Belt CP E-Sky Belt CP
Old 07-18-2009, 11:06 PM   #1
slotdr
Default Tower Pro Servo Wire Colors
Hi all, just received my new Tower Pro servos (Brown,Orange,Yellow) and was wondering when plugging them into my RX is the Brown wire at the plug the same as the black wire on the Esky servos (Black,Red,White)
slotdr is offline        Reply With Quote
Old 07-18-2009, 11:21 PM   #2
another_finn
Yes, and the wire order is the same.
Brown = Black = Ground
Orange = Red = Positive
Yellow = White = Signal
Mika
T-Rex 600NP, T-Rex 500 ESP, HDX500 SE V2, HDX450 SE V3, T-Rex/Outrage SE V2, EXI450, T-Rex 250, CopterX/Guru-Z hybrid, HBFP separates, Lama V4, 2 x Walkera 4#3B
another_finn is offline        Reply With Quote
Old 07-18-2009, 11:26 PM   #3
kanexx2
Tower Pro SG90 = Yellow, orange, brown
Esky servo = white, red, black
I use SG90s for cyclic, and an Esky servo for the tail rotor. In my RX, with the plugs plugged in, these are the colors left to right. Hope this helps some.
Kane
EXI Frame, Trex 450SE V2 head, 450HDX/3200kV,
Dynam ESC, Trex flybar, Trex paddles, Trex/EXI canopies, Align 325 Pros, SG90 cyclic, Esky tail servo, Flightmax and Rhino LiPos, Tech 450 metal V/H fins, 13T Rhino pinion, CNC tail, Trex 450 tail rotors, EK2-0704B HH gyro, DX6i and AR6200.
kanexx2 is offline        Reply With Quote
Old 07-19-2009, 12:11 AM   #4
slotdr
I am using the Specktrum-AR6100-EndPins , do I need to reverse anything in my Specktrum Dx6i
Old 07-19-2009, 07:30 AM   #5
another_finn
No, SG90s work in the same direction as your original Esky servos.
Of course you always have to check with the motor disconnected before attempting to fly. There's always the chance you might have plugged something in the wrong connector.
Oh, and obviously you'll be setting your subtrims again for the new servos, so remember to reset them to zero before you put the servo arms on. Might find a better spline that way.
Mika
