| Phoenix Custom Creations Phoenix Flight Sim Custom Models and Fields |
#61 |
![]() I'm almost out of words Mike, but i just want to say: THANK YOU again. They are so wonderful. Greetings, Leen |
#62 |
Hi, here's some new schemes for the F16 and Eurofighter Typhoon EDF.
Enjoy! |
#63 |
Hey, other skins from Flying Elvis. Great man. These are great as well. Nice to see that you guys are still in the mood to make more and more skins. Great job everyone. Thanks
![]() Greetings, Leen |
#64 |
Hi, here's a link to some thrust vectoring F16's and Eurofighter Typhoon variants.
http://www.helifreak.com/showthread.php?t=53814&page=5 Cheers! ![]() |
#65 |
Hi,
Decided to attach my EDF sound, as I can't enjoy the EDF vids being posted with the default ducted fan sound........ fixedWing_EDF.pxe in c:\Program Files\PhoenixRC\resources\objects\aircraft\fixedWi ng\engines\ EDF.wav in c:\Program Files\PhoenixRC\resources\soundEffects\planes\ Select EDF as your engine sound in plane setup. Cheers! Last edited by puzom; 02-15-2010 at 06:41 AM.. |
#66 |
Very nice mate, anyone would think you like the F16......
#67 |
#68 |
Hi,
My two custom EDF favs in PhoenixRC at the moment. - Flight time set to 8 minutes. - EDF variant for scale models HawkTrainer (wingspan 900mm) and F-16 Turbine (wingspan 800mm) - EDF sound Regarding sound: fixedWing_EDF.pxe in c:\Program Files\PhoenixRC\resources\objects\aircraft\fixedWi ng\engines\ EDF.wav in c:\Program Files\PhoenixRC\resources\soundEffects\planes\ Select EDF as your engine sound in plane setup. Share your thoughts! Enjoy! Last edited by puzom; 02-15-2010 at 06:41 AM.. |
#69 |
Very nice work, I just wish we had a scale British Jet to work on, the Typhoon just wont cut it.
Regards: helicopterpilot@btinternet.com |
#70 |
Great work again Puzom, thank you very much.
#71 |
It's been a while since I did a plane scheme, was fun again.
One for the Scale Spitfire. Cheers! |
#72 |
One for the new P47.
Cheers! |
#73 |
Now why could they have not done that with the original now all we need is the ability to model the 3D models and we can start to make some real cool stuff.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#74 |
Now this thing looks the part, thanks puzom.
Mini Titan E325 SE, Trex 600LE, AURORA 2.4GHz AFHSS, Phoenix RC, Reflex XTR2. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#75 |
P-51 Mustang scheme Betty Lee III for y'all.
Enjoy |
#76 |
Here is a scheme I did for the ParkZone T28 in the Navy's colors. Let me know what you think, it's my first attempt.
Blade MCX-->Blade MSR-->Trex 450 Sport To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#77 |
One revived Max3D model scheme from PhoenixRC v1.
Cheers! |
#78 |
Hi,
Here's an Edge540 Air Race variant I like to use when doing some high speed flying. Variant file is read-only as it also has smoke option. If you remove the read-only the smoke will get deleted. Also included new sound based on some Katana vids. I think it sounds nice, specially when flying full throttle. Installation of the sound files: - PXE file into c:\Program Files\PhoenixRC\resources\objects\aircraft\fixedWi ng\engines\ - WAV files into c:\Program Files\PhoenixRC\resources\soundEffects\planes\ Installation of the variant file: - PXV file into My documents folder, eg when using Vista c:\Users\%USERNAME%\Documents\PhoenixRC\Variants\f ixedWing\ Run the sim and select the AirRace variant for the Edge540 model. Cheers! |
#79 |
Here's an Air Race scheme I created a while ago, based on one of Hannes Arch's schemes in Abu Dhabi.
with matching prop blur: Cheers! |
#80 |
Had a little bit of spare time today so did this Air Race one.
Edge 540 scheme based on the N540MD Zivko Edge 540 of Matthias Dolderer (http://www.flickr.com/photos/olaborda/3975796680/) Enjoy! |
| Tags |
| canopy, heli, phoenixr/c, skins |
