Old 05-05-2009, 04:26 AM   #1
rockjock3
Default Review - FMA's new Co-Pilot II
This is going to be a review of the new Co-Pilot II by FMA Direct. I am going to try and take you from receipt of the unit through basic install and into some flight recovery with it. I am an beginner/average heli flyer. I have been flying for about 1 year, but due to money and time limitations I have not progressed very well. I spend lots of time on the sim, but with limitations on money/time to get real flying in I am, like many, hesitant to try much beyond some basic flight and maneuvers.
Flight stabilization was interesting to me in the past, but cost prohibitive with units costing upwards of $500 and more. With the introduction of the Co-Pilot II, at under $200 for the basic model and $209 (as of this posting) for the full-blown all inclusive model, flight stabilization became very interesting again.
--T-Rex 450 V2 (mostly) 430XL - CC35, GY401 W/S9650, HS65MG, AR7000e, 325 Carbons
--T-Rex 500 all metal head, GY401 W/S9254, HS5245MG, AR7000, 425 carbons
-- DX7, Hyperion Duo, flight leader case
rockjock3 is offline        Reply With Quote
Old 05-05-2009, 04:49 AM   #2
rockjock3
Default Review -- Installation
My initial impression of this system is awesome. The components appear be well constructed and installation is very simple and straight-forward. I installed the unit on my T-rex 500 and it took approximately 2.5 hours from the time cut the box open until I programmed the unit for its initial flight.
One note, for my installation I required the use of a 6 inch extension for the horizontal sensor and a 3 inch extension for the vertical sensor.
I would have liked to be able to mount the horizontal sensor on the bottom of the boom for better protection, but it just rubs the pushrod. On a larger heli you should be able to mount it on the bottom if you wish.
So far, I am very impressed. I am ready for some test flights. Hopefully in the next few days out I will be able to get out to the field and get some shots and video for you all.
ID:	95505   Click image for larger version
ID:	95506   Click image for larger version
ID:	95507   Click image for larger version
ID:	95508   Click image for larger version
ID:	95510   Click image for larger version
ID:	95511   Click image for larger version
ID:	95512   Click image for larger version
ID:	95513   Click image for larger version
Old 05-05-2009, 08:30 AM   #3
JasonJ
Is it easier to set up than the first Co-pilot was? That was a big pain in the ass getting those infernal dip switches right and getting the thing to give the right commands. Pre-flight calibration wasn't too horrible, but I hope this new version has streamlined things better.
Velocity 50 FBL w/Beastx, T-rex 500ESP, 450 size scale UH-1N, T-Rex 450, mCPX BL, mCPX, Traxxas QR-1 micro quad, JR X9303, Realflight G3.5, AMA# 923167, Vice Prez Farragut Flyers
JasonJ is offline        Reply With Quote
Old 05-05-2009, 09:49 AM   #4
rockjock3
I cannot compare the two as this is the first Co-Pilot system I have had. I can say that it was VERY easy to program. The manual was very good at explaining everything I needed to know and the flow chart was very easy to follow. The initial programming only took me approx 15 minutes and that included just playing around time in the menus.
I can also say that their are no dip switches. Everything is done from the IRNet programmer.
Old 05-05-2009, 10:25 AM   #5
Navigator53
Thanks for taking the time to give your feedback on this, I'll be following your reviews as you post them.
Clean looking bird you have there, is that heat shrink on the AR7000 antennas? Hmmm..
Mel
When the people find that they can vote themselves money, that will herald the end of the republic.
~Benjamin Franklin ~
Navigator53 is offline        Reply With Quote
Old 05-05-2009, 10:34 AM   #6
rockjock3
Mel
Yes, shrink wrap. I will probably get some wire netting for the CP-II wires as well, but didn't have any and wanted to get the system installed.
Old 05-05-2009, 11:02 AM   #7
HELINHAWAII
Hey man, good to see the 500 is still up and running. I kinda miss that little bird... somedays. You should come check out the FBL T700N sometime. I'd like to check out your CP2 as well.
Jesse
T700N FBL - V-Bar w/ 3DX Head
T250 Super Pro - HS-5084MG Tail Servo
X9303
HELINHAWAII is offline        Reply With Quote
Old 05-05-2009, 01:11 PM   #8
rockjock3
Hey there. Yes, that will have to happen. I just got orders for Robins Georgia, but we don't leave till October.
