Old 09-24-2011, 09:03 AM   #161
quattros4
Im just using the align grey mount on a KDE anti-rotation bracket. Align 3g v3. Working very good so far!
quattros4 is offline        Reply With Quote
Old 09-28-2011, 09:46 AM   #162
turbokimmees
My LHS don't have any metal anti vibration plate....For the quick fix...can I use coin quarter? Have any one try that? What's the difference? I have Align blue gel and M3 4010..tape.. going to try the coin in between them.
turbokimmees is offline        Reply With Quote
Old 11-21-2011, 08:19 AM   #163
crash8384
Angry noob to align 3g heli is unflyable
ok guys. ive read and read and im using the 3m grey tape from walmart. i use it on everything. just got my b400 fully built. have the tarot head and align 3g on it. goes ape sh#* when i try to take off. cant even fly the dang think. had 1 layer then 2 then 3 then back to 1 layer of tape. i have went thru the setup over and over. it hasthe gel mod done to sensor. im close to oulling this 3g crap off and chunking it. i fly other fbl helis and never have any probs with them. i need help. where do i turn. i dont know what im doing wrong and im the only heli pilot here. my gains are at 12:00 pos.swash is 65% pit is 67% tx is a 9303
crash8384 is offline        Reply With Quote
Old 11-23-2011, 03:42 AM   #164
Lighty
where have you mounted the 3G and what heli?
Lighty is offline        Reply With Quote
Old 04-14-2013, 09:40 PM   #165
Turttle
Sorry to bring back a thread from the dead but mounting tape to use on electric vs nitro are 2 completely different things.I here a lot of strapping but its not to make sure the gyro comes flying off its to pute some preasure on a gyro thats mounted with softer tape as if it were in a nitro bird.I can use 3m on an electric all day but pute that in a nitro and vibes are so bad it may screw something up or damage the gyro itself after a while.Not to mension hard take offs twitchy servos and just crazy drifting porblems.On a nitro the vibes are bad enouph you loose screws if there not threadlocked and even then you may loose a couple
Northern California RC Unlimited RC Flyers.
www.ashcreekrcflyers.com
Turttle is offline        Reply With Quote
