Old 11-28-2009, 10:39 PM   #1
CF_Machete
Default DIY guide request
ok, this may sound dumb, so feel free to call me out on it, but could some one post a how to video for DIY blades? I've been through the read through's and think i have it down, but a video woud be awesome.
fbl furion 6, fbl gaui 200 v2, FBL Stretched Align 450 pro V2, fbl t-rex 500, fbl beater 450...and some planks.
CF_Machete is offline        Reply With Quote
Old 11-30-2009, 06:11 PM   #2
SlowWhite
I could post an after video. and just talk a step by step / piece by piece if that would work for you?
-Brian Barton
Team Xerogear
SlowWhite is offline        Reply With Quote
Old 12-01-2009, 07:51 PM   #3
CF_Machete
that would be pretty cool. I just got a rave 450 and it looks like il have to make some 350 night blades as no one make them ...to my knowledge.
Old 12-02-2009, 12:40 PM   #4
seanmil666
An after video would be awesome.
seanmil666 is offline        Reply With Quote
Old 12-02-2009, 03:05 PM   #5
flyinfool
The SWARM Heli club is going to be having a heli night some time in the near future, where the main topic will be constructing night blades.
I'll see if anyone has a digital video camera and an idea on how to use it.
All I have for digital capability is a cheap web cam with lousy picture quality and no closeup capability.
I have an older high end video camera that uses HI-8 tape but I have no way to convert that into a digital format for posting. I have a few tapes of things that I have filmed over the years, that I would love to convert to digital.
Jeff Borowski
RAMS Club President
www.ramsrcclub.com
flyinfool is offline        Reply With Quote
Old 12-24-2009, 06:05 AM   #6
The Dude II
Default Hmmm...
Sounds like a good holiday project...and I need to build another set of blades for a more advanced battery/controller for IRCHA 2010 anyway.
That rug really tied the room together...did it not?
The Dude II is offline        Reply With Quote
Old 12-28-2009, 07:43 PM   #7
daisydog
I too would love a video. Some times trying reading it and do it is a lot harder than watching a video.
I can't wait to see the video, then I'll try and make my own.
daisydog is online now        Reply With Quote
Old 01-20-2010, 05:58 PM   #8
thenewguy
Alpha_&_Omega
Here is a teaser for you. http://www.helifreak.com/showpost.ph...&postcount=213
Rave 450 night blades.
thenewguy is offline        Reply With Quote
Old 01-20-2010, 06:50 PM   #9
CF_Machete
nice, can't wait for a vid
Old 01-29-2010, 09:34 PM   #10
povern
Found this guy "thenewguy"on the otherr site, he will make night blades for you out of any blades that you have....
Just PM him for prices.
povern
Screw It, I'm gonna fly.
Logo 6003d and 600se: BLS all around, Pyro and HeliJive
povern is offline        Reply With Quote
Old 02-02-2010, 11:14 PM   #11
The Dude II
Default OK...this is a LONG project!
Series nearly complete as of 3-16-10 - 1 or 2 more videos to edit/up-load.
Long-A$$ project this is!
List of parts:
Digi-Key at www.digikey.com
part # make-up color lens package size
leds:
350-2046-6-ND INGAN BLU WATER CLR 0805 SMD
350-2047-6-ND ALINGAP RED CLEAR 1206 SMD
350-2045-1-ND INGAN GRN CLEAR 0805 SMD
Resistor
P40.2CCT-ND 40.2 OHM 1/8W 1% 0805 SMD
3-pin socket
A26245-ND CONN IC SOCKET 3POS SIP TIN
On/Off Switch - Radio Shack
Catalog #: 275-007 6VDC 0.3A DPDT Slide Switch
Battery
80-mah single cell lipo
http://www.bphobbies.com/view.asp?id=A2416227&pid=W561531
Copper Tape
4516 Copper foil tape http://www.glasscrafters.biz/CTGY/foil
2-Part Automotive Clear
http://www.sherwin-automotive.com/pr...?product=FC710
http://www.sherwin-automotive.com/pr...?product=FH612
Tools & Supplies Video:
Components Video:
Blue Tape, LED Soldering & SIP/Switch prep:
(sorry video is rotated 90-degrees - only way to get work surface in frame & be able to solder)
Note: The "Booger Technique" - you'll see in the video where I roll around the soldered LED & resistor - this is a simple "mechanical stress test" of the junction between the the two components.
Introducing the blades, weigh-in, insulating the exposed CF to keep battery from draining too quickly, surface prep, where to place the copper traces and more blue tape:
Attaching the copper foil tape:
Marking LED placement on copper foil:
Adding the LEDs and copper traces over the LE:
Another continuity check, Battery placement, switch & charge port wiring:
P.S. - Thanks Jeff...