Yea, still flying. Tooooo scared to try much that will get it hurt. Still hasn't hit the dirt (knock on wood).
Hey everybody, Helinhawaii created that "clean bird" to my 500 before I bought it from him. Great work huh?
Old 05-05-2009, 04:29 PM   #9
HELINHAWAII
Yeah... I'm transferring to Fort Campbell in August. Kinda looking forward to it... kinda not!
Jesse
X9303
Old 05-05-2009, 05:28 PM   #10
zAdventure
FYI...You may have seen this already. Here's a video on the setup:
zAdventure is offline        Reply With Quote
Old 05-05-2009, 05:50 PM   #11
Black Sparrow
rockjock3
Greetings. Im just gonna ask, how far apart are your main sensor and vertical sensor? Nice install...
Thunder Tiger Raptor 50 Titan, E-Flight Blade 400, E-sky Belt CP, E-sky Honey Bee King 2, Heli Max AXE CPv3, AH64 3ch Co-axial
"To EaCh HiS oWn"
Black Sparrow is offline        Reply With Quote
Old 05-05-2009, 07:44 PM   #12
mtnbike101
Default Main Sensor Placement
Thanks for posting this review; I'm very interested. I have a feeling this setup may end up on my Furion for safe measure during my learning process.
I don't know how crucial this is, but you may want to double check your measurements prior to flight.
The Main Sensor Module can be mounted anywhere on the aircraft, as long as the following requirements are met:
Should be at least 6 inches from other components (including the Vertical Sensor Module, IRNet Router, digital servos, vertical stabilizer, horizontal stabilizer and landing gear) and at
least 12 inches from engine and muffler.
It looks like the two sensors are pretty close to one another; you may want to move the Vertical Sensor Module closer to the body.
mtnbike101 is offline        Reply With Quote
Old 05-05-2009, 07:45 PM   #13
mtnbike101
Originally Posted by Black Sparrow View Post
rockjock3
Great minds....
Old 05-05-2009, 08:23 PM   #15
HELINHAWAII
Originally Posted by nightflyr View Post
here's my setup got about a dozen flights on it ..no problems to report so far...
DUDE! I think that's the most "stuff" I've ever seen stuffed into a 450 before.
Jesse
X9303
Old 05-05-2009, 08:25 PM   #16
aramsdell
Nightflyr, My turn... Those vertcial stabs on yur horiz. fin may have some blocking effect as the field of view of the sensors is quite wide and they overlap. About 120 d eg each sensor I believe.
Al
Swift .46 on 6S,Homebuilt Swift HELICAM on 5S,TREX 450 HDE (Mech mix),TREX 450 custom HDE to direct CCPM conversion helicam with stretch boom and 350's, Blade3D with custom frame and belt drive .
aramsdell is offline        Reply With Quote
Old 05-05-2009, 08:49 PM   #17
nightflyr
HH, if you think thats packed you should see my experimental....can barely fit a pair of needle nose inside the frames, but thats half the fun ain't it
nightflyr is online now        Reply With Quote
Old 05-05-2009, 08:57 PM   #18
nightflyr
Al, The verticals have not posed any problem so far with the CPII and I've been running the system every chance I can, she's been balanced and trimmed to the point of hands off hover for 15 seconds at 3 feet off the ground before I installed the CPII but good eye and if you look real close you'll notice the sensor is placed in such a position that the field of view being blocked is at an absolute minimum besides I wouldn't lose my verticals no matter what...keep my bird very stable in turns and reduces tail slide with less tail rotor input
Old 05-05-2009, 09:03 PM   #19
aramsdell
Looks great , flies great. Can't complain there.
Old 05-05-2009, 09:21 PM   #20
nightflyr
nope I can't ...the only trouble I seem to have is a side drift that I can't seem to trim out...after going thru all the material on the CPII i'm 98% sure it's due to my location, been testing it in my side yard and it can not get a clear view of the skyline i believe it's reacting to the houses and cars that are around the area, As soon as the weather clears up I'll take it to the fields and buzz it around and see if that improves it any
