Old 10-30-2011, 12:19 PM   #41
mattmezz
Default question
I have a couple 3300mah packs that are from a trex 500 that bit the big one… the packs weigh around 515g, I was thinking putting them on my protos, but it’s not stretched. So I thought I could add some weight to the tail.
Think this is a good idea or am I dooming my protos to an ill fate?
mattmezz is offline        Reply With Quote
Old 11-04-2011, 04:53 AM   #42
pani
Protos plastic composite frame stretched
Turnigy 3025 850Kv motor
Mini-Vbar blueline
3x Turnigy MG930 on cyclic
Futaba S9257 tail servo
YGE 60A ESC
MSH White Fiberglass canopy (70 grams!!!!!!)
Edge FBL 425 blades
Spektrum satellite
Hyperion phase sensor
dry weight: 1220g
w/ Turnigy 2200mah 40C: 1600g
pani is offline        Reply With Quote
Old 11-09-2011, 01:37 PM   #43
zaplik
Protos carbon
Stock motor + ESC
BeastX
Align DS510-3x
Savox SH-1357 -1x
AR-6200
Chapmion blades
6S 2500 PULSE 45C - 1595g
6S 2650 ZIPPY 20C - 1580g
zaplik is offline        Reply With Quote
Old 11-25-2011, 10:55 PM   #44
dennisvm75
I'm using turnigy 3300s but my protos is stretched. Still flies very well. Very little difference when I'm flying with nanotec 2700 65c. Flying times I'm getting around 5mins doing a lot of big rainbows nag tight tic tocs.
dennisvm75 is offline        Reply With Quote
Old 12-19-2011, 03:46 PM   #45
whisperdancer
My Protos is a PIG!!!
The Gens Ace 3300mAh makes it a heavy dog.
It weights 1715g with the Voltz 2600 35C, and 1340g dry (stretched).
MSH Prôtos CF FBL Stretch - Scorpion 880KV, YGE 60A, 3x s9650, BLS251, VBar 5.1
E-flite HABU 32
Ikarus EXTRemA 330S
Multiplex Parkmaster 3D
whisperdancer is offline        Reply With Quote
Old 12-27-2011, 12:50 AM   #46
torro
stretched, BLS153, BLS251, YGE80, HK3226, miniVS 1300gramm
6S2250 nano 65C 380gramm
torro is offline        Reply With Quote
Old 06-07-2012, 10:11 PM   #47
Dr. M
1340g dry, 1790g AUW with 2600mAh GensAce 25C 6s.
Stock CF, CCIce Lite 75, Ds510, mks ds760p tail.
Fly first ask questions later.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
MSH PRÔTOS 500 FBL "Sky Whip" | ZYX v4.0
Audacity P6 FBL "Phoenix" | MSH Brain | 12s e-conversion
Dr. M is offline        Reply With Quote
Old 06-08-2012, 09:00 AM   #48
shadco
P500, Minivbar, R6203SB rx, 9650's cyclic, BLS257 Rudder, Mavrikk G5 Pro Wide cords, Fusano Canopy, A Plus 2500 mah 45c lipo, MSH/Scorp motor, YGE ESC.
1576 grams
Synergy E5-S KDE 600XF MKS HV YGE Vbar : Compass 6HV Quantum 4125 MKS HV YGE Vbar
SAB G500 Savox 4050 KST/MKS HV YGE HC3SX
Compass Warp Scorpion 2520 MKS YGE SK540 : 130X MCPX BL Nano 14SG DX8
shadco is offline        Reply With Quote
Old 06-10-2012, 12:01 PM   #49
jfluegel
Carbon frame
Stretched
Low FBL head
Aluminum servo mounts, bearing blocks, rudder servo mounts, tail case, and pulleys
JR3717 on cyclic
DS650 rudder
Ice 75 with EC5
Scorpion 3026
SAB 470 blades
Fusano canopy
BeastX
1325 grams no battery
1751 grams with Gens Ace 2600
Not as bad as I thought it was going to be with all that added aluminum parts.
jfluegel is online now        Reply With Quote
Old 12-27-2012, 04:31 AM   #50
pani
I changed my configuration a bit so here are my new weights.
Protos plastic composite frame stretched, no screws on landing gear (1.5mm tie wraps), removed Horizontal fin, lynx 500 series Vertical FRP orange fin
Turnigy 3025 850Kv motor no backplate,14T pinion with long motor shaft (no pinion adapter)
Beast-x with 1 Orange sat
Hi Model 60A ICE ESC
Logo 400 canopy 90grams
Edge FBL 475 main, MSH orange tail
dry weight: 1230g
w/ Turnigy 2200mah 40C: 1610g
Old 12-27-2012, 01:11 PM   #51
Dr. M
Originally Posted by pani View Post
dry weight: 1230g
That is a super-light stretch Protos
Old 01-01-2013, 07:36 AM   #52
michalp
1,33 Kg
With 2200 45C Packs.
But its not the original Protos
Greets,
Michal
michalp is offline        Reply With Quote
Old 01-02-2013, 12:01 PM   #53
pani
Originally Posted by michalp View Post
1,33 Kg
Greets,
Michal
Pics please...
Old 01-03-2013, 05:40 AM   #54
michalp
Here are the Pics.
http://www.fotos-hochladen.net/uploa...h71a5dxyr9.jpg
http://img5.fotos-hochladen.net/uplo...snu25zgmvl.jpg
1333 Gramms
But i have a Carbon Mainschaft and other Things like this ^^
Greets,
Michal
Old 01-03-2013, 08:07 AM   #55
michalp
Hi,
here are the Pics :
http://www.fotos-hochladen.net/view/...bjr2pe5z3l.jpg
http://www.fotos-hochladen.net/view/...a4ri3yzocl.jpg
Greets ,
Michal
Old 01-03-2013, 12:18 PM   #56
pani
Michal how does it fly without the boom braces?
Old 01-03-2013, 12:50 PM   #57
michalp
It's a modified CFk Boom, its reinforced in the front and back with a second boom in the boom. I know that this sounds freaky but it works really well without any issues.
You can see some Vids on my Youtube Channel :
http://www.youtube.com/playlist?list...eature=mh_lolz
I also use a Carbonmainshaft that weights only about 14 Gramm or something arround it
This shaft is 20 Gramm lighter then the original MSH mainshaft.....
Sorry for my bad English
Old 02-18-2013, 03:20 PM   #58
solex227
Carbon frame
Alum frame 2 servo frames/ 1 bearing support
Alum pulley X4
Motor pinion Support
Alum Tail gear t18
Ar8000 w/1 sat
JR 3517mg x3
BeastX
Hyperion 3026 880
CC Ice 100 Lite
Savox SH1290 mg full size tail servo
Alum tail servo mount
Stock FG canopy
Glacier 2600 mah 6s 22.2V 30C
SAB425mm Blades
TOTAL 1660g very much average ready to fly
solex227
solex227 is offline        Reply With Quote
Old 03-11-2013, 08:08 PM   #59
karl k
Plastic Protos 500
1680 grams
Edge FBL blades
karl k is offline        Reply With Quote
