Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters
Compass Model Helicopters Compass Model Helicopter Discussion
Old 06-21-2009, 02:39 PM   #1
Dflyer
Default Governor sensor install pics please ?
Hi,
can any of you guys post some pics on how you have mountend the sensor for you governor ? I'm talking about sensors for Model Avionics or Align governors !
Thanks,
grtz,
Dirk
The heli virus has infected me and i hope that there is NO CURE !! Compass Support Team
__________________________________________________ _____
Warp 360 / 6HVU / CY Stingray / Invertix 400 / SH Little Spyder
Dflyer is offline        Reply With Quote
Old 06-21-2009, 05:29 PM   #2
TheBum
Is this on the new Knight 3D? I'd recommend buying a Spektrum backplate sensor and adapting it as needed to work with the governor. I know the Align governor will work with it after http://www.helifreak.com/showthread.php?t=100432.
HeliFreak Support
DT520Ev2 (VBar), Protos Max Evo 700 (Brain), Protos Max V2 770 (Brain2; under construction)
TheBum is online now        Reply With Quote
Old 06-21-2009, 05:54 PM   #3
Dflyer
Yep Alan,
it's for the new K3D, but allready have the Align governor laying around ! How does the Spektrum backplate sensor work ? Can it work in combination with the Align governor ?
Grtz,
Dirk
Old 06-22-2009, 12:11 AM   #4
TheBum
It senses the actual crank on the crankshaft through the backplate. All you have to do is unscrew two backplate bolts, run them through the sensor bracket, and then screw them back into the crankcase.
See the link embedded in my reply above.
HeliFreak Support
Old 06-22-2009, 01:44 PM   #5
Dflyer
Hi Alan,
sorry i missed the link in you first post. Thanks for the info, but i allready made something myself to fit the Align sensor, i'll post a pic later !
Grtz,
Dirk
Old 02-16-2010, 09:50 PM   #6
Bob O
Member
Originally Posted by TheBum View Post
SNIP
Bum,
I found this thread:
http://www.helifreak.com/showthread....60#post1484460
Is there a different one pertaining to this issue? I couldn't get a link to work in your other reply.
TIA!!
Bob O is offline        Reply With Quote
Old 03-17-2010, 02:40 AM   #7
helinewby
Default spectrum backplate
were can you buy the spectrum backplate. I have the atg and a revlock 20 so i dont really care wich one i use..
thanks C.B.
helinewby is offline        Reply With Quote
Old 03-17-2010, 09:06 AM   #8
TheBum
thanks C.B.
Just about anywhere. Just do a search for "spektrum sensor" on your favorite hobby shop website. Here's the page for ReadyHeli:
http://www.readyheli.com/Spektrum_Re..._p/spm6823.htm
If you want a better quality sensor than the one Spektrum makes, check out AlumaFX's sensor. It has all CNC brackets, whereas the Spektrum sensor is all plastic.
http://www.alumafx.com/
HeliFreak Support
Old 03-17-2010, 12:26 PM   #9
skunkworx
Thanks a lot Bum (you jerk!). As if I didn't have enough crap to go spending money on, you point out one more!!! Bah!!!!
I second the notion of doing the alumafx sensor. The spektrum has a metal bracket upgrade, but I'm not too sure how much it is and where to get it from. They all do it much the same, so I wouldn't worry about a difference in reliability.
Tim
KBDD TEAM PILOT
--Si vis pacem, para bellum--
skunkworx is offline        Reply With Quote
Old 03-17-2010, 01:56 PM   #10
TheBum
I started out with the Spektrum, but I switched over to the AlumaFX after the plastic piece attached directly to the sensor broke right through the middle of the "50" hole during a crash, making it impossible to clamp the sensor to the bracket that attaches to the backplate bolts.
HeliFreak Support
