View Poll Results: Did you find this thread helpful?
Very Helpful 7 46.67%
Helpful 4 26.67%
Not so helpful 2 13.33%
No comment 2 13.33%
Voters: 15. You may not vote on this poll
Old 12-18-2009, 06:06 PM   #41
motomanmel
Originally Posted by terrabit View Post
I too have a slight staining at the top of the piston in my 91hz with cool power after 3 gallons.
Hmmm.
Yes it seems like CoolPower changed something in there blend. Last year i never had any stains, this year I have stains in all my engines 90 size 60's
Live, Sleep, Breath Helis... It is a Disease....
motomanmel is offline        Reply With Quote
Old 12-26-2009, 08:54 PM   #42
kazager
Are these engines anodized (Crank Case/Cylinder/Head)? Would you guys consider custom color anodizing for a fee?
kazager is offline        Reply With Quote
Old 01-03-2010, 02:05 PM   #43
Geek
Hi
Any news about when they will be coming to the UK
I can't wait
Sound like the power is awesome.
some of the pitches people are using
my poor old os 50 can't pull 11 deg's
Happy new year Paul
Geek is offline        Reply With Quote
Old 01-04-2010, 11:33 AM   #44
motomanmel
We were thinking to do a Limited Addition with some Anodizing. Let me ask everyone, where and what color wold you like to see.
Old 01-04-2010, 11:54 AM   #45
kazager
If you would do a one-off, I'd like to see THE WHOLE THING ORANGE. I'd also consider Black. I think coloring only the head would be a waste since it's shrouded and you can't see it.
Old 01-09-2010, 12:09 AM   #46
kmcevoy
Default KME
Hi KME owners, I have a KME in my 600 and was wondering, do I treat it exactly the same as a hyper 50 as far as tuning goes, for example - start at 1 1/2 turns out and lean to 1 3/4 if it suits, I had no manual with the motor.
kmcevoy is offline        Reply With Quote
Old 01-09-2010, 09:16 AM   #47
motomanmel
Yes I would start the Needle at 1 1/2 turns out no less it need to be a little more open that the Hyper 50 because it is a bigger motor.
1 1/2 to 1 1/4 is what the optimum running range for the fuel delivery depending on where you live. you can go as rich as 1 3/4 but no more.
Run your engine temp at 180 deg to 195
Break in the motor as to specs at the web site.
http://www.kmeengines.com/Support.php
Hope this helps
We hope to get the Manual up on the site soon
Old 01-10-2010, 06:48 PM   #48
double0757
Default Stalling engine
Hi Jerome, I've been having trouble lately with the transition from idle to half throttle. It idles fine and it start accelerating fine then it stalls, I either close the idle needle all the way and try again, or open the needle a hair if it was close all the way. Do you, or anybody, know what may be going on. I was thinking of changing the carb and see what happens?
Double O
Trex 600N KME Diamond 60 engine w/ Hattori (18, for 90eng.) muffler, jr8717, Spartan 760/Futaba9256, 610mm Rotortech, AR7100r 8v.
Logo 600 FBL w Pro-Bar & Spartan 760 on tail, Scorpion on 10S and Jazz ESC(big)
JRX9303 TX.
double0757 is offline        Reply With Quote
Old 01-11-2010, 05:24 PM   #49
double0757
I changed the glow plug and that seems to make it better, it does not stall now, but it hesitate when going from fast idle to half throttle. Could a hotter glow plug help?
Florida sea level, 45 F cold, fuel is, Byron 30% rotor rage (good fuel). Double O
JRX9303 TX.
Old 01-12-2010, 03:38 PM   #50
motomanmel
you might have some small particles of dust or sand in the Carb. Try pulling the needles and blow some gas through them. It might be easier if you take the carb off but if your careful you can do it when on the heli...
Old 04-18-2010, 05:39 PM   #51
HeliTool
I was out flying today and I herd that KME dropped the price of the Diamond .60 Pro. to $299
Im trying to find out if this is true has anyone else herd this?
Let me know.
HeliTool is offline        Reply With Quote
Old 04-18-2010, 08:54 PM   #52
fastflyer20
All of the dealers are at $349-$359, unless the sites have not been updated yet.
fastflyer20 is offline        Reply With Quote
Old 04-19-2010, 05:14 AM   #53
motomanmel
Let me know.
Yes Its true. I have no Idea how you guys found out so Quickly we just released this info to our dealers.
We now make our own CNC billet Carb for the Diamond .60 and we don't have to buy a carb from OS. So we are turing on the savings on to our customers.
Old 05-11-2010, 05:59 PM   #54
Inman20k
Any pics of the new pipe yet I am looking at getting my first nitro heli and would like to get a KME motor and pipe combo. Love to have a sneak peek and a estimated price.
Inman20k is offline        Reply With Quote
Old 05-12-2010, 10:06 AM   #55
motomanmel
I will put one up on Monday, along with the new carb.
Old 05-12-2010, 09:21 PM   #56
ccnada
Default LOoOk what I got fellas!
Here are a few pic's of what I received in the mail today. So pretty!!! I'm hoping to have this new carb installed and tested this Sat!
Thanks Jerome!
ID:	156536   Click image for larger version
ID:	156537   Click image for larger version
X5, DX7se
My son Enzo's - X5, mcpxBL, DX7se
ccnada is offline        Reply With Quote
Old 05-13-2010, 01:56 AM   #57
motomanmel
We just updated the website for the KME Billet carb set up. Check out the Setup Page if you guys need help.
Old 05-16-2010, 01:32 AM   #58
visionplay
Can anyone advise if they have a backplate sensor working with a gov off this motor?
John
Logo 600, Vbar, Jive 80HV, Pyro 700, BLS.
Synergy N5, OS55, Vbar
Mini Protos FBL, Vbar, YGE, 3S TP 65c's.
visionplay is offline        Reply With Quote
Old 05-16-2010, 10:58 AM   #59
motomanmel
We set up all of our engines this way should work fine. Try backing of the sensor a little with a washer, but it might be to close or to far.
Old 05-16-2010, 05:46 PM   #60
visionplay
Sweet, Thanks!
John
