Old 12-04-2009, 06:43 PM   #1
TJinGuy
Default How much does your Protos weigh?
I brought my mail scale home from work and it occurred to me that I had not weighed new Protos yet. See I like numbers, numbers like weights, and I was interested to see what number my scale would tell me when I sat my new super light heli on it. Lets just say I was a little surprised to see that the number was a little higher than I expected. MSH advertises the Protos with 6s pack at 1520g and with 7s A123 at 1700g. By comparison my scale informed me that my Protos weighs 1320g minus battery and 1750g with.
My setup is pretty normal
Plastic Protos w/stock motor, canopy and blades
3x s9650mgs on cyclic
CC Ice 75A
Mini-G + s9254 on tail
AR6200
Hyperion VX 2600 packs
Yes the mg servos add weight and so does the full sized tail servo. Yeah the Ice 75A is heavy. The lightest 6s pack I can find anywhere is is 340g, 64g less than my packs. So there is all of that but how can it add up to 230g or over half a pound!?!?!?
All I can think is that MSH must have seriously shopped for some light parts to get low numbers like that.
- Chris
heli...info...news...such
Helis: TRex 450 Pro - Protos - TRex 550e
Stuff: Spektrum DX7 - iCharger 208B - Hyperion G3
TJinGuy is offline        Reply With Quote
Old 12-04-2009, 07:25 PM   #2
DriveWRX
My numbers on my 2 Proti:
Protos #1
- Stock plastic kit
- Stock motor/ESC
- SAB blades
- MSH FG canopy
- AR7000
- HS-85MG cyclic
- Futaba 520/9257
- Hyperion VX 2600 6S
Weight: 1542g
Protos #2 FBL
- Stock plastic kit
- Stock motor
- CC80 w/ CCBEC
- Radix blades
- MSH FG canopy
- 9650 cyclic
- 9257 tail
- Mini VBar
Weight: 1546g
After loosing the flybar parts, I was a little suprised to see that the FBL one weighs more than stock.
MSH Prôtos ...A Better Way to Fly
MSH Prôtos Mini
Mikado Logo 600
Vergnügenstabi
DriveWRX is offline        Reply With Quote
Old 12-04-2009, 07:31 PM   #3
CatchmyCorsair
The original weight advertised by MSH was when 25C was the hot pack. 30-45C were not available, so MSH did testing with 18C FP Evolite packs.
Steve
Trex 450 Pro
= MSH Prôtos = E-Stratus
CatchmyCorsair is offline        Reply With Quote
Old 12-04-2009, 08:02 PM   #4
TJinGuy
Protos #1
- Stock plastic kit
- Stock motor/ESC
- SAB blades
- MSH CF canopy
- AR7000
- HS-85MG cyclic
- Futaba 520/9257
Weight: 1542g
The 85mgs weighs 4g less than plastic geared 9650s and 12g less than the MKS 9660 (which I assume are similar to the mg upgraded 9650s). The 9254 weighs 23g more than the 9257. The AR7000 weighs 4g more than the AR6200. Otherwise they should be the same. ESC weighs the same and gyro should be very close. The differences add up to 59g. So either I am missing something or one of our scales is off.
- Chris
Old 12-04-2009, 08:42 PM   #5
DriveWRX
I'm curious now too...
Try this:
Weigh your Hyperion pack.
I got 402g on mine with Anderson Power Poles.
Stock weight according to the Hyperion Spec sheet is 404g. Pretty close.
ID:	127417   Click image for larger version
MSH Prôtos Mini
Mikado Logo 600
Vergnügenstabi
Old 12-04-2009, 09:44 PM   #6
TJinGuy
Good idea.
My 2600s with straight 3.5mm bullets, probably lighter than your PPs, show 425g on my scale. So maybe my scale it high? Or maybe yours is low?
- Chris
Old 12-04-2009, 09:51 PM   #7
nyc863
My FBL carbon, with a BLS251, is 1770 grams, with a zippy 2600 battery (461 grams with the velcro etc). A 2600 Hyperion I also fly with weighs 409 grams, so that would take it down to 1720.
I have a z-power motor which may weigh more than the stock MSH motor. The tail servo is more than a 9257 and I have a carbon wrapped boom that is heavier than the stock boom, I think the carbon frame weighs more than the plastic one?
<--- check out my fleet get your fleet online
nyc863 is offline        Reply With Quote
Old 12-04-2009, 09:52 PM   #8
trickybit
Hyperion VX 2600 6S powerpoles, 1"x2" velcro and a thin lap of cloth tape: 411g.
