Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > 4G3
4G3 Walkera 4G3 Helicopter Support
Old 01-10-2010, 08:25 PM   #1
bobrains
Default 4G3 Has No Pitch
Been flying a Walkera CB100 for a while and moving up to a 4G3. Transmitter is a Walkera 2081Pro. Works fine with the CB100 in 2401 mode. With the 4G3 paired with the TX in 2081 mode I have no tail rotor, so I put it into 2601 mode and the tail rotor is working fine now. Problem is, I have zero pitch. In normal mode no positive pitch and in 3D mode no negative pitch. Throttles up fine, but the pitch never changes. Sure would appreciate any suggestions anyone might have. Thanks much.
Bob
bobrains is offline        Reply With Quote
Old 01-11-2010, 09:51 AM   #2
Silverexpress01
Default try this
My prior reply was inaccurate - I've removed it.
Jose (Youtube -> Silverexpress01
See also Helifreak Blog)
MCPx 76/7 | Trex 250 DFC 667/19 | Hurricane 200 FES 143/7
Last edited by Silverexpress01; 02-28-2010 at 04:31 AM.. Reason: Learning and Discovering as I go....
Silverexpress01 is offline        Reply With Quote
Old 01-11-2010, 10:19 AM   #3
Dusty1000
Bob
Do you have the swash type set to 120 degrees? and have you set up the pitch curves?
Dusty
Blade 400, mSR, mCPX - Sonix SX450SE - Walkera 1#A, 4#3, 4#3A, 4#3B, 4G3
Dusty1000 is offline        Reply With Quote
Old 01-11-2010, 10:45 AM   #4
Silverexpress01
Default Regarding Pitch
Tags
2081pro, 4g3, pitch, walkera
