Old 07-06-2006, 03:47 PM   #1
ferro
Default trex 600 and glitches
hi all .
i fly a 450 se and i have glitches every now and then
im from the netherlands and the 600 is not on the market yet over here .
i really love my 450 but i really hate the glitches .
now the 600 is coming soon and it looks like a nice and thrilling package to me !![saw scabo doing stuff with it ]
my q is , is this machine glitch free ? and is it allready a good machine with all the small probs solved ?i am thinking of it , but over here i saw a package with a e raptor 50 with motor and jazz reg and 2 packs for 999 euro , wich is slightly cheaper than the 600 will be . flyin weight of raptor will be 3300 grams [advertised like this ]. what you think ?
three dee mp xl v91 , trex 450 , t12fg , three dee nt ---->r.i.p.
ferro is offline        Reply With Quote
Old 07-06-2006, 04:39 PM   #2
stevehonn
Any electric heli can suffer glitches depending upon how it is set up. The Trex's ESC comes with a ferrite ring on the lead to the receiver which helps plus it's much easier to keep a reasonable distance between the ESC & the receiver, a problem with the much smaller size to play with!
From reports so far I've only heard of one crash due to a lockout, mine's fine so far but I'm yet to venture very far away as I've only been able to do shake down hovers at a local field which is a little small, I'll be able to get to one of my main flying sites on Saturday. I am using a good quality JR PCM receiver (R900S) which gives a good range check and I'm flying a Swift with a similar setup without problems.
stevehonn is offline        Reply With Quote
Old 07-07-2006, 02:07 PM   #3
dennis@deetee
During 3D flight testing the other evening with our 600, and after 6 flights that same evening, both close in and very far out, and with a Deans Based Loaded antenna installed, we had no hint of glitches.
We are using the Futaba 149 PCM Rx driven by a Futaba 9C on ours. Russ McCutcheon of Ridgefield, Washington was the pilot.
.........Dennis
dennis@deetee is offline        Reply With Quote
Old 07-07-2006, 06:02 PM   #4
stevehonn
Where do you have the Deans mounted? I've got my Quick UK aerial fixed to the rear skid pointing backwards so its well clear of the electrics.
Old 07-07-2006, 06:07 PM   #5
dennis@deetee
Thats the exact same location as mine. Makes good sense. No probs.
.........Dennis
Old 07-07-2006, 06:08 PM   #6
stevehonn
Thanks for the reply, happier now
Steve H
Trex 600N Sport, 700N , Trex 250, Beam E4, Trex 550E, Raptor E550, Mikado Logo 500 3D, now a happy user of Futaba 10CG
