| Phoenix Flight Sim Phoenix Flight Sim |
i have had blade mcpx which i crashed last summer, and recently blade 130x where i was too lasy to find a fix for vibrating tail, dropped out of helis, but now i got the bug again... im mostly flying 3d planes...
i could hover my 130x quite well, i could do square circles, provided tail was allways facing me... soo, i spend half a night configuring my phoenix sim, just to find in the end that i needed to reassign pitch channel... seems like i fly better than i expected, i can do circles, rolls, sometimes i manage to pull a tic-toc and inverted hover... could someone suggest me a pitch curve where by middle stick would be very soft throttle response (up to the hovering range...), while by the stick ends, it would still be a rocket? p.s. |
What heli are you flying in Phoenix?
What transmitter are you using for a controller? It sounds like you just need to calibrate your transmitter with Phoenix, and maybe add some expo, but no idea what kind of pitch curve you have programmed. Maybe you can share your settings with us? I think most folks just go with a standard linear 0-25-50-75-100 kind of thing and get nice predictable thrust response so long as their transmitter is calibrated properly inside Phoenix.
#3 | |
im flying with aeroplane (does it matter?) dx8i... i THINK my tx is calibrated properly, because heli like blade msr and quad flys like i would expect them to fly... i programmed my pitch curve as per manual, linear, throttle curve at 70% at idle 1... (since one heli i wanted was blade 450x, i programmed my tx throttle and pitch settings from that manual), but im yoyo-ing every heli i fly... |
#4 |
I use a linear pitch and throttle curve;
Pitch 0-25-50-75-100 Throttle 0-75-75-75-75 Idle up 100-100-100-100-100 No expo Make sure you do a calibration inside Phoenix! |
#5 | |
#6 |
