| Mikado Logo Helicopters Mikado Logo Helicopters Discussion |
#61 | |
I will have a look at it - certainly don't want to re-do "all" my wiring... ![]()
Mathias Mikado Logo 700 Xxtreme | JR XG8 & Spektrum DX8 |
#62 |
Fair enough. I came up with that solution when I first built my SE, so everything was tailored to suit.
Freya 90E, Logo 500SE, Logo 400SE, Lepton EX, Mini Protos - FX-30
#63 |
I will probably just go ahead order this pack, and solder on a Deans female connector. Then I will make a conversion, which consists of one Deans male connector, a piece of RX-wire, and a RX male connector, which plugs into the RX-lead that goes into the RX itself...
Also, I'm running Deans connectors on my 6S Logo 500. I've never had a issue with that, but I see a lot of people nowadays that are running bullet connectors. Should I change?
#64 | |
My friends Logo crashed twice because Deans disconnected in flight.
Regards perfeet - Mikado Logo 600SE (Vbar 5.0 and 12S) - Parkzone Habu (5S) - ArtTech Wing Dragon Sportser |
#65 | |
+1 EC5s are the shiznit for HV setups period, they lock in, awesome power throughput and overall the very best choice on 6S and up applications, for 6S and under the XT80s rock.
#66 |
+2 for EC5's! They are awesome
Edge Rotorblades Thor/Voltz Batteries 450 Pro V-Bar 130X |
#67 |
I have a lot of soldering coming...
Changing them on my Logo, I might just swap them on my 6S 450 Pro as well, don't you think?
#68 |
EC5's on a 450? Hell no, haha. Plus on 6S you'll be pulling only around 25-30A peak.
What plugs are you running right now?
#69 |
My HF Map location Join Date: Jul 2007
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
I've started the transition from Deans to EC5s by starting out with EC5s on the batteries I have for my upcoming Atom 6HV. My Atom 500 will be next so that I can easily share the 6HV packs with the 500. Then I'll probably convert my Logo 500.
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Nankin Hobby Field Rep, Compass Support Team Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX Experience is something you obtain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
#70 |
I would run EC3 on the 450.
#71 |
Currently running Deans on the 450. Reason asking is because then I will have the same connectors on all my equipment, making charging easy etc.
#72 |
Deans are fine, especially for a 6S 450. IMO EC5's on a 450 would be ridiculously big and unnecessary!
#73 |
XT80s on 450s are awesome!
#74 |
#75 |
yea those, goto sleep young man!
#76 |
It's later where you are, old man!!
#77 |
Ordered a set of e-Flite EC5s for my L500 last night.
As far as the 450, haven't ordered any XT60s yet, as the only place I can find them is at Hobbycity. Deans should work just as fine in this size, right? Also, I asked this question in the Static discharge thread... Is it necessary to ground my L500 V-Stabi, and what is the best and easiest way to do so? Currently servicing my equipment, so I have a few Qs...
#78 | |
http://www.readyheli.com/MIK4358-Mik...t_p_37134.html ![]()
#79 |
They're plenty good enough for a 450.
#80 |
Hobby City has EC3's for cheap. Awesome on a 450, they aren't the same as the larger birds but look identical if looks are a concern.
Conway V Scene From Above Photography To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Logo 600SE Cameraship, Logo 600SE, Compass 7HV |
