Old 10-26-2011, 01:54 AM   #41
avengedkevinfold
any cheaper alternative to put the clear coat on the blades? i am doing 325's for my 450. possibly a simple spray paint clear coat? I don't care how it looks.
also, what if it use some Align 325 woodies (1st DIY attempt). can i do these without clear coat as they don't have the metal leading edge.
avengedkevinfold is offline        Reply With Quote
Old 10-26-2011, 09:18 AM   #42
flyinfool
Yes you could eliminate the clear coat for woodies or fiberglass blades.
The clear is only needed because many carbon blades are electrically conductive.
Jeff Borowski
RAMS Club President
www.ramsrcclub.com
flyinfool is offline        Reply With Quote
Old 10-26-2011, 10:57 AM   #43
avengedkevinfold
if i do use the CF blades, is there a cheaper/easier alternative to clearcoat? i dont have a booth, sprayer, etc. what spray paint clear coat would you recommend?
Old 10-26-2011, 08:43 PM   #44
flyinfool
Since you are doing blades for an electric, you can use Krylon clear from the hardware store.
Jeff Borowski
RAMS Club President
www.ramsrcclub.com
Old 11-02-2011, 04:28 PM   #45
avengedkevinfold
Hey guys, I built my own night blades last night on some 325 align woodies. I had a 150 mah battery mounted using double sided 3M tape. Next I covered in shrink wrap. However my shrink wrap only went around the thick part of the blade. In other words, after performing the shrinking, the shrink wrap was still rectangular when looking from the top.
Test flew them today and the shrink wrap flew off and then the batteries flew off. Not much damage with a good auto but I am wondering what you guys are using to keep the shrink wrap on?
A couple options come to mind.
1) put more double sided tape between the battery & shrink tube, or blade & shrink tube.
2) make the shrink wrap come all the way up to where the end of the blade (near the blade grip) starts to get smaller.
What would you guys suggest?
Old 11-03-2011, 04:20 AM   #46
The Dude II
Start with a shrink wrap that barely fits over the blade first - again what was sourced for these videos was from the RC car guys that make their own battery packs...tends to shrink quite a bit.
Next - due to the blade size you're working on (325) - might suggest using 2-3 sizes of wrap - big piece for the widest part of the cord, smaller for the taper.
Finally, try wicking some thin CA under the wrap.
Can't stress enough, you are your own QC expert on this stuff; when there's doubt - best step-back and rethink.
Also - might look into a slightly smaller cell... 50 to 80mAh - less weight equals less rotational forces pulling on the heat/tape.
That rug really tied the room together...did it not?
The Dude II is offline        Reply With Quote
Old 11-03-2011, 11:04 AM   #47
avengedkevinfold
Seems like most people place the battery on the top of the blade. Can I place on the bottom? Has anybody ever done this?
Old 11-03-2011, 02:17 PM   #48
flyinfool
I've never tried it, but there is no reason that the battery needs to be on the top other than accessibility.
With the cell on the top side you can see it is easier to spot if it is starting to come loose and easier get at if you need to.
Remember this is for use in the dark, daylight cosmetics are meaningless. ALL of my night stuff is really ugly in the light of day.
Jeff Borowski
RAMS Club President
www.ramsrcclub.com
Old 09-28-2012, 09:59 PM   #49
Generalx5
ohh buddy, I should have seen this earlier. I did this! DIY
I had some spare socket 0806 SMD white LEDS that are 2800milicandles bright. And used 2 thin audio wires their like 40 awg or something its really fine single strand and CA glued it onto one of the blades with the soldered LED on one end. On the other end attached is a small 3 pin header strip the ones with the holes to plug pins in. I used that as the terminal for charging and turning on the LED using a simple U pin made from cut offs from resistors to complete the circuit.
On the top of the blade is a 20miliamp single cell lipo which runs the LED.
I balanced the other blade but screwing in metal weights. All in all, things worked out just fine at a cost of under 5 dollars for everything. One LED is enough, dont need both blades to have them since 2800mcd is already blindingly bright. At close range and at night, when the blades come to a stop the LED light brightens the walls around the heli, so thats how bright were talking about....
I am on HK right now, but i have this one my blade 400 back home. Ill post some pics when I get back! someone PM me if they ever see this and not see a picture posted. It may be because I forgot. Yeah remind me!
Mcpx ~ Mcpx(Xtr) ~ T-450 Trainer (HC3-SX)
T-250 DFC (ZYXS) T-450 PRO DFC (ZYX) T-700E DFC HVSC (3GX)
WARP 360 (3GX)
ATOM 550 (3GX) Futaba 8FGS/DSM2
Generalx5 is offline        Reply With Quote
