| 450 PRO Class Electric Helicopters 450 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
#161 |
tarot has a head for about 30.00 you can get a tarot fbl conversion with the xyz unit for about 79.00 I personally would get the tarot head and a beastx, or a 720 skookum
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530 450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF X-8 Wing , D/L UHF Full fpv package |
#162 |
Trex 450 Pro V2
Mikado Mini V-Bar 5.0 Express Scorpion 2221-6 w/ 13T MKS DS92 Cyclics Align DS520 Tail Kontronik Jazz 55-6-18 ESC TrueBlood Green Dampners
Gaui X5 VBar + Gov mCPX BL Last edited by NovaCX12; 12-29-2011 at 09:32 PM.. |
#163 |
Hi,
I’m currently assembling a T-Rex 450 PRO with beastx and I’d like to know if the esc of 35A that comes with the box is enough to power my model. The Align combo with 3gx is also sold with this esc, does this mean I can also use it with the beastx? Thanks
T-REX 450 SE | GAUI 425 | ATOM 500 FBL BEASTX | T-REX 450 PRO FBL BEASTX ...work in progress... Hitec Aurora 9 |
#164 |
You could, but I would suggest external BEC just to be safe. I used CC Bec 10A
Sent from my GT-I9001 using Tapatalk
MSH MINI PRÔTOS |
#165 |
I have a T Rex 450 V2 3GX FBL super combo on its way what kind of radio should I get?? Is there issues with this setup or have the previously mentioned bugs been worked out??
#166 | |
Steve
Trex 450SEv2/HS65-MGs cyclic/Spartan Quark/DS520 tail Trex 450ProV2 DFC/CGY750 FBL/DS410s cyclic/DS520 tail Trex 500ESP DFC/CGY750 FBL/YGE-120LV ESC/DS510s cyclic/DS650 tail Futaba 8FG 2.4GHz |
#167 |
im looking to convert my 450 pro to fbl whats the best fbl head for the money and fbl unit i already have a 550 with beast x i love it but is there anything just as good for less money??
#168 |
I'd say the best FBL head for the money is probably Tarot, it is really cheap and great
MSH MINI PRÔTOS |
#169 |
Wht are yalls setting on the 3gx? Around what tail gain is good, since I'm not bringing a computer to the field I would like to have it close enough
#170 |
Anybody?
#171 |
Has anybody have any Review on the Stock Trex 450 pro 3GX combo looking to order one
#172 |
I have just fitted a Tarot ZYX on my 450 pro, works brilliantly.
#173 |
Look, just got into the 450 FBL and "misplaced" the usb connector,software, and data connector. Not gonna name names (freakin kids) but whatevs. Does anybody know where to find the parts without buying a completely new 3gx kit? does the 3g usb and connections work? Please help!
#174 |
Just go to any heli parts website like Helidirect and order the Align 3Gx. It will come with the usb connector and software. Or search ebay or rcuniverse for someone selling one used. The software can also be found online at Aligns website.
#175 | |
beastx 450pro ice 50.
3179HS Gov. -8motor 2200gensace55c 12 pitch what else? oh.......FUN!!! ![]()
"How high does it go?" Love that question..... To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#176 |
Oops posted in the wrong place. Sorry guys.
- Goblin 700, Sk540, ICE2 HV160, Quantum 4530-500, MKS Tail, Outrage Torq Cyclics - Kasama Srimok Faifa 90e, VBar 5.3 Pro, ICE2 HV120, Scorpion 4035-500kv - Trex 450 FBL, BeastX - Blade MCPX V2 Last edited by Bruno28; 03-30-2012 at 05:58 AM.. |
#177 | |
Sent from my Transformer Prime TF201 using Tapatalk |
#178 |
Anyone else having trouble with the Mikado 450 FBL head being way to soft, leading to cyclic bounce? I have adjusted the cyclic gain countless times, but with no luck. I also tried shimming the head to remove the softness without any obvious results. I actually went so far that I applied a large OD shim between the cone and the dampeners, which completely removed all dampening in the head.
After just a few flights in on this head, I have decided that I am getting the Align DFC head when it comes out. Question is, Can I fly it without any head dampening (extremely rigid)? I do not like the design of the Mikado head at all. It does not use thrust bearings, it has o-rings instead of one piece dampeners (works best on 450s) and 3 mm spindle instead of 4 mm. The hub and blade grips are also not as wide as the stock Align one, which makes the total blade span a little longer. Thanks,
Mathias Mikado Logo 700 Xxtreme | JR XG8 & Spektrum DX8 |
#179 |
Anyone?
#180 | |
