| FMA/Revolectrix Product Support FMA/Revolectrix Factory Product Support |
#661 |
Thank you!
#662 |
I think Spider's out of business now, remember reading something about it...
Jerry Trex 700N Pro fbl, 600N Pro x 2, 450SE v1, 250 v2 fbl, Compass 6HV fbl, Blade 450x, 400, 300x, 130x, mCPx, 120SR, mQx, mSR, Rotor Concepts HPQ1, Walkera CB180Q, CB100, Novus FP, CP, Esky Hunter, Big Lama. |
#663 |
Hmmm That would be my luck....
#664 |
MSR, MCPX, 450s, 600, 650, 700, 800, 900, 1000 Assorted Mix Fixed Wing. AMA # 972083 |
#665 |
This question has probably been asked before, but I couldn't find it.
Will the Co pilot ll work on a Trex with the new DFC head if the Co pilot is used in place of the Align 3GX for stabilization, with a separate gyro for the tail? |
#666 |
The 3GX is the FBL controller and you need to wired to a separate Rx..
Rx>>>>>CPII>>>>>3GX>>>>>>servos
#667 |
Can't use CP2 in place of a FBL controller, they do different things. What Night means is you can use it with 3GX, but only if you go with a separate Rx, the signal flow being Rx --> CP2 --> 3GX --> servos
Good explanation about why you need both stabilization and FBL system, here: http://www.helifreak.com/showthread.php?t=440814&page=7 It refers to flymentor, but the same exact principle applies to CP2.
