| Register | FAQ | PM | News | HF Locator | Groups | Blogs | Calendar | Mark Forums Read |
| Mikado V-BAR Mikado V-Stabi/V-BAR Flybarless System Software and Hardware Support |
Can I use the Aux port on my VBar to supply power to my Switchglo?
Thanks, Chuck
VBar 700N, 450 Pro, Avant Aurora, 250 |
Yes, powerbus is shared on the Vbar, any port can be power in or out.
"Never argue with an idiot - he'll drag you down to his level and beat you with experience!" My site: To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Much appreciated.
Thanks, Chuck
If switchglo is connected to ch4, can ch4 be assigned to a switch on my X9303? I tried connecting my switchglo to the v-bar Aux ch but it doesn't trigger my switchglo.
I'd also like to know if you can use your TX to trigger Switchglo without having to run a seperate RX.
#6 |
can we just use a y connector on the govenor RPM selector channel?
I'm not a player. I just crash a lot. |
#7 |
That's analogous to what I do on my flybarred Knight 3D with the gyro gain channel.
Alan (just call me "Bum"; no need to be so formal) Nankin Hobby Field Rep Helis: Atom 500, Logo 500 (V-Bar), Atom 6HV (V-Bar). Memberships: AMA |
#8 |
I have my Gov Ch (Aux2) tied to FMod. If I used a Y-connector on Aux2, wouldn't that simply arm the switchglo without allowing me to turn it on/off?
#9 |
I am also considering the switchglo... But I need to know how to wire and activate it with a JR 9303/9503 via a switch.
T-Rex 450 Pro, FBL T-Rex 500, T-Rex 600E, FBL T-REX 600NP & FBL T-REX 700 Flying helis makes life's woes bareable! |
#10 | |
