Old 10-03-2006, 05:56 AM   #1
DebianDog
Default Programming a 9Z radio for helicopters -(Video)-
This is not the end all bee all but it will get you over the "got ya's" and get you flying with a correctly setup radio. For those that try and help other people that do not have a 9Z this will be VERY helpful.
Finless Bob shows you how to program the Futaba 9Z - 46 minutes - 76 megs
Dan Da Dawg - JR X9303
Hexa F550 on 3S + 6S TREX 500 + 6S TREX 600 + Blade mSR + Blade mCPx2 Brushless + 12S Rave FBL ENV
DebianDog is offline        Reply With Quote
Old 10-05-2006, 04:08 AM   #2
zorba
Hi are they any videos available for the Futaba 7CHP transmitter?
Bill
zorba is offline        Reply With Quote
Old 10-05-2006, 08:44 AM   #3
DebianDog
We are working on doing a whole bunch after the Centruy Swift videos. Stay tuned
Old 10-25-2006, 01:51 PM   #4
athiqueahmed
Will that include the FF8? I'm asking because I realise that it's a discontinued Tx.
athiqueahmed is offline        Reply With Quote
Old 12-18-2006, 01:41 AM   #5
Godfather
How about videos for the programming the Futaba 9C super?
Pretty please?! :mrgreen:
Godfather is offline        Reply With Quote
Old 12-25-2006, 01:30 AM   #6
harrysvr
The same for 9chps? thanks
harrysvr is offline        Reply With Quote
Old 07-19-2008, 06:20 PM   #7
roglan
I'd love a setup video for the new 10C fasst! Please Finless Bob!
roglan is offline        Reply With Quote
Old 12-27-2008, 05:51 PM   #8
ImRich
Thanks for the great video on the 9Z!
I know that this video was done a while ago, but this minor point that may help someone if they want to properly understand the functions of this overly powerful (and therefore confusing) radio.
Under Failsafe setup, I believe Bob mentions the 'BFS' setup as 'before fail safe', he states that it's confusing and that it allows you to return the control of the servos my moving the throttle stick.
This is not quite right.
'BFS' is the 'Battery Fail Safe' feature. If the receiver detects that your battery voltage (going into the receiver, not your motor battery) is too low, it will drop your motor throttle to idle (or a programmed set point). To regain control of your throttle, you then must move the throttle stick to below the set point, and then move it back up above the set point to have throttle again.
Note that this function does not affect any of the fail safe channels except the throttle control.
Of course moving your throttle stick on a heli also changes the collective, so this feature may not be very useful for a heli pilot. I think its more useful for aircraft pilots. But then again, losing receiver voltage is not good for any pilot!
Either way, feel free to disable this function as Bob mentioned in the video.
ImRich is offline        Reply With Quote
