| JS TZ-V2 Frenzy JS Models TZ-V2 Frenzy Helicopters Discussion |
#21 |
hey doe anyone have the raptor fan shroud, is it close to the frenzys shroud, or can it be used twith some mod to the frame, for a better fit, i have the raptor clutch bell and clutch in my frenzy. i have the tt53 with a os 50 hyper carb modded on it,and i kept breaking the frenzy clutch(one hot start )because the frenzy clutch is made from soft metal,not like the raptors.i have been trying to find a torque tube setup that i can mod to fit the frenzy. i had the velocity front gear, the bevel gear mounted on the top of the belt drive unit and i put the velocity tt boom setup on my frenzy but it made the tail to short,i would have to find a longer torque tube and mod it .like cutting down a 90 torque tube to fit. i will find some way to have a tt setup on my frenzy, im sick of the tail boom sliding in and having a loose belt.im going to try the 90 metal tail boom brackets and see how they fit.
JS TZ Frenzy V2 , TT53 w/os50carb w/MP5 , hyperion digital servos all around, jr 7703d , CTG, SPECTRUM 7000, DX7 SE. MAH 600 CARBONS and a carbsmart(soon to get a multigov proand a ar7100R) i might get a fury 55, or i really like the velocity 50 its nice |
#22 |
have you tried balancing your hub and fan?
#23 |
yea i dial indicated them, the plastic fan on the stock fan mount is crap, it comes loose from the metal and then you either have to get a new one or deal with wobble.i got a new one and got it turned to hit the high spots now it is a problem of the past.
#24 | |
TZ V2 3D Frenzy To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#25 |
hi!user23, did you maded new holes on the engine mount too?can you explain a little better cause my english is awful and i still can't understand what you did on your frenzy
#26 |
Besides modding the frame for the Raptor fan, there must be another fan. The runout on my fan is 5 thou, vibrates too much. Anyone know?
Gaui NX4 Trex 450 eFlite Mcpx BL V Bar Pro |
#27 |
anybody took a closer look at the vibe 50?
