Go Back   HeliFreak > R/C Helicopter Support > Hirobo Nitro Helicopters > Hirobo Electric Helicopters
Hirobo Electric Helicopters Hirobo Lepton EX, Quark and other Electric Helicopters
Old 09-04-2006, 05:59 PM   #21
Dr.3D
Hi Kovi,
same for me. One 19T Pinion and one derlin main gear....
how much?
Andrea
Dr.3D is offline        Reply With Quote
Old 09-05-2006, 06:18 AM   #22
gtrick90
Hi Kovi,
One 19T Pinion and one derlin main gear for me (shipping to Italy)
Luca
gtrick90 is offline        Reply With Quote
Old 09-05-2006, 09:53 AM   #23
poerqwa
Hi Kovi,
Count me in for a main gear and pinion (if you have a 20 tooth version, than that one too ).
Shipping to budapest(One of our offices is based in Budapest)
Just let me know the costs.
Thanks,
Marc
***** If it FLIES it WILL CRA$H *****
T18MZ, JR Sylphide E12 & 90, JR Airskipper 50 FBL, Hirobo Sceadu EX 50, Hirobo Lepton EX
poerqwa is offline        Reply With Quote
Old 09-07-2006, 03:06 PM   #24
Kövi
Default Pinoin
The reason of the many request I have started the gears productions.
They will be avaible on next week Wednesday ( 19T, 20T and 94T ).
I also make 20T pinions and the carbon parts like ESC holder and fins.
From 14th September I will be able to receive money via Paypal.
Istvan
Kövi
Kövi is offline        Reply With Quote
Old 09-07-2006, 03:21 PM   #25
eheliflyer
Default Re: Pinoin
Istvan
Finally someone is making quality aftermarket parts at a good price. I can't wait to see all of your products. :mrgreen:
Kovi you rock. :glasses:
Alvin
eheliflyer is offline        Reply With Quote
Old 09-07-2006, 03:46 PM   #26
Kövi
Thanks Alvin!
The pictures of the last modifications:
Bell-Hiller mixing ratio is 80% now, and the new slide block.
Kövi
Old 09-07-2006, 04:06 PM   #27
eheliflyer
Damn Kövi you are really impressing me with all of your mods and cnc abilities. Keep them coming. You can never leave anything stock. :glasses:
Alvin
Old 09-07-2006, 06:48 PM   #28
Finless
Team Taco VP
Kövi,
I like the idea of the derlin bushing in the washout block... Did you make any other changes to it like distance/angle from main shaft, etc?
Bob
"Don't Taco My Pack Dude!"
Old 09-08-2006, 12:29 AM   #29
Kövi
Yes, I used Derlin as bushings.
It protects the main shaft surface and eliminates the gap between the main shaft and the slide block.
It is 12mm high so it also helps to fits perfectly. The factory one is only 7mm high and internal diameter is 8.03mm when main shaft is only 7.93mm.
The geometry is same as the original one. There is no modification.
The only modification what I did in the rotor head is the new hole in the mixing arm.
Kövi
Old 09-08-2006, 12:34 AM   #30
eheliflyer
Kövi how far apart did you drill the new holes on the mixing arm? How much did you have to adjust the links also?
Alvin
Old 09-08-2006, 05:12 AM   #31
Kövi
The new hole is 2,5mm far from the original.
I moved the ball into the inner hole on the balde holder.
I aslo lenghtened ( by 1 full turn ) the link between the blade holder and the mixing arm.
Kövi
Old 09-08-2006, 09:17 AM   #32
eheliflyer
Thanks I will try it out tonight.
Alvin
Old 09-08-2006, 12:07 PM   #33
les
Kovi,did you get my PM regarding items i would like to buy?
Regards Les
les is offline        Reply With Quote
Old 09-08-2006, 12:36 PM   #34
Kövi
Hi Les,
I have got your PM and a PM was sent to you.
Today I was able to test fully the new head setup.
The feeling was much better than before. I used the stock paddles and blades at this test.
Lepton was as stable as with the stock setup but it was much more responsive. A roll and nick rate was twice faster than the original.
Now I can fly hard 3D from 2600rpm and I don't need to move to 3000.
At 2200-2300rpm it is an ideal trainer heli. Quiet and really friendly....
Kövi
Old 09-15-2006, 08:52 AM   #35
Kövi
I have just finished the pinions and the derlin main gears.
Tonight I will finish the slide blocks and carbon parts.
So every order will be dispatched on tomorrow.
Kövi
Old 09-15-2006, 09:02 AM   #36
poerqwa
Hi Istvan,
Can you reply to my message (PM) on my order, need to know the amount to be paid through paypal.
Thanks in advance.
Marc
Old 09-16-2006, 03:50 PM   #37
les
Hi Kovi,PM SENT!!
Old 09-17-2006, 02:29 PM   #38
Kövi
Here is some pic of the new parts:
Kövi
Old 09-17-2006, 03:08 PM   #39
gtrick90
Hi Istvan, I've sent you a PM!!
Pls let me know!!
Regards
Luca
Old 09-19-2006, 01:00 AM   #40
rotodingo
Hello,
Has anybody successfully sent some money to Kovi via paypal? Paypal is telling me that Hungary is still not authorized to receive money via paypal. Only to send money. Did you have the same problem?
Nicolas
rotodingo is offline        Reply With Quote