Logo 600: Jive, BLS, VBar "Hansen Built"
T-Rex 550E: ICE, BLS 251, VBar
Protos 500 (plastic): Jazz, Hyperion/Scorpion, VBar BLS 251
Tornado Coin-Op: Gray marble, XTremeSoft wraps
trickybit is offline        Reply With Quote
Old 12-04-2009, 09:55 PM   #9
nyc863
I think his mail room has been over-charging
Old 12-04-2009, 10:30 PM   #10
JustPlaneChris
Mine has:
Plastic frame
Hitec 5245MG
Spartan / 9257
SK360
AR7000
Jazz 80-6-18
With a Kong Power 2600 and Fusono FG canopy AUW is 1624g
With plastic canopy it's 1598g
KP 2600 = 387g
I also have two Polyquest 2700 packs at 433g, so AUW with those is 1670g.
Just for interest, AUW with the 7S A123 packs is 1794g (558g pack).
-Chris
JustPlaneChris is offline        Reply With Quote
Old 12-04-2009, 10:43 PM   #11
trickybit
My little scale shows 1215 without the o-rings, with the hyperion that would be 1626.
Stock: plastic,motor, blades, fg canopy
phoenix 60, powerpoles
sportbec
mks metal all round
spartan
ar6200
voltage stepdown
pads of dualoc here and there for mounting satellite, eagletree
dang, i hope it's sunny tomorrow... all this talk about light helicopters and their cool setups is making me antsy.
Old 12-04-2009, 10:55 PM   #12
TJinGuy
Man I wish it would warm up so we could fly. It was 19F out when I went to work this morning at 9am
- Chris
Old 12-05-2009, 05:29 AM   #13
Chorge
1542g - Plastik-Kit - FBL (V-Stabi 4.0) - BLS251 - Rockamp (Fusuno?) canopy, heavy! - SLS ZX 6S 2500mAh 30C
With V-Stabi 4.0: THREE DEE RIGID
With MicroBEAST: T-REX 550
, PRÔTOS 500, T-REX 450 Pro
Chorge is offline        Reply With Quote
Old 12-05-2009, 07:00 AM   #14
wespen
Infinity V2 carbon frame
FG canopy
Kora 15-14 (40g lighter than my Scorp 880)
Jazz 80 + CC BEC
MKS on cyclic
BLS on tail
V-Bar
metal grips
metal tail
Ar6100E
1220 grams empty
410g G3 2600
450g PQ XF 2500
1630g / 1660g RTF (1690g with Scorp)
I just hope Lexan canopy will be out soon, this will bring me hair below 1600g
- Croatian RC forum
wespen is offline        Reply With Quote
Old 12-05-2009, 05:19 PM   #15
JiriK
Plastic Protos kit with sab blades and plastic canopy.
* Stock motor
* Spektrum AR6100 rx
* Spartan ds760 + 9257
* Ino labs HG-D260HB servos
* Kontronik Jazz 80A
* 7S A123 2300mAh pack
1701g.
Only mods are the tail fins that I made from fiberglass sheet and motor mount washers (made from 3mm aluminum)
JiriK is offline        Reply With Quote
Old 12-07-2009, 09:27 AM   #16
henryd123
mine is 1644 grams with 6s lipo installed(2800 winforce)
msh protos,trex 500esp
henryd123 is offline        Reply With Quote
Old 12-07-2009, 10:38 AM   #17
Synx666
1660 with 6S2500, Mini-V, jazz55 and CC BEC pro. (plastic)
For Sale: Logo 6003D Vbar
Synx666 is offline        Reply With Quote
Old 12-09-2009, 04:44 PM   #18
Shawn Behrens
1650 g
carbon protos
stock motor
align 60 amp esc
3517 on head
spartan and 8900G on tail
stock FG canopy
6s 2600mah hyperion vx
align 425D
shawn
Shawn Behrens is offline        Reply With Quote
Old 12-09-2009, 07:09 PM   #19
monse
current AUW with 6s A123 ( 466g ) is 1522g
things that save weight:
Plastic frame
carbon tail boom: -12g compared to stock
Blades: HT 435DF: 110g/Set
Plastic Canopy: 37g (39g repaired)
Spartan (shortened wires) --> AC-3X FBL: -28g
Kora 15 without 3rd bearing: 155g inlc. connnectors
Duzi.cz tailboom support brace + no horizontal finn
rc-carbon.com 450 landing gear: 25g including skids, bolts, nuts
YGE-60 ESC integrated BEC
MKS 8910 tailservo
Savox 1350 on Swashplate (wires shortened)
monse is offline        Reply With Quote
Old 12-10-2009, 08:10 AM   #20
Chorge
I'm extremly sorry!!!! Made a mistake!!!
Mine is 1621g....
