| Mikado Logo Helicopters Mikado Logo Helicopters Discussion |
#101 |
Yep -- I've had many of those same days and nights lately so as former president Billy would say "I feel your pain..." Yeah, just walk away at that point.
BTW, +1 on all points you mentioned about the CF frame. It's a little pricey, but you'll forget about the $ once you get it. I haven't seen a frame that's finished as nice as this one. I took some pics the day I got it and posted here: http://www.helifreak.com/showthread.php?t=270129 Also, be sure you see Big Fil's carbon fiber frame build thread here: http://www.helifreak.com/showthread....43#post2599943 Lots of good info in that thread. When you take the screws/bolts out just be sure to keep track of each one's location. You'll also have to take the tail belt drive pulley (wheels) from your other frame. Note that the documentation is pretty sparse too -- because it assumes that you know that you have to put together a 600. LOL! It's actually really easy though, especially after you go through Big Fil's thread.
Banshee #48 | Henseleit TDR | Minicopter Diabolo | Triabolo | Kasama Dune | Synergy E7 Mikado Logo 600SX | Logo 600 SE - Mikado Hughes 500 Scale Fuselage | Logo 800 XXtreme |
#102 |
ElectricSheep,
Again Thanks! I just read the whole thread from Big Fil. I gotta find out what the OD and Thickness of the counter bearing as I'm running a 5mm shaft in my Scorpion. I see it's a 5x15x5 from the manual you posted, that I need. Last edited by $teve; 05-23-2011 at 04:52 AM.. Reason: found it! |
#103 |
Well it turns out the 600se kit does not have a bag #12, However the 500se does, so I'm not going insane. Anyway RH was right on it, and bag #12 is in the mail. Thanks RH for the Great Customer Support!!!
#104 |
Looks like the carbon frame ships with both 20 and 25mm boom mounts now, got mine today.
Ordered another one and it only had the 25mm boom mounts? Might be old stock. Last edited by $teve; 05-31-2011 at 06:40 PM.. |
#105 |
I bought my Logo 600SE the other day and to my own understanding this one is Carbon fiber frame. But soon i opened it i have a plastic frame.
I thought it was Carbon Fiber since its stated on box LOGO 600 SE CARBON EDITION. Just wondering if the CF frame an upgrade only? or its comes with the kit?Anyway anyone could link me to some information between the Plastic Logo600SE vs CF Logo 600SE. Will check if what suited,for AP/AV.
Rave450 x Velocity50 x Logo600SE x ArducopterMulti.x Gaui 330X x Mikrokopter Hexa x MultiWii x XAirCraft X650V8 |
#106 |
Do you have a link from where you got it? All I've ever seen is that it's an upgrade. Never heard of a Carbon Edition, not saying there isn't one, but I've just never seen it.
#107 | |
Oh i bought it from a friend came from the states. My bad, i misunderstood the packaging. ![]() All is clear now. lols a common newbie mistake.
#108 |
Mikados are akin to Porsches; form follows function. Bling on a Porsche is in my opinion barbaric and crude.
Jorge | AMA #987294 Trex 700E BeastX v.3, Logo 600 3D, Trex 450 Sport FBL Microbeast TT upgrade, Trex 450 Sport, Trex 250 SE, Blade SR, Blade mSR, Walkera 4G6 FBL, Walkera 4G3 brushless The exuberance of flight is....intoxicating! |
#109 |
Is the tail issue still there - should I swap out the tail on a 500SE? I bought 86mm blades for some stupid reason - not sure whether to at least try them before buying 92mm . Think it will work?
#110 |
What size mains are you running?
Edge Rotorblades Thor/Voltz Batteries 450 Pro V-Bar 130X |
#111 |
#112 | |
#113 |
Thanks Chris, I'll stick the 95s on.
#114 |
Sorry if I missed it earlier but is the list on page 1 still accurate? I see that it was created a few years ago. I am thinking about getting a 600 so thanks so much for taking the time
S
Compass 7HV / AR7200BX / CC ICE2 80HV / Align 700MX / Edge 693FBL Trex 700 Pro / iKON / CC EDGE 120HV / Align 800MX / 3G 700's KDE Blinged Blade 130X |
#115 |
Hi guys
I'm planning to get a log 600sx and wonder what size the ball links are. E.g. what size Ball Link Pliers do I need. And while we are at it, what would be a good size circlips pliers? Thanks! |
#116 |
Hi guys,
I'm planning to get a 600sx myself and was wondering what size the ball links are? E.g. what size Ball Link Pliers should I get? And while we are at it, what size circlips pliers do you use for this heli? Thanks. |
#117 | |
Standard size links really, so any of decent quality or to your liking. The C-Clips on main shaft are 10mm spring, so base decision of set based on 10mm closed diameter.
#118 | |