One thing that I noticed that you did do but did not mention is to wire the switch so that moving the switch to the outside turns them on. This way centripetal force will keep the switch in the on position.
Final Video- Weights checked, CG's are VERY CLOSE, measuring clear-coat, recap & charge leads:
See the finished product (blades from 2009)in-flight:
Maybe I'll edit the video for this below...kinda like explaining brain-surgery: I'm also going to show how the 'environment' of the blade helps us to "cheat" an LED with lower light output and drive it a bit harder than normally allowed. (observe your surroundings and take advantage & quite possibly why some have had limited success without employing resistors!)
Red LED temps relative to others because of the "cheat":
Why Resistors???
  • Limits the Current
    • Protects the LED
  • Protects other Branches of the Parallel Circuit
  • Protects the Li-Po Battery
  • Places the LED at optimum operating Voltage & Current
  • Extends the “run-time” of the design.
If no resistors!!!
  • LEDs will run SUPER BRIGHT
    • and burn out (excessive heat)
    • hopefully an “open circuit” will occur
  • Extremely short run times on battery pack (relative)
  • Continuous LED replacement
  • Could fail the LED in a “dead short”
    • loss of all LEDs on that blade
    • possibly damage the Li-Po or FIRE!
Ohms Law
Voltage (V) = Current (I) x Resistance (R)
or
V= I x R
Voltage Division across a Series circuit
Vtotal = V1 + V2 + Vn...
Vtotal = Single Cell Li-po Voltage Source
Vtotal= Vled + Vresistor
4.2V= 3.2 + Vresisitor
Vresistor = 1.0V
Iled= Current = 0.020Amp aka 20mA
V= I x R
R= 50-ohm
Power
Watts = Voltage x Current
0.02Watts = 1V x 0.020A
Smallest Wattage on 0805SMD resistor = 1/10W =0.1
Night Blade Circuit is 4 Series-Circuits in Parallel with a battery & switch.
NOTE THAT ABOVE a 50-ohm resistor was calculated but a 40.2-ohm value was purchased. Why?
4.2VDC is the fully charged state of the battery - the moment the blades are "on" the voltage will be dropping. Majority percentage of the discharge will be in the 3.8 to 3.4 VDC range.
Take 3.8V - 3.2V / 40.2 = ~ 15mA.
Next version may have an AMtel chip driving the LEDs directly - then no resistors and an RF link to the x-mitter!!!
Old 02-03-2010, 12:29 PM   #12
flyinfool
Nice start on the vids.
Jeff Borowski
RAMS Club President
www.ramsrcclub.com
Old 02-03-2010, 04:55 PM   #13
The Dude II
Added Components Video - just uploaded at 5:55PM EST - still processing.
Old 02-06-2010, 11:25 AM   #14
CF_Machete
THANK YOU!
Old 02-06-2010, 02:28 PM   #15
The Dude II
Default Glad you like.
Working on a Power-Point presentation for calculating resistors, LED selection and other points to consider before constructing.
Hope this cold leaves my head...sound more like Barry White today than I'd like to...except my lines are all about helis &$hit...so the wife is less than impressed.
Old 02-07-2010, 11:50 AM   #16
nexgen
Thanks for teh info and the vids. I am comfortable with the other aspects of the project, save for one. would also like to see a vid of how to go about soldering the LED's to the tape without melting the led.
GAUI Field RepbeastXTeam Empire Hobby
Gaui 200 •Gaui 550 •Gaui X5
BeastX Castle Scorpion Hyperion Spektrum JR
nexgen is offline        Reply With Quote
Old 02-07-2010, 11:00 PM   #17
The Dude II
Absolutely. This is probably the most critical - you might fall out of your chair when you see how simple - there can not be any "gaps" between LED/Resistor & the copper tape - solder will not "bridge".
Old 02-14-2010, 07:17 AM   #18
The Dude II
Head cold is gone but business has finally come out of the "winter slump" (this is GOOD) so my time is getting short.
Fortunately, a friend of a friend has asked me to build a set of blades for him...so - when his blades arrive, I'll shoot the remainder of the build-series.
So, coming yet -
  • Power Point on the "engineering" behind LED selection, current & power calculations.
  • Bench Prep & soldering technique used to "mate" the LED & resistors prior to placement on the blades
  • Blade prep (blade measurements, sanding & clear along leading edge)
  • Blade lay-up (copper tape, LED/resistor mounting, battery, switch, charge port & wiring)
  • Soldering & testing
  • Measurement part II and CG/weight corrections
  • Final Clear
  • Making a set of charge leads
Old 02-14-2010, 03:53 PM   #19
nexgen
Old 03-09-2010, 04:19 AM   #20
The Dude II
Shooting the final videos this AM.
Look for more videos this weekend.
I will edit/insert the original lengthy post on page #2 with the added content.
