setup mode if the standard plug positions are used ie Gyro Gain - CH3. You have to use CH10, 11 or 12 This is acheived by pulling up the Linkages Screen and selecting Function. Then assign either CH10,11 or 12 to Gyro. The Gyro Gain and Mode change will then work as expected I have only confirmed this on an ICG400 This only applies if using the 14MZ with the R5014DPS G3 Reciever, all other recivers 1024PCM and PPM are as standard - Gyro Gain plugs into CH3 Also the mode selection is reversed with CSM Gyro's AVCS = Gyro Normal NOR = Gyro Head Lock/Smartlock
Mark Morley F1 60 Max (OS 61LX-H), Hirobo SDX (OS 55HZ-H, GY701), Trex 450SE + some planks |
#6 |
Reverse the channel on which you control the gyro, so it will function like other gyro's.
Goblin 630, Vibe 50, trex 500, 450, mcpx v2 and mcpx bl. All fbl of course...:-) |
