Old 10-21-2011, 05:49 AM   #61
Inverse
Anyone have a V5 file for an otherwise standard carbon Protos?
Just looking for gain figures to start playing with as this is my first FBL 500 after FBL 250s and 450s.
I honestly don't have a clue
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Prôtos 500 - MSH Brain
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote
Old 03-19-2012, 07:51 AM   #62
belun
Question newbie question
so, the beastx acts as a gyro and flybarless unit?
also, could i use one of these SPMAR7200BX 7CH DSMX & BeastX Flybarless Control System on a protos? this way i have gyro + flybarless unit + receiver ...
belun is offline        Reply With Quote
Old 03-19-2012, 10:34 PM   #63
desertstalker
Yes to both.
-DX8
Old 03-19-2012, 10:53 PM   #64
banditpowdercoat
With the BX you do not need a Gyro. The BX IS a Gyro. 3 Axis Gyro. You can even disable the FBL and use it as a standard tail Gyro. Not sure if you can use another tail gyro with it tho. You can disable the FBL function, but don;t think you can disable the tail gyro function from what I remember. So it would conflict with a standalone gyro
Dan Pesonen
FBL, Don't think about it, DO IT.
mCX2, nCPX, mCP X, Blade 400, MSH PRÔTOS
"Tri-Flow"
I put that S*** on everything!"
banditpowdercoat is online now        Reply With Quote
Old 06-02-2012, 01:23 AM   #65
zole
Hi all,
what about 3G? Is anybody using that unit on Protos? Is it worth it?
Thanks!
Protos 500
T-Rex 600 12S
Raptor 60 V2
Logo 600SE
zole is offline        Reply With Quote
Old 06-02-2012, 08:50 AM   #66
desertstalker
Originally Posted by zole View Post
Hi all,
Thanks!
Its not as good as the others, id stay away from it.
-DX8
Old 08-26-2012, 06:38 PM   #67
crickr1
Hi all,
Thanks!
If your mad at your Protos and want to punish it, maybe,,,,
Keep it in the air!
Lovin MSH!
hybrid Gaz/otos fbl,stretched 6s MiniP Stretched PROTOS 500 ,EC135 Era/Protos500,Compass 6HV, Gaui NX4 all MSH-Brain/Futaba8FG Compass 3D+ CGY750
crickr1 is offline        Reply With Quote
Old 09-08-2012, 09:55 AM   #68
Dowquest
Crickr1,
How do you like the brain fbl system?
Dowquest is offline        Reply With Quote
Old 09-13-2012, 06:02 AM   #69
crickr1
Originally Posted by Dowquest View Post
Crickr1,
So far I am loving it! Have on my mini protos and it's great, Put 1 on my p500 and need to change some settings,made some changes and had to do a few emergency autos, found my belt was badly worn so haven't had time to dial in yet. Hopefully today. Was looking here to see if anyone posted some settings for it. Guess all the info still on brain forum.
Keep it in the air!
Lovin MSH!
Old 10-01-2012, 02:45 PM   #70
phranticness
LOVE the brain on the Protos - Freakin Awesome.
I attached my latest Brain file - please don't use it! look at it if you like, copy the "tune" settings even, but don't try and upload it and fly, you'll crash. Too many setup variables.
Brain works great on my T700 too - not only does it fly awesome - it's immune to vibration - (something my T700 has had issues with since new)
phranticness is offline        Reply With Quote
Old 10-26-2012, 07:40 PM   #71
aquaanox
looking for some vbar 5.x setup files to compare gain values for tail and cyclic. only one ot two posted so far. ill put mine up here too once i have a setup that is working good. thanks...
aquaanox is offline        Reply With Quote
Old 01-23-2013, 07:36 AM   #72
sly
Default Protos FBL Feathering Shaft
Does anybody know the differance in lenght between a standard feathering shaft and a FBL feathering shaft?
sly is offline        Reply With Quote
Old 01-25-2013, 12:17 PM   #73
banditpowdercoat
FBL is a couple MM longer. not sure exact but a tad bit longer
Dan Pesonen
"Tri-Flow"
Old 01-26-2013, 09:49 PM   #74
sly
MSH tech help tells me that the FBL spindle is about 1.5mm longer.
Old 02-24-2013, 11:50 AM   #75
tantar
Hi gents / ladies , did some of you install an fbl unit COPTER X 3x1000 on PROTOS , especially using T8FG ?
Any help will be highly appreciated
tantar is offline        Reply With Quote
Old 02-25-2013, 03:29 AM   #76
Mikej
I had one on for a while (using Spektrum) but changed it to a Robird G31
Mikej is online now        Reply With Quote
Old 02-25-2013, 10:17 AM   #77
Inverse
Default Flybarless Protos, share your files and your notes on your setups :)
I used one on my 450 and decided it wasn't up to scratch to try on my Prôtos. I hope you have good luck with yours.
Spektrum DX8
Old 02-25-2013, 02:30 PM   #78
Dr. M
My Protos is proudly flying a CX 3x1000 flashed to ZYX 3.5 firmware. I'm using Spektrum, though, not Futaba. The FBL controller works very well, and even though I like the Brain better, I have no plans in changing out the 3x-ZYX on my Protos.
Word of warning: This FBL controller is extremely sensitive to static and the Protos is a static monster. Take extra precautions by grounding your tail to the motor mount and keeping the belt lubed up with silicone anti-static spray.
Fly first ask questions later.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
MSH PRÔTOS 500 FBL "Sky Whip" | ZYX v4.0
Audacity P6 FBL "Phoenix" | MSH Brain | 12s e-conversion
Dr. M is offline        Reply With Quote
Old 03-05-2013, 06:21 PM   #79
ddhuans
Dont have any issue with Beastx and my P500 until now. Everything is running smoothly.
I recommend you guy should use one of famous FBL units like Brain/iKon, BeastX, Vbar or Skookum...You really get what you pay for!!!
Align T-Rex 450 Pro: BL450MX motor,ServoKing DS995, Jazz 55-10-32, Mini V-Bar Blueline Pro
Align T-Rex 500EFL Pro: Scorpion motor, Align servos, Castle Creations ESC, BeastX
µB
MSH Prôtos 500: Scorpion motor, Hitec&Futaba servos, YGE ESC, BeastX
µB
ddhuans is online now        Reply With Quote
Old 03-06-2013, 09:10 PM   #80
husafreak
I see some files for the Vbar 5.X and Protos here but can't open them. Is this a file you put onto you Vbar via PC?
BL MCPx/Blade 130X/Rave 450 Vbar/Protos 500 Vbar//Logo6003D Vbar/Rave ENV90 ARBX/TDR Vbar
husafreak is offline        Reply With Quote
